Hi there
I would like to get some information from my network devices by using the snmp binding. Currently I try to get the uptime from my firewall.
I have some problems getting the snmp binding to work. After changing the port to 1030 in the snmp.cfg i finally see something going on by tcpdumping on port 1030.
08:48:34.856218 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 76) 10.4.4.254.snmp > 10.4.4.111.1030: { SNMPv1 { GetResponse(33) R=2108097992 system.sysUpTime.0=2436890100 } }
As you can see, i get an answer with the correct uptime. But if i list the items in KARAF, the FW_Uptime is still State=NULL
openhab> items list
fwTS_UpTime (Type=NumberItem, State=NULL, Label=FW Uptime, Category=null)
The item in the items file looks like this
Number fwTS_UpTime “FW Uptime [%d]” { snmp=“<[10.4.4.254:public:.1.3.6.1.2.1.1.3.0:10000]” }
And on the sitemap
Text item=fwTS_UpTime label=“test [%s]” icon=“network”
OH2 is installed on Raspberry Pi.
Version OH2 2.0.0-SNAPSHOT Build#526
Thanks for your help.
