tnemrap
(Michael Parment)
January 27, 2019, 12:45pm
1
I have created a binding for smhi weather (Swedish Meteorological and Hydrological Institute).
I need testers before i have it going into 2.5 release.
You can find the documentation at https://github.com/tnemrap/openhab2-addons/tree/smhi/addons/binding/org.openhab.binding.smhi
You can download the jar from here
I have tested it with both 2.4 and 2.5-snapshot.
Update: Updated jar with latest fixes.
Update: Updated with better location check.
/Mike
Kattlukt
(N)
February 10, 2019, 10:36pm
2
This is great news!
Only tested temperature, wind and time. It works!
I will use this for my sunshade?(markis).
Good work and thank you!
martin1
(Martin Hagelin)
March 8, 2019, 2:13pm
3
Works for me as well! Running 2.5.0M1.
The only thing I can think of is that maybe the new units-of-measurement stuff should be used, like Number:Temperature instead of only Number etc.
//Martin
I havet the latest snapshot of 2.5 and it is still working good!
How often does SMHI update their stations?
AleAle
(Ale)
June 9, 2019, 8:58am
6
hi
I installed the binging on 2.4 but I get an error:OFFLINE - COMMUNICATION_ERROR
in the instructions: Latitude must be between 52.50 and 70.75, but my latitude is between 44 and 45
is this the problem?
if I use the site smhi.se I can see the data of my area and the 10days forecasts
https://www.smhi.se/vadret/vadret-i-sverige/ortsprognoser/q/San%20Lazzaro/3168175#tab=0,chart=1
Ale
tnemrap
(Michael Parment)
June 9, 2019, 4:00pm
7
I will check this for you.
/Mike
tnemrap
(Michael Parment)
June 12, 2019, 4:42pm
9
ssalonen
(Ssalonen)
June 12, 2019, 5:07pm
10
Cool stuff! Nice to see more Swedish institute covered up, I’ve worked on similar binding against Finnish Meteorological Institute (FMI) https://github.com/openhab/openhab2-addons/pull/5226
One small note: I expect you to encounter issues with mm/h
unit in case you go for UoM (which I highly recommend) – at least that was the issue for me in Finnish Meteorology of Institute (FMI) binding, underlying issue [UoM] IAE on parsing value "0.41 µ(km/h)" · Issue #644 · openhab/openhab-core · GitHub .
tnemrap
(Michael Parment)
June 13, 2019, 6:16am
12
Have now updated the jar in the first post with the latest fixes.
/Mike
tnemrap
(Michael Parment)
September 17, 2019, 7:14pm
13
I have closed the pull request and will keep the source in my own repository.
It is to much work to get a binding approved.
I will keep the jar updated in this thread when i do changes.
/Mike
vespaman
(Micael )
September 29, 2019, 1:53pm
14
So while upgrading from 2.4 to 2.5m3, I decided to also add this binding (thanks for your work @tnemrap !).
However, there seems to be some issue with the configuration;
My things file looks like this; (replaced the last digits with 123456)
Thing smhi:weather-and-forecast:stockholm [ weatherlocation="59.123456,17.123456", refresh=60 ]
In the log, the only thing information I get, is;
14:42:32.578 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'smhi:weather-and-forecast:stockholm' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
If I look instead, in paperui, it does not show any weather location. Not sure if it should, since I am using things file instead.
Am I missing something obvious?
tnemrap
(Michael Parment)
October 2, 2019, 1:56pm
15
Sorry for late answer. I will look into this in this weekend.
/mike
Did you find a fix for this. I have the exact same problem.
tnemrap
(Michael Parment)
November 30, 2019, 10:19am
17
I can not reproduce the problem. Can you try to run it in debug mode.
/mike
soists
(Lennart)
December 9, 2019, 7:34pm
18
Hej @tnemrap ! I just tried your binding and get
'smhi:weather-and-forecast:stockholm' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING) to UNINITIALIZED (HANDLER_MISSING_ERROR)
I placed the provided jar file of your first post in /usr/share/openhab2/addons
Any idea?
tnemrap
(Michael Parment)
December 9, 2019, 9:31pm
19
Was it possible to add a thing in paperui?
/Mike
soists
(Lennart)
December 9, 2019, 9:40pm
20
I was not aware of that option, but yeah that works.
my textual configuration is:
tnemrap
(Michael Parment)
December 9, 2019, 9:47pm
21
must have a miss in documentation
This is my configuration
Thing smhi:weather-and-forecast:gavle [ location="60.654321,17.123456", refresh=60 ]
