Hi everyone,
I have a problem with snmp binding (v2).
I have configured everything (thing, channels, items) with text files and it’s working as expected.
But after disabling the thing (UNINITIALIZED (DISABLED)
) and enabling it again, the snmp:target thing stays uninitialized (UNINITIALIZED (HANDLER_MISSING_ERROR)
). Doesn’t matter how often I try or if I do the disabling/enabling via PaperUI or rule. So it seems to be reproduce-able. All other snmp:targets continue to work properly.
Is this a known limitation? Even a intended behavior? Anybody ever seen the same? Any hint’s welcome
For reference:
- same procedure works for other things/bindings, so it seems to be a snmpv2 issue
- OS: Docker on Synology
- OH version = 2.5.10
Sebastian
