Pi 3 Model B Plus Rev 1.3. (but same problem on Pi4 2GB)
I have done a fresh install of openhabian, on my pi.
Without any futher installs, I upgraded to to 3.2.0 M2. did a reboot
Then tried the installing smartthings binding 3.2.0 M2, but i get this error:
2021-09-06 21:47:48.367 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.smartthings.internal.SmartthingsHandlerFactory.sendDeviceCommand(SmartthingsHandlerFactory.java:129) ~[?:?]
at org.openhab.binding.smartthings.internal.discovery.SmartthingsDiscoveryService.sendSmartthingsDiscoveryRequest(SmartthingsDiscoveryService.java:136) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
The binding won’t discover anything (and I have tried adding the hub and the IP of the ST Hub)
I had it up running back in the OH 2.3. days, and just to be sure I have removed and reinstalled the apps and devide handler on ST.
I have tried upgrading java through the openHABian Configuration Tool, but no luck.
Any tips to get this working?
im not an experienced programmer.
Peter
