Having an issue setting up samba to work with my windows pc. fresh install of 3.4.1. followed the officail guide but still struggling. the log is showing errors. Update. I can see the share from my iPhone. I just get an error when trying to move more home.items files over for instance. Most of my setup is textual config and I’ve had a major system failure that I couldn’t cure with a backup file. Using windows 8.
openhabian@openhabian:~ $ sudo cat /var/log/samba/log.smbd
[2023/02/06 20:26:46.890141, 0] ../../source3/smbd/server.c:1784(main)
smbd version 4.13.13-Debian started.
Copyright Andrew Tridgell and the Samba Team 1992-2020
[2023/02/06 20:26:47.060555, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
[2023/02/06 20:29:41, 0] ../../lib/util/util.c:488(directory_create_or_exist_strict)
invalid permissions on directory '/var/log/samba/cores': has 0750 should be 0700
[2023/02/06 20:29:41, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
Failed to create /var/log/samba/cores for user 0 with mode 0700
[2023/02/06 20:29:41, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
Unable to setup corepath for smbd: File exists
[2023/02/06 20:29:41.888063, 0] ../../source3/smbd/server.c:1784(main)
[2023/02/06 20:29:41.930670, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
[2023/02/06 20:31:01, 0] ../../lib/util/util.c:488(directory_create_or_exist_strict)
[2023/02/06 20:31:01, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
[2023/02/06 20:31:01, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
[2023/02/06 20:31:01.112831, 0] ../../source3/smbd/server.c:1784(main)
[2023/02/06 20:31:01.296372, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
[2023/02/06 20:56:01, 0] ../../lib/util/util.c:488(directory_create_or_exist_strict)
[2023/02/06 20:56:01, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
[2023/02/06 20:56:01, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
[2023/02/06 20:56:01.443187, 0] ../../source3/smbd/server.c:1784(main)
[2023/02/06 20:56:01.476855, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
[2023/02/06 21:07:20, 0] ../../lib/util/util.c:488(directory_create_or_exist_strict)
[2023/02/06 21:07:20, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
[2023/02/06 21:07:20, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
[2023/02/06 21:07:20.856851, 0] ../../source3/smbd/server.c:1784(main)
[2023/02/06 21:07:20.890689, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
[2023/02/06 21:17:03, 0] ../../lib/util/util.c:488(directory_create_or_exist_strict)
[2023/02/06 21:17:03, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
[2023/02/06 21:17:03, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
[2023/02/06 21:17:03.899149, 0] ../../source3/smbd/server.c:1784(main)
[2023/02/06 21:17:03.932675, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
[2023/02/06 21:26:16, 0] ../../lib/util/util.c:488(directory_create_or_exist_strict)
[2023/02/06 21:26:16, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
[2023/02/06 21:26:16, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
[2023/02/06 21:26:16.442856, 0] ../../source3/smbd/server.c:1784(main)
[2023/02/06 21:26:16.638941, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
anyone having the same issue or offer some advise on how to get it going please?
