I’ve just uploaded a (hopefully) final version with some fixes related to a wrong rounding of a certain values which get divisioned by 10.
Would be great if you could somehow catch which of the raw values is the “feed in” power, i.e. the power that comes from the electricity provider. In my opinion that’s a very important counter for any automations you may want to implement. (probably you want to reduce low priority consumers if feed in power is too high for example)
If you have the time and you’re willing to do that… could be worth checking it on the cloud site if you have access to it (if not, probably you can ask your installer for one). What you need to do is to ensure relatively constant consumption from the feed in power (maybe at night when there is no production from PVs) and cross-check it with the unassigned values from the array. (could be tricky because the negative values appear as very big integers because the most major bit is set to 1, which means that if you pull from the network, probably the value should be something above the value of 32768.
That could be a hint I guess and I hope I’m right about that
@nobbi123 Yesterday the cloud connector support was merged and due to the big refactoring I have some doubts about the X1 mini support if I merged everything right.
I wonder if you could have a look and retest the binding on your system when you have the time?
Here is the latest release: Release X1 mini support on top of the merged cloud connector support · theater/openhab-addons · GitHub
If you don’t find any issues, I will create a PR for your inverter and hopefully once it’s merged the full backlog will be cleared.
I just saw that the three new PRs are included in 4.2 first milestone build so yes - you can have it with 4.2 official release (or any of the milestones).
Hi all.
I’m getting my new X3 Hybrid G4 installed tomorrow. I’m using wired connection, so the installer is installing a lan module (which I hope is compatible, it should work the same as a wifi module, right?). Is there anything speciel I need to check with regards to the version when the installation is made? It sounded to me like the electrician has a bunch of Solax lan modules lying around, is there any risk that the module installed here has an old version that is not fully compatible?
Hi Daniel,
I’m afraid that it has never been tested with lan module. We can only hope they follow the same protocol (would be nonsense if not). I would recommend to use latest possible FW. If lan modules follow the wifi modules version naming convention, it should be 3.x
Thanks! I’ll report back tomorrow and then hopefully you can add the lan module as supported
btw, I suspect the version numbering on the lan modules doesn’t match the one on the wifi-only modules, just noticed the compatibility list here. I’ll report back on that as well
