Solarpower widget
OpenHAB power usage widget
I was always jealous at the solar widget that Hass.IO offers. So I decided to create one for OpenHAB myself. The dots on the lines move faster or slower depending on the values detected. The house will glow green, yellow, orange or red depending on the power usage.
As I’m getting alot of positive feedback, I decided to share it here!
Hope you’ll like it!
Screenshots
All variable can be set in widget settings.
Changelog
Widget created
Version 0.1
  • initial release
Resources
version: 1
widgets:
  energy_flow_new:
    tags:
      - ev
      - grid
      - solar
      - battery
      - water
      - energy
    props:
      parameters:
        - context: item
          label: Solar Power Item (W)
          required: true
          type: TEXT
        - context: item
          label: Battery Power Item (W)
          required: true
          type: TEXT
        - context: item
          label: Battery %
          required: false
          type: TEXT
        - context: item
          label: Battery charge rate
          required: false
          type: TEXT
        - context: item
          label: Battery discharge rate
          required: false
          type: TEXT
        - context: item
          label: Grid Import Item (W)
          required: true
          type: TEXT
        - context: item
          label: Grid Export Item (W)
          required: true
          type: TEXT
        - context: item
          label: Home Consumption Item (W)
          required: true
          type: TEXT
        - context: item
          label: Water Usage L/h Item
          required: false
          type: TEXT
        - context: item
          label: EV Battery %
          required: false
          type: TEXT
        - context: item
          label: EV Power (W)
          required: false
          type: TEXT
        - context: item
          label: EV Charge (kWh)
          required: false
          type: TEXT
        - context: item
          label: EV Connected Item (Switch / Contact)
          required: false
          type: TEXT
        - context: item
          label: Mazout Price Item
          required: false
          type: TEXT
        - context: item
          label: Home Peak Today Item (W)
          required: false
          type: TEXT
        - context: item
          label: Solar Today (kWh)
          required: false
          type: TEXT
        - context: item
          label: Grid Import Today (kWh)
          required: false
          type: TEXT
        - context: item
          label: Home Today (kWh)
          required: false
          type: TEXT
    component: f7-card
      style:
        background: transparent
        box-shadow: none
        margin: 0
        padding: 0
    slots:
      content:
        - component: f7-block
            style:
              background: "#18181b"
              border: "1px solid #3f3f46"
              borderRadius: 20px
              boxShadow: 0 10px 15px -3px rgba(0, 0, 0, 0.2), 0 4px 6px -4px rgba(0, 0, 0, 0.2)
              color: "#e4e4e7"
              padding: clamp(12px, 1.6vw, 20px) clamp(8px, 1.4vw, 18px)
          slots:
            default:
              - component: f7-row
                  style:
                    flexWrap: nowrap
                    justifyContent: space-between
                    marginBottom: 12px
                slots:
                  default:
                    - component: f7-col
                        style:
                          flex: 1 1 0
                          minWidth: 0
                          textAlign: center
                      slots:
                        default:
                          - component: f7-icon
                              color: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? '#FACC15' : '#93c5fd'"
                              f7: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? 'sun_max' : 'moon'"
                              style:
                                fontSize: clamp(18px, 1.6vw + 12px, 26px)
                              style:
                                fontSize: clamp(13px, 1.4vw + 8px, 24px)
                                fontWeight: "700"
                                lineHeight: 1.15
                                margin: 3px 0 1px
                                overflow: hidden
                                textOverflow: ellipsis
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state ? Number.parseFloat(items[props.solarPowerItem].state).toFixed(0) : '0') + ' W'"
                              style:
                                color: "#a1a1aa"
                                fontSize: clamp(8px, 0.6vw + 7px, 11px)
                                fontWeight: "600"
                                letterSpacing: 0.02em
                            slots:
                              default:
                                - component: Label
                                    text: SOLAR
                    - component: f7-col
                        style:
                          flex: 1 1 0
                          minWidth: 0
                          textAlign: center
                      slots:
                        default:
                              color: "#14B8A6"
                              f7: battery_25
                              style:
                              style:
                                color: "#14B8A6"
                                fontWeight: "700"
                                lineHeight: 1.15
                                margin: 3px 0 1px
                                overflow: hidden
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state ? (Number.parseFloat(items[props.batteryPowerItem].state) >= 0 ? '+' : '') + Number.parseFloat(items[props.batteryPowerItem].state).toFixed(0) : '0') + ' W'"
                              style:
                                color: "#a1a1aa"
                                fontWeight: "600"
                            slots:
                              default:
                                - component: Label
                                    text: BATTERY
                              style:
                                color: "=(items[props.batteryPowerItem] && Number.parseFloat(items[props.batteryPowerItem].state || 0) > 1) ? '#4ade80' : ((items[props.batteryPowerItem] && Number.parseFloat(items[props.batteryPowerItem].state || 0) < -1) ? '#f87171' : '#a1a1aa')"
