This motion sensor comes up as a temperature sensor. The zigbee log shows
2017-09-09 09:18:10.897 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Node discovered: IEEE=24FD5B000102F674, NWK=7FB3, Type=END_DEVICE
2017-09-09 09:18:10.908 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 24FD5B000102F674: Starting ZigBee device discovery
2017-09-09 09:18:10.909 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 24FD5B000102F674: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_ember:17e682cd
2017-09-09 09:18:10.909 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zigbee:device:17e682cd:24fd5b000102f674' to inbox.
2017-09-09 09:18:10.909 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: ZigBee node property discovery start
2017-09-09 09:18:10.910 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: ZigBee node property discovery using 32691/1
2017-09-09 09:18:14.485 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: Hardware version request timeout
2017-09-09 09:18:14.677 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 7CE5240000077666: Node updated - IEEE=7CE5240000077666, NWK=F963, Type=ROUTER
2017-09-09 09:18:22.608 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: Stack version request timeout
2017-09-09 09:18:23.677 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: Date code request timeout
2017-09-09 09:18:23.677 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: ZigBee node property discovery complete: {zigbee_manufacturer=SmartThings, zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_model=motionv4, zigbee_appversion=25, zigbee_networkaddress=32691, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], zigbee_powersource=MAINS, zigbee_zclversion=1}
2017-09-09 09:18:23.678 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 24FD5B000102F674: Update ZigBee device zigbee:device with bridge zigbee:coordinator_ember:17e682cd
2017-09-09 09:19:14.631 [DEBUG] [zigbee.internal.ZigBeeHandlerFactory] - Creating coordinator handler for org.eclipse.smarthome.core.thing.internal.ThingImpl@60b2e76
2017-09-09 09:19:14.633 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - Initializing ZigBee thing handler zigbee:device:17e682cd:24fd5b000102f674.
2017-09-09 09:19:14.639 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000102F674: Coordinator status changed to ONLINE.
2017-09-09 09:19:14.639 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000102F674: Coordinator is ONLINE. Starting device initialisation.
2017-09-09 09:19:14.650 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000102F674: Initialising node
2017-09-09 09:19:14.651 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000102F674: Created 1 channels
2017-09-09 09:19:22.294 [DEBUG] [converter.ZigBeeConverterTemperature] - ZigBee attribute reports ZclAttribute [cluster=TEMPERATURE_MEASUREMENT, id=0, name=MeasuredValue, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=3114] from 24FD5B000102F674
2017-09-09 09:19:22.341 [DEBUG] [converter.ZigBeeConverterTemperature] - ZigBee attribute reports ZclAttribute [cluster=TEMPERATURE_MEASUREMENT, id=0, name=MeasuredValue, dataType=UNSIGNED_16_BIT_INTEGER, lastValue=3114] from 24FD5B000102F674
2017-09-09 09:19:22.599 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 24FD5B000102F674: Initializing ZigBee thing handler
2017-09-09 09:19:22.610 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: ZigBee node property discovery start
2017-09-09 09:19:22.611 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: ZigBee node property discovery using 32691/1
2017-09-09 09:19:33.583 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: Date code request timeout
2017-09-09 09:19:33.583 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 24FD5B000102F674: ZigBee node property discovery complete: {zigbee_manufacturer=SmartThings, zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_model=motionv4, zigbee_appversion=25, zigbee_networkaddress=32691, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], zigbee_powersource=MAINS, zigbee_zclversion=1}
Anybody has it working as a motion sensor?
