I’ve got Openhab running with a few sensors now I’m ready to make it do some actual automation.
What I want to do is measure the soil moister content in my green house and turn on my drip irrigation based on when the soil needs water not simply with a timer.
I pretty sure I could scratch build something with an Arduino, but an of the shelf solution especially for the soil moister measurement would sure simplify things.
Not having bought into any home automation standard as of yet, I’m open to suggestions.
There is a Koubachi binding, but I think the product line is in doubt related to a corporate acquisition.
I don’t have to open ports in the router to use cloud services; they work similarly to web browsers in that openHAB makes HTTP(S) requests to get and set information.
That VH400 probe looks very interesting, it could be driven with an Arduino turns on a relay to actuate a 12v irrigation valve at the appropriate time and wirelessly sends data to an MQTT server which would allow me to change the set points etc via OH.
Hi Björn!
i’m looking for a soil moister sensor and found your (1 year old) post.
the combination AVR-NET-IO board with VH100 sensor looks interesting.
are you still running this setup? Have you had any problems so far?
Would you care to explain your setup (hard- / software)?