                                fontSize: clamp(8px, 0.5vw + 6px, 10px)
                                marginTop: 1px
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(items[props.batteryPowerItem] && Number.parseFloat(items[props.batteryPowerItem].state || 0) > 1) ? 'Charging' : ((items[props.batteryPowerItem] && Number.parseFloat(items[props.batteryPowerItem].state || 0) < -1) ? 'Discharging' : 'Idle')"
                    - component: f7-col
                        style:
                          flex: 1 1 0
                          minWidth: 0
                          textAlign: center
                      slots:
                        default:
                              color: "#A1A1AA"
                              f7: house
                              style:
                              style:
                                color: "#f6b7f6"
                                fontWeight: "700"
                                lineHeight: 1.15
                                margin: 3px 0 1px
                                overflow: hidden
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(items[props.homePowerItem] && items[props.homePowerItem].state ? Number.parseFloat(items[props.homePowerItem].state).toFixed(0) : '0') + ' W'"
                              style:
                                color: "#a1a1aa"
                                fontWeight: "600"
                            slots:
                              default:
                                - component: Label
                                    text: HOME
                    - component: f7-col
                        style:
                          flex: 1 1 0
                          minWidth: 0
                          textAlign: center
                      slots:
                        default:
                              color: "#1E3A8A"
                              f7: bolt_horizontal
                              style:
                              style:
                                color: "=(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) && Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > 1) ? '#f87171' : '#4ade80'"
                                fontWeight: "700"
                                lineHeight: 1.15
                                margin: 3px 0 1px
                                overflow: hidden
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) ? '+' + Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0).toFixed(0) : Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0).toFixed(0)) + ' W'"
                              style:
                                color: "#a1a1aa"
                                fontWeight: "600"
                            slots:
                              default:
                                - component: Label
                                    text: GRID
                              style:
                                marginTop: 1px
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) && Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > 1) ? 'Importing' : (Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) > 1 ? 'Exporting' : 'Idle')"
                    - component: f7-col
                        style:
                          flex: 1 1 0
                          minWidth: 0
                          textAlign: center
                      slots:
                        default:
                              color: "#3B82F6"
                              f7: drop
                              style:
                              style:
                                color: "#3B82F6"
                                fontWeight: "700"
                                lineHeight: 1.15
                                margin: 3px 0 1px
                                overflow: hidden
                                whiteSpace: nowrap
                            slots:
                              default:
                                - component: Label
                                    text: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state ? Number.parseFloat(items[props.waterUsageLhItem].state).toFixed(1) : '0') + ' L/h'"
                              style:
                                color: "#a1a1aa"
                                fontWeight: "600"
                            slots:
                              default:
                                - component: Label
                                    text: WATER
                  style:
                    background: "#27272a"
                    borderRadius: 14px
                    marginTop: 8px
                    overflow: visible
                    padding: 16px 8px 16px
                slots:
                  default:
                    - component: f7-row
                        class:
                          - no-gap
                        preserveAspectRatio: xMidYMid meet
                        style:
                          aspectRatio: 520 / 276
                          display: block
                          height: auto
                          margin: 0 auto
                          maxHeight: 276px
                          maxWidth: 560px
                          overflow: visible
                          width: 100%
                        tag: svg
                        viewBox: 50 19 520 276
                        width: 100%
                        xmlns: http://www.w3.org/2000/svg
                      slots:
                        default:
                          - component: f7-row
                              d: M 108 65 Q 230 100 325 107
                              fill: none
                              opacity: "0.3"
                              stroke: "#CA8A04"
                              stroke-linecap: round
                              stroke-width: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? 10 : 3"
                              tag: path
                          - component: f7-row
                              d: M 108 165 Q 230 125 325 123
                              fill: none
                              opacity: "0.35"
                              stroke: "#0F766E"
