Please review the documentation a little closer.
The engineid should not have Seperators “:” The `engineId` must be given in hexadecimal notation (case-insensitive) without separators (e.g. `80000009035c710dbcd9e6` ). The allowed length is 11 to 32 bytes (22 to 64 hex characters). If you encounter problems, please check if your agent prefixes the set engine id (e.g. Mikrotik uses `80003a8c04` and appends the set value to that).
