Hi guys,
I´m trying to connect Solax Hybrid inverter locally via Modbus on Port 502. I´m able to read values in RealtimeData with no problem.
Problem is, that I´m unable to write data for example from item solax_WorkingMODE
I don´t know, if the problem is in connection or in transformation. If you gave me some example, I would finish it and give tutorial for others.
Thanks in advance
It gives me error:
2022-07-06 12:44:36.558 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:localhostTCP:holdingRegisters:WorkingMode 'Modbus Data' had ModbusSlaveIOExceptionImpl error on write: ModbusSlaveIOException(cause=ModbusIOException, EOF=false, message='I/O exception: EOFException null', cause2=null)
2022-07-06 12:44:36.562 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'modbus:data:localhostTCP:holdingRegisters:WorkingMode' changed from OFFLINE (COMMUNICATION_ERROR): Error (ModbusSlaveIOExceptionImpl) with write. Request: ModbusWriteRegisterRequestBlueprint [slaveId=2, reference=31, registers=ModbusRegisterArray(0001), maxTries=3, getFunctionCode()=WRITE_SINGLE_REGISTER]. Description: ModbusSlaveIOException(cause=ModbusIOException, EOF=false, message='I/O exception: EOFException null', cause2=null). Message: Modbus IO Error with cause=ModbusIOException, EOF=false, message='I/O exception: EOFException null', cause2=null to OFFLINE (COMMUNICATION_ERROR): Error (ModbusSlaveIOExceptionImpl) with write. Request: ModbusWriteRegisterRequestBlueprint [slaveId=2, reference=31, registers=ModbusRegisterArray(0003), maxTries=3, getFunctionCode()=WRITE_SINGLE_REGISTER]. Description: ModbusSlaveIOException(cause=ModbusIOException, EOF=false, message='I/O exception: EOFException null', cause2=null). Message: Modbus IO Error with cause=ModbusIOException, EOF=false, message='I/O exception: EOFException null', cause2=null
I have found mapping in Solax Modbus Documentation here: Solax Modbus RTU documentation
This is my Test Thing with working reading data from input registers
Bridge modbus:tcp:localhostTCP [ host="192.168.0.7", port=502, id=2 ] {
Bridge poller inputRegisters [ start=0, length=99, refresh=10000, type="input" ] {
Thing data NetworkVoltage [ readStart="0" , readValueType="int16", readTransform="JS(divide_by_10.js)"]
Thing data OutputCurrent [ readStart="1", readValueType="int16", readTransform="JS(divide_by_10.js)" ]
Thing data ACPower [ readStart="2", readValueType="int16" ]
Thing data PV1Voltage [ readStart="3", readValueType="int16", readTransform="JS(divide_by_10.js)" ]
Thing data PV2Voltage [ readStart="4", readValueType="int16", readTransform="JS(divide_by_10.js)" ]
Thing data PV1Current [ readStart="5", readValueType="int16", readTransform="JS(divide_by_10.js)" ]
Thing data PV2Current [ readStart="6", readValueType="int16", readTransform="JS(divide_by_10.js)" ]
Thing data DailyYield [ readStart="80", readValueType="int16", readTransform="JS(divide_by_10.js)"]
Thing data BatteryTemp [ readStart="27", readValueType="int16" ]
Thing data BatterySOC [ readStart="28", readValueType="int16" ]
Bridge poller holdingRegisters [ start=100, length=99, refresh=10000, type="holding" ] {
Thing data WorkingMode [ readStart="139", readValueType="uint16", writeStart="31", writeValueType="uint16", writeType="holding", writeTransform="default"]
Here is my items file
Number ACPower "Výkon dodávaný do sítě [%.2f W]" { channel="modbus:data:localhostTCP:inputRegisters:ACPower:number" }
Number NetworkVoltage "Napětí v síti [%.2f V]" { channel="modbus:data:localhostTCP:inputRegisters:NetworkVoltage:number" }
Number OutputCurrent "Výstupní proud měniče [%.2f A]" { channel="modbus:data:localhostTCP:inputRegisters:OutputCurrent:number" }
Number PV1Voltage "Napětí panelů PV1 [%.2f V]" { channel="modbus:data:localhostTCP:inputRegisters:PV1Voltage:number" }
Number PV2Voltage "Napětí panelů PV2 [%.2f V]" { channel="modbus:data:localhostTCP:inputRegisters:PV2Voltage:number" }
Number PV1Current "Proud panelů PV1 [%.2f A]" { channel="modbus:data:localhostTCP:inputRegisters:PV1Current:number" }
Number PV2Current "Proud panelů PV2 [%.2f A]" { channel="modbus:data:localhostTCP:inputRegisters:PV2Current:number" }
Number Solax_DailyYield "Výroba dnes [%.2f kWh]" { channel="modbus:data:localhostTCP:inputRegisters:DailyYield:number" }
Number solax_WorkingMODE "Working Mode" { channel="modbus:data:localhostTCP:holdingRegisters:WorkingMode:number" }
Number Solax_BatteryTemp "Teplota baterie [%.0f °C]" { channel="modbus:data:localhostTCP:inputRegisters:BatteryTemp:number" }
Number Solax_BatterySOC "Nabití baterie [%.0f%%]" { channel="modbus:data:localhostTCP:inputRegisters:BatterySOC:number" }
Number Input1503Float32 "Input registers 1500-1501 as float32 [%.0f]" { channel="modbus:data:localhostTCP:inputRegisters:input1503:number" }