                              stroke-width: "=(items[props.batteryPowerItem] && Math.abs(Number.parseFloat(items[props.batteryPowerItem].state || 0)) > 1) ? 10 : 3"
                              tag: path
                          - component: f7-row
                              d: M 512 65 Q 390 100 325 107
                              fill: none
                              opacity: "0.35"
                              stroke: "=(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) && Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > 1) ? '#f87171' : '#4ade80'"
                              stroke-width: "=(Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) > 1) ? 10 : 3"
                              tag: path
                          - component: f7-row
                              d: M 317 255 Q 317 195 317 148
                              fill: none
                              opacity: "0.35"
                              stroke: "#2563EB"
                              stroke-width: "=(items[props.waterUsageLhItem] && Number.parseFloat(items[props.waterUsageLhItem].state || 0) > 0) ? 10 : 3"
                              tag: path
                          - component: f7-row
                              d: M 512 165 Q 390 125 325 123
                              fill: none
                              opacity: "0.35"
                              stroke: "#16A34A"
                              stroke-width: "=(items[props.evPowerItem] && Number.parseFloat(items[props.evPowerItem].state || 0) > 1) ? 10 : 3"
                              tag: path
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#EAB308"
                              r: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state ? Math.max(3, Math.min(7.5, 3 + ((Number.parseFloat(items[props.solarPowerItem].state) || 0) / 700))) : 3)"
                              style:
                                opacity: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state && Number.parseFloat(items[props.solarPowerItem].state) > 1) ? 1 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    dur: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state ? Math.max(0.55, Math.min(2.2, 1.7 - ((Number.parseFloat(items[props.solarPowerItem].state) || 0) / 2200))) : 1.5)"
                                    path: M 108 65 Q 230 100 325 107
                                    repeatCount: indefinite
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#EAB308"
                              r: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state ? Math.max(2.2, Math.min(5.5, 2.5 + ((Number.parseFloat(items[props.solarPowerItem].state) || 0) / 900))) : 2.2)"
                              style:
                                opacity: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state && Number.parseFloat(items[props.solarPowerItem].state) > 1) ? 0.7 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    begin: -0.7s
                                    dur: "=(items[props.solarPowerItem] && items[props.solarPowerItem].state ? Math.max(0.6, Math.min(2.0, 1.55 - ((Number.parseFloat(items[props.solarPowerItem].state) || 0) / 2400))) : 1.4)"
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#2DD4BF"
                              r: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state ? Math.max(3, Math.min(7.5, 3 + Math.abs(Number.parseFloat(items[props.batteryPowerItem].state) || 0) / 550)) : 3)"
                              style:
                                opacity: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state && Math.abs(Number.parseFloat(items[props.batteryPowerItem].state)) > 1) ? 1 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    dur: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state ? Math.max(0.55, Math.min(2.2, 1.9 - (Math.abs(Number.parseFloat(items[props.batteryPowerItem].state) || 0) / 2000))) : 1.85)"
                                    path: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state && Number.parseFloat(items[props.batteryPowerItem].state) < 0) ? 'M 108 165 Q 230 125 325 123' : 'M 325 123 Q 230 125 108 165'"
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#2DD4BF"
                              r: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state ? Math.max(2.2, Math.min(5.5, 2.5 + Math.abs(Number.parseFloat(items[props.batteryPowerItem].state) || 0) / 700)) : 2.2)"
                              style:
                                opacity: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state && Math.abs(Number.parseFloat(items[props.batteryPowerItem].state)) > 10) ? 0.7 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    begin: -0.65s
                                    dur: "=(items[props.batteryPowerItem] && items[props.batteryPowerItem].state ? Math.max(0.6, Math.min(1.95, 1.7 - (Math.abs(Number.parseFloat(items[props.batteryPowerItem].state) || 0) / 2200))) : 1.5)"
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "=(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) ? '#f87171' : '#4ade80')"
                              r: =(Math.max(3, Math.min(7.5, 3 + (Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) / 550))))
                              style:
                                opacity: "=(Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) > 1) ? 1 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    dur: =(Math.max(0.5, Math.min(2.0, 1.5 - (Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) / 1800))))
                                    path: "=(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0) > Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0) ? 'M 512 65 Q 390 100 325 107' : 'M 325 107 Q 390 100 512 65')"
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              r: =(Math.max(2.2, Math.min(5.5, 2.5 + (Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) / 700))))
                              style:
                                opacity: "=(Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) > 1) ? 0.7 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    begin: -0.6s
                                    dur: =(Math.max(0.55, Math.min(1.8, 1.35 - (Math.max(Number.parseFloat((items[props.gridImportItem] && items[props.gridImportItem].state) || 0), Number.parseFloat((items[props.gridExportItem] && items[props.gridExportItem].state) || 0)) / 2000))))
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#60A5FA"
