- Platform information:
- Hardware:
Rpi4, 2GB
- OS:
Linux openhabian 6.6.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.20-1+rpt1 (2024-03-07) aarch64
- Java Runtime Environment:
standard installation
- openHAB version:
OH4
(new installation + restored backup)
I have an issue with my zigbee configuration I cannot figure out alone. I use an external, rooted Silvercrest) Zigbee hub and the socat utility to create a local serial port for OH, as described here.
Everything worked till last week, when suddently I have got a “Communication Error”, here below the log (zigbee debug enabled)
2024-04-03 20:29:57.231 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:d262c81014' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2024-04-03 20:29:57.270 [INFO ] [penhab.event.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:coordinator_ember:d262c81014 changed to UNKNOWN.
2024-04-03 20:29:58.266 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2024-04-03 20:29:58.267 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2024-04-03 20:29:58.270 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2024-04-03 20:29:58.307 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C138A93227C615: ZigBee reading network state complete.
2024-04-03 20:29:58.354 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C1382CA259B890: ZigBee reading network state complete.
2024-04-03 20:29:58.391 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 00124B000EF3CD0B: ZigBee reading network state complete.
2024-04-03 20:29:58.417 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 60A423FFFE0EA5BF: ZigBee reading network state complete.
2024-04-03 20:29:58.476 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - BC33ACFFFE47E968: ZigBee reading network state complete.
2024-04-03 20:29:58.519 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C138FF42C3943B: ZigBee reading network state complete.
2024-04-03 20:29:58.559 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6FFFFE816CEF: ZigBee reading network state complete.
2024-04-03 20:29:58.599 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C138F29CEE0A1A: ZigBee reading network state complete.
2024-04-03 20:29:58.645 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C1387803356E06: ZigBee reading network state complete.
2024-04-03 20:29:58.687 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C1385EDBF00B8E: ZigBee reading network state complete.
2024-04-03 20:29:58.732 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C138AB208EFD4A: ZigBee reading network state complete.
2024-04-03 20:29:58.782 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C138CEFD09C413: ZigBee reading network state complete.
2024-04-03 20:29:58.826 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C13826147B4BC4: ZigBee reading network state complete.
2024-04-03 20:29:58.869 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C13875162B4AEF: ZigBee reading network state complete.
2024-04-03 20:29:58.911 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C13899F0DE2DFA: ZigBee reading network state complete.
2024-04-03 20:29:58.948 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6FFFFE816D5B: ZigBee reading network state complete.
2024-04-03 20:29:58.993 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C1389699F6EDE3: ZigBee reading network state complete.
2024-04-03 20:29:59.033 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - A4C1380C5680A5A6: ZigBee reading network state complete.
2024-04-03 20:29:59.036 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyzbbridge1] at 115200 baud, flow control FLOWCONTROL_OUT_RTSCTS.
2024-04-03 20:29:59.042 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyzbbridge1]
2024-04-03 20:29:59.043 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Unable to open serial port
This is the socat log file (max debug)
2024/04/03 20:04:10 socat[48217] I socat by Gerhard Rieger and contributors - see www.dest-unreach.org
2024/04/03 20:04:10 socat[48217] I This product includes software developed by the OpenSSL Project for use in the OpenSSL Toolkit. (http://www.openssl.org/)
2024/04/03 20:04:10 socat[48217] I This product includes software written by Tim Hudson (tjh@cryptsoft.com)
2024/04/03 20:04:10 socat[48217] I setting option "symbolic-link" to "/dev/ttyzbbridge1"
2024/04/03 20:04:10 socat[48217] I setting option "raw"
2024/04/03 20:04:10 socat[48217] I setting option "user" to 106
2024/04/03 20:04:10 socat[48217] I setting option "group" to 20
2024/04/03 20:04:10 socat[48217] I setting option "perm" to 511
2024/04/03 20:04:10 socat[48217] I openpty({6}, {7}, {"/dev/pts/3"},,) -> 0
2024/04/03 20:04:10 socat[48217] N PTY is /dev/pts/3
2024/04/03 20:04:10 socat[48217] N opening connection to AF=2 192.168.178.123:8888
2024/04/03 20:04:10 socat[48217] I starting connect loop
2024/04/03 20:04:10 socat[48217] I socket(2, 1, 6) -> 8
2024/04/03 20:04:10 socat[48217] N successfully connected from local address AF=2 192.168.178.88:60696
2024/04/03 20:04:10 socat[48217] I resolved and opened all sock addresses
2024/04/03 20:04:10 socat[48217] N starting data transfer loop with FDs [6,6] and [8,8]
and the related files
openhabian@openhabian:~ $ ls -l /dev/ttyzbbridge1 /dev/pts/3
crwxrwxrwx 1 openhab dialout 136, 3 Apr 3 20:04 /dev/pts/3
lrwxrwxrwx 1 root root 10 Apr 3 20:04 /dev/ttyzbbridge1 -> /dev/pts/3
I do not see anything wrong, so should I continue to debug to find the issue?
Max
