Hi There,
i am using the SMLReader Binding from Market Place. My USBSerial adapters are connected to my windows machine. Openhab runs on this machine too.
Randomly one of the two adapters disconnects and becomes unavailable. I have to restart openhab to get things working again.
Is this a windows or openhab issue? Any suggestions?
Log:
2017-08-25 09:06:29.627 [ERROR] [binding.smlreader.internal.SmlDevice] - smlreader:meter:867f9c8a: Error during receive values from device: can't parse argument number:
2017-08-25 09:06:29.627 [ERROR] [g.smlreader.handler.SmlReaderHandler] - Failed to read SML
java.lang.IllegalArgumentException: can't parse argument number:
at java.text.MessageFormat.makeFormat(MessageFormat.java:1429)[:1.8.0_131]
at java.text.MessageFormat.applyPattern(MessageFormat.java:479)[:1.8.0_131]
at java.text.MessageFormat.<init>(MessageFormat.java:362)[:1.8.0_131]
at java.text.MessageFormat.format(MessageFormat.java:840)[:1.8.0_131]
at org.openhab.binding.smlreader.connectors.SerialConnector.openConnection(SerialConnector.java:106)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at org.openhab.binding.smlreader.connectors.ConnectorBase.getMeterValues(ConnectorBase.java:66)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at org.openhab.binding.smlreader.connectors.SerialConnector.getMeterValues(SerialConnector.java:1)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at org.openhab.binding.smlreader.internal.SmlDevice.readValues(SmlDevice.java:266)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at org.openhab.binding.smlreader.handler.SmlReaderHandler.updateOBISValue(SmlReaderHandler.java:128)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at org.openhab.binding.smlreader.handler.SmlReaderHandler.access$0(SmlReaderHandler.java:126)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at org.openhab.binding.smlreader.handler.SmlReaderHandler$1.run(SmlReaderHandler.java:100)[195:org.openhab.binding.smlreader:2.1.0.201706271509]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_131]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_131]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_131]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_131]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
Caused by: java.lang.NumberFormatException: For input string: ""
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)[:1.8.0_131]
at java.lang.Integer.parseInt(Integer.java:592)[:1.8.0_131]
at java.lang.Integer.parseInt(Integer.java:615)[:1.8.0_131]
at java.text.MessageFormat.makeFormat(MessageFormat.java:1427)[:1.8.0_131]
... 17 more