                              r: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state ? Math.max(2.5, Math.min(6.5, 2.8 + ((Number.parseFloat(items[props.waterUsageLhItem].state) || 0) / 25))) : 2.5)"
                              style:
                                opacity: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state && Number.parseFloat(items[props.waterUsageLhItem].state) > 0) ? 1 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    dur: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state ? Math.max(0.7, Math.min(2.3, 1.9 - ((Number.parseFloat(items[props.waterUsageLhItem].state) || 0) / 60))) : 1.8)"
                                    path: M 317 255 Q 317 195 317 148
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#60A5FA"
                              r: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state ? Math.max(2, Math.min(4, 2.2 + ((Number.parseFloat(items[props.waterUsageLhItem].state) || 0) / 30))) : 2)"
                              style:
                                opacity: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state && Number.parseFloat(items[props.waterUsageLhItem].state) > 0) ? 0.7 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    begin: -0.6s
                                    dur: "=(items[props.waterUsageLhItem] && items[props.waterUsageLhItem].state ? Math.max(0.6, Math.min(1.8, 1.5 - ((Number.parseFloat(items[props.waterUsageLhItem].state) || 0) / 70))) : 1.4)"
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#4ADE80"
                              r: "=(items[props.evPowerItem] && items[props.evPowerItem].state ? Math.max(3, Math.min(7.5, 3 + ((Number.parseFloat(items[props.evPowerItem].state) || 0) / 600))) : 3)"
                              style:
                                opacity: "=(items[props.evPowerItem] && items[props.evPowerItem].state && Number.parseFloat(items[props.evPowerItem].state) > 30) ? 1 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    dur: "=(items[props.evPowerItem] && items[props.evPowerItem].state ? Math.max(0.55, Math.min(2.0, 1.7 - ((Number.parseFloat(items[props.evPowerItem].state) || 0) / 2000))) : 1.6)"
                                    path: M 325 123 Q 390 125 512 165
                                    tag: animateMotion
                          - component: f7-row
                              cx: "0"
                              cy: "0"
                              fill: "#4ADE80"
                              r: "=(items[props.evPowerItem] && items[props.evPowerItem].state ? Math.max(2.2, Math.min(5.5, 2.5 + ((Number.parseFloat(items[props.evPowerItem].state) || 0) / 750))) : 2.2)"
                              style:
                                opacity: "=(items[props.evPowerItem] && items[props.evPowerItem].state && Number.parseFloat(items[props.evPowerItem].state) > 30) ? 0.7 : 0"
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    begin: -0.65s
                                    dur: "=(items[props.evPowerItem] && items[props.evPowerItem].state ? Math.max(0.6, Math.min(1.8, 1.55 - ((Number.parseFloat(items[props.evPowerItem].state) || 0) / 2100))) : 1.45)"
                                    tag: animateMotion
                          - component: f7-row
                              cx: "108"
                              cy: "65"
                              fill: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? '#713F12' : '#1e293b'"
                              r: "32"
                              stroke: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? '#EAB308' : '#93c5fd'"
                              stroke-width: "3"
                              tag: circle
                          - component: f7-row
                              fill: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? '#EAB308' : '#93c5fd'"
                              font-size: "30"
                              font-weight: "700"
                              innerHTML: "=(items[props.solarPowerItem] && Number.parseFloat(items[props.solarPowerItem].state || 0) > 1) ? '☀️' : '🌙'"
                              tag: text
                              text-anchor: middle
                              x: "108"
                              y: "73"
                          - component: f7-row
                              cx: "108"
                              cy: "165"
                              fill: "=(Number.parseFloat((items[props.batteryPercentItem] && items[props.batteryPercentItem].state) || 0) >= 20) ? '#134E4A' : ((Number.parseFloat((items[props.batteryPercentItem] && items[props.batteryPercentItem].state) || 0) >= 10) ? '#78350F' : '#7F1D1D')"
                              r: "32"
                              stroke: "=(Number.parseFloat((items[props.batteryPercentItem] && items[props.batteryPercentItem].state) || 0) >= 20) ? '#2DD4BF' : ((Number.parseFloat((items[props.batteryPercentItem] && items[props.batteryPercentItem].state) || 0) >= 10) ? '#F59E0B' : '#EF4444')"
                              stroke-width: "3"
                              tag: circle
                          - component: f7-row
                              fill: "#ffffff"
                              font-size: "30"
                              font-weight: "700"
                              innerHTML: 🔋
                              tag: text
                              text-anchor: middle
                              x: "108"
                              y: "173"
                          - component: f7-row
                              cx: "317"
                              cy: "115"
                              fill: none
                              opacity: "=(items[props.homePeakTodayItem] && Number.parseFloat(items[props.homePeakTodayItem].state || 0) > 1) ? 0.75 : 0"
                              r: =(48 + 24 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePeakTodayItem] && items[props.homePeakTodayItem].state) || 0) / 9000)))
                              stroke: "#F97316"
                              stroke-width: "1.5"
                              tag: circle
                          - component: f7-row
                              cx: "317"
                              cy: "115"
