Solax X3 gen4 modbus read data
Hi is here anybody who is using this config in openhab?
I have a problem with reading data from Solax X3 gen4 8kw.
In the log is error about modbus but Im not able to identify what is wrong.
Send a log…
Blockquote2023-03-05 20:44:53.110 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_INPUT_REGISTERS, start=0, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 82c8f400-5224-4780-8e75-844e1d1b72db]
2023-03-05 20:44:56.281 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=200, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 19f5beb7-97fe-4423-81ee-22b3f1307a79]
2023-03-05 20:44:59.451 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_INPUT_REGISTERS, start=0, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 82c8f400-5224-4780-8e75-844e1d1b72db]
2023-03-05 20:45:02.625 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_INPUT_REGISTERS, start=100, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 3b82d9c6-3818-4a03-a19e-8def27d3b090]
2023-03-05 20:45:05.800 [ERROR] [rt.modbus.internal.ModbusManagerImpl] - Last try 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=200, length=99, maxTries=3]). Aborting. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 19f5beb7-97fe-4423-81ee-22b3f1307a79]
2023-03-05 20:45:08.970 [ERROR] [rt.modbus.internal.ModbusManagerImpl] - Last try 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_INPUT_REGISTERS, start=0, length=99, maxTries=3]). Aborting. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 82c8f400-5224-4780-8e75-844e1d1b72db]
2023-03-05 20:45:12.143 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=100, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 0761b32e-28aa-4989-b789-5eee22948b2c]
2023-03-05 20:45:15.316 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_INPUT_REGISTERS, start=100, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 3b82d9c6-3818-4a03-a19e-8def27d3b090]
2023-03-05 20:45:18.488 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=200, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID f723a8cd-6f94-4784-8848-063ef1f03d9a]
2023-03-05 20:45:21.659 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=100, length=99, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 0761b32e-28aa-4989-b789-5eee22948b2c]
2023-03-05 20:45:24.834 [ERROR] [rt.modbus.internal.ModbusManagerImpl] - Last try 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_INPUT_REGISTERS, start=100, length=99, maxTries=3]). Aborting. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 3b82d9c6-3818-4a03-a19e-8def27d3b090]
if you have correct ip and port, it is probably blocked by Solax Cloud. Try disconnect internet and restart Modbus binding
If I try to telnet on this IP and port it’s opened. I have also serial to RS485 at home. Do you know how to change config to this connection?
Thanks for help.
I’ve check firmware of the inverter and its 1.13 which is one year old and I have pocket wifi module 2.0. Is it working with this wifi module?
Thanks.