                              fill: "=(Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) < 1500) ? '#22C55E' : ((Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) < 3000) ? '#84CC16' : ((Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) < 4500) ? '#EAB308' : ((Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) < 6000) ? '#F59E0B' : ((Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) < 7500) ? '#F97316' : ((Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) < 8500) ? '#F43F5E' : '#EF4444')))))"
                              opacity: "0.16"
                              r: =(48 + 24 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000)))
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    attributeName: opacity
                                    calcMode: spline
                                    dur: =(2.6 - 1.4 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))) + 's'
                                    keySplines: 0.4 0 0.2 1; 0.4 0 0.2 1
                                    keyTimes: 0;0.5;1
                                    tag: animate
                                    values: 0.08;0.30;0.08
                                - component: f7-row
                                    attributeName: r
                                    calcMode: spline
                                    keyTimes: 0;0.5;1
                                    tag: animate
                                    values: =(Math.round(48 + 24 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))) + ';' + Math.round(54 + 32 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))) + ';' + Math.round(48 + 24 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))))
                          - component: f7-row
                              cx: "317"
                              cy: "115"
                              opacity: "0.22"
                              r: =(44 + 16 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000)))
                              tag: circle
                            slots:
                              default:
                                - component: f7-row
                                    begin: -0.35s
                                    calcMode: spline
                                    keyTimes: 0;0.5;1
                                    tag: animate
                                    values: 0.12;0.38;0.12
                                - component: f7-row
                                    attributeName: r
                                    begin: -0.35s
                                    calcMode: spline
                                    keyTimes: 0;0.5;1
                                    tag: animate
                                    values: =(Math.round(44 + 16 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))) + ';' + Math.round(48 + 22 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))) + ';' + Math.round(44 + 16 * Math.min(1, Math.max(0, Number.parseFloat((items[props.homePowerItem] && items[props.homePowerItem].state) || 0) / 9000))))
                          - component: f7-row
                              cx: "317"
                              cy: "115"
                              fill: "#ee9bed"
                              r: "40"
                              stroke: "#d243d2"
                              stroke-width: "3.5"
                              tag: circle
                          - component: f7-row
                              fill: "#ffffff"
                              font-size: "40"
                              font-weight: "700"
                              innerHTML: 🏠
                              tag: text
                              text-anchor: middle
                              x: "317"
                              y: "123"
                          - component: f7-row
                              cx: "512"
                              cy: "65"
                              fill: "#1E3A5F"
                              r: "32"
                              stroke: "#60A5FA"
                              stroke-width: "3"
                              tag: circle
                          - component: f7-row
                              fill: "#ffffff"
                              font-size: "30"
                              font-weight: "700"
                              innerHTML: ⚡
                              tag: text
                              text-anchor: middle
                              x: "512"
                              y: "72"
                          - component: f7-row
                              cx: "512"
                              cy: "165"
                              fill: "#4ADE80"
                              opacity: "=(items[props.evPowerItem] && Number.parseFloat(items[props.evPowerItem].state || 0) > 1) ? (0.16 + 0.16 * Math.min(1, Number.parseFloat(items[props.evPowerItem].state || 0) / 7000)) : 0"
                              r: "=(items[props.evPowerItem] && Number.parseFloat(items[props.evPowerItem].state || 0) > 1) ? (38 + 16 * Math.min(1, Number.parseFloat(items[props.evPowerItem].state || 0) / 7000)) : 32"
                              tag: circle
                          - component: f7-row
                              cx: "512"
                              cy: "165"
                              fill: "#14532D"
                              r: "32"
                              stroke: "#4ADE80"
                              stroke-width: "3"
                              tag: circle
                          - component: f7-row
                              fill: "#ffffff"
                              font-size: "30"
                              font-weight: "700"
                              innerHTML: 🚗
                              tag: text
                              text-anchor: middle
                              x: "512"
                              y: "172"
                          - component: f7-row
                              cx: "317"
                              cy: "255"
                              fill: "#1E3A8A"
                              r: "32"
                              stroke: "#60A5FA"
                              stroke-width: "3"
                              tag: circle
                          - component: f7-row
                              fill: "#ffffff"
                              font-size: "30"
                              font-weight: "700"
                              innerHTML: 💧
                              tag: text
                              text-anchor: middle
                              x: "317"
                              y: "263"
                  style:
                    borderRadius: 14px
                    marginTop: 12px
                    padding: 12px 8px
                slots:
                  default:
                    - component: f7-row
                        style:
                          alignItems: stretch
                        visible: =device.desktop
                      slots:
                        default:
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "25"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#FACC15"
                                      fontSize: 20px
                                      fontWeight: "700"
                                    text: "=(items[props.solarTodayKwhItem] && Number.parseFloat(items[props.solarTodayKwhItem].state) == Number.parseFloat(items[props.solarTodayKwhItem].state)) ? Number.parseFloat(items[props.solarTodayKwhItem].state).toFixed(1) + ' kWh' : '—'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: PV TODAY
                          - component: f7-col
                              style:
                                borderLeft: "1px solid #3f3f46"
                                textAlign: center
                              width: "25"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#f6b7f6"
                                      fontSize: 20px
                                      fontWeight: "700"
                                    text: "=(items[props.homeTodayKwhItem] && Number.parseFloat(items[props.homeTodayKwhItem].state) == Number.parseFloat(items[props.homeTodayKwhItem].state)) ? Number.parseFloat(items[props.homeTodayKwhItem].state).toFixed(1) + ' kWh' : '0.0 kWh'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: HOME TODAY
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "25"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#f87171"
                                      fontSize: 20px
                                      fontWeight: "700"
                                    text: "=(items[props.gridImportTodayKwhItem] && Number.parseFloat(items[props.gridImportTodayKwhItem].state) == Number.parseFloat(items[props.gridImportTodayKwhItem].state)) ? Number.parseFloat(items[props.gridImportTodayKwhItem].state).toFixed(1) + ' kWh' : '—'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: GRID TODAY
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "25"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#fdba74"
                                      fontSize: 20px
                                      fontWeight: "700"
                                    text: "=(items[props.oilPriceItem] && items[props.oilPriceItem].state && items[props.oilPriceItem].state != 'NULL' && items[props.oilPriceItem].state != 'UNDEF') ? ('🔥 ' + (items[props.oilPriceItem].displayState || items[props.oilPriceItem].state)) : '🔥 —'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: MAZOUT
                    - component: f7-row
                        style:
                          alignItems: stretch
                        visible: =!device.desktop
                      slots:
                        default:
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "50"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#FACC15"
                                      fontSize: 18px
                                      fontWeight: "700"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: PV TODAY
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "50"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#ee9bed"
                                      fontSize: 18px
                                      fontWeight: "700"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: HOME TODAY
                    - component: f7-row
                        style:
                          alignItems: stretch
                          marginTop: 8px
                      slots:
                        default:
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "50"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#f87171"
                                      fontSize: 18px
                                      fontWeight: "700"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: GRID TODAY
                          - component: f7-col
                              style:
                                textAlign: center
                              width: "50"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#fdba74"
                                      fontSize: 18px
                                      fontWeight: "700"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: MAZOUT
                  style:
                    borderRadius: 14px
                    marginTop: 12px
                    padding: 14px 12px
                slots:
                  default:
                    - component: f7-row
                        style:
                          alignItems: center
                      slots:
                        default:
                          - component: f7-col
                              small: "25"
                              style:
                                alignItems: center
                                display: flex
                                gap: 10px
                                justifyContent: center
                                marginBottom: 8px
                              width: "100"
                            slots:
                              default:
                                    innerHTML: 🔋
                                  slots:
                                    default:
                                      - component: Label
                                          style:
                                            color: "#e4e4e7"
                                            fontSize: 14px
                                            fontWeight: "700"
                                          text: BATTERY
                                      - component: Label
                                          style:
                                            color: "#a1a1aa"
                                            fontSize: 10px
                                          text: STATUS
                          - component: f7-col
                              small: "25"
                              style:
                                textAlign: center
                              width: "33"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#14B8A6"
                                      fontSize: 22px
                                      fontWeight: "700"
                                    text: "=(items[props.batteryPercentItem] && items[props.batteryPercentItem].state) ? Number(items[props.batteryPercentItem].state).toFixed(0) + ' %' : '—'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 11px
                                    text: SOC
                          - component: f7-col
                              small: "25"
                              style:
                                textAlign: center
                              width: "33"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#14B8A6"
                                      fontSize: 22px
                                      fontWeight: "700"
                                    text: "=(items[props.batteryChargeRateItem] && items[props.batteryChargeRateItem].state) ? Number(items[props.batteryChargeRateItem].state).toFixed(0) + ' %' : '—'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 11px
                                    text: Charge Rate
                          - component: f7-col
                              small: "25"
                              style:
                                textAlign: center
                              width: "33"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#14B8A6"
                                      fontSize: 22px
                                      fontWeight: "700"
                                    text: "=(items[props.batteryDischargeRateItem] && items[props.batteryDischargeRateItem].state) ? Number(items[props.batteryDischargeRateItem].state).toFixed(0) + ' %' : '—'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 11px
                                    text: Discharge Rate
                  style:
                    borderRadius: 14px
                    marginTop: 12px
                    padding: 14px 12px
                slots:
                  default:
                    - component: f7-row
                        style:
                          alignItems: center
                      slots:
                        default:
                          - component: f7-col
                              small: "25"
                              style:
                                alignItems: center
                                display: flex
                                gap: 10px
                                marginBottom: 8px
                              width: "100"
                            slots:
                              default:
                                    f7: car_fill
                                    style:
                                      color: "=(items[props.evConnectedItem] && (items[props.evConnectedItem].state == 'ON' || items[props.evConnectedItem].state == 'true' || items[props.evConnectedItem].state == 'OPEN' || Number.parseFloat(items[props.evConnectedItem].state || 0) > 0)) ? '#22C55E' : '#f87171'"
                                  slots:
                                    default:
                                      - component: Label
                                          style:
                                            color: "#e4e4e7"
                                            fontSize: 14px
                                            fontWeight: "700"
                                          text: MEGATRON
                                      - component: Label
                                          style:
                                            color: "#a1a1aa"
                                            fontSize: 10px
                                          text: STATUS
                          - component: f7-col
                              small: "25"
                              style:
                                textAlign: center
                              width: "33"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#4ade80"
                                      fontSize: 22px
                                      fontWeight: "700"
                                    text: "=(items[props.EVBatteryPercentItem] && items[props.EVBatteryPercentItem].state) ? Number(items[props.EVBatteryPercentItem].state).toFixed(0) + ' %' : '—'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 11px
                                    text: SOC
                          - component: f7-col
                              small: "25"
                              style:
                                textAlign: center
                              width: "33"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#4ade80"
                                      fontSize: 22px
                                      fontWeight: "700"
                                    text: "=(items[props.evPowerItem] && items[props.evPowerItem].state ? Number.parseFloat(items[props.evPowerItem].state).toFixed(0) : '0') + ' W'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 11px
                                    text: POWER
                          - component: f7-col
                              small: "25"
                              style:
                                textAlign: center
                              width: "33"
                            slots:
                              default:
                                - component: Label
                                    style:
                                      color: "#22C55E"
                                      fontSize: 20px
                                      fontWeight: "700"
                                    text: "=(items[props.evChargeKwhItem] && items[props.evChargeKwhItem].state) ? Number.parseFloat(items[props.evChargeKwhItem].state).toFixed(1) + ' Wh' : '0 kWh'"
                                - component: Label
                                    style:
                                      color: "#a1a1aa"
                                      fontSize: 10px
                                    text: CHARGE
