michi
(Michael Geramb)
December 19, 2017, 7:55pm
1
UPDATE: Setup work now with Java SE 9 SDK. See postings below.
Hello developers,
I have tried to start a development for a new binding. But currently I have a problem with the IDE setup on my mac book.
Platform information:
Hardware: CPUArchitecture/RAM/storage
OS: macOS High Sierra 10.13.2
Java Runtime Environment: java version "1.8.0_151"
Java™ SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot™ 64-Bit Server VM (build 25.151-b12, mixed mode)
openHAB version: 2.2
Issue of the topic:
If followed the instruction on https://docs.openhab.org/developers/development/ide.html and it seems that every thing goes ok. org.openhab.core.karaf fails to compile, but I think this is an known bug and I have closed the project.
But if I launch the project, something seems to block. For example it is not possible to open the dashboard most of the tries. The browser hangs in the call. I have tried the setup procedure several time and a got always an other result. Sometime, I saw the start-page in the web browser but nothing more. Sometime I saw that open hab executes the sample rules, sometimes not. But I have newer seen the initialize message of the yahoo wheater binding described in the sample.
So I have tried the same procedure in windows and there it works and I can debug bindings, but the machine is very old and slow and so I want use my mac.
I have tried also the eclipse smarthome https://www.eclipse.org/smarthome/documentation/development/ide.html . This work well on my mac, I have no idea whats the problem with the openhab.
Kind regards,
Michael
michi
(Michael Geramb)
December 19, 2017, 7:56pm
2
2017-12-19 20:51:28.790 [DEBUG] [.s.r.i.SitemapRuntimeActivator:26 ] - Registered ‘sitemap’ configuration parser
2017-12-19 20:51:28.841 [DEBUG] [s.m.i.r.i.ItemRuntimeActivator:26 ] - Registered ‘item’ configuration parser
2017-12-19 20:51:28.891 [DEBUG] [.i.PersistenceRuntimeActivator:26 ] - Registered ‘persistence’ configuration parser
2017-12-19 20:51:28.917 [INFO ] [org.eclipse.jetty.util.log :192 ] - Logging initialized @2032ms
2017-12-19 20:51:28.924 [INFO ] [.DefaultJettyAtJettyHomeHelper:159 ] - Configuring the default jetty server with [file:/Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/./etc/jetty.xml, file:/Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/./etc/jetty-http.xml, file:/Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/./etc/jetty-deployer.xml]
2017-12-19 20:51:28.925 [INFO ] [.DefaultJettyAtJettyHomeHelper:164 ] - JETTY.HOME=/Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/.
2017-12-19 20:51:28.925 [INFO ] [.DefaultJettyAtJettyHomeHelper:165 ] - JETTY.BASE=/Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/.
2017-12-19 20:51:29.087 [INFO ] [rg.eclipse.jetty.server.Server:346 ] - jetty-9.3.22.v20171030
2017-12-19 20:51:29.149 [INFO ] [tty.util.ssl.SslContextFactory:290 ] - x509=X509@9e84b27(mykey,h=[openhab.org ],w=[]) for SslContextFactory@240ba319(file:///Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/etc/keystore,file:///Users/mgeramb/openhab2-master2/git/openhab-distro/launch/home/etc/keystore)
2017-12-19 20:51:29.290 [INFO ] [jetty.server.AbstractConnector:278 ] - Started 0.0.0.0:8443@3e00ddbd{SSL,[ssl, http/1.1]}{0.0.0.0:8443}
2017-12-19 20:51:29.291 [INFO ] [jetty.server.AbstractConnector:278 ] - Started ServerConnector@3fd3f639{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
2017-12-19 20:51:29.291 [INFO ] [rg.eclipse.jetty.server.Server:414 ] - Started @2407ms
2017-12-19 20:51:29.292 [INFO ] [.DefaultJettyAtJettyHomeHelper:185 ] - Default jetty server configured
2017-12-19 20:51:29.337 [DEBUG] [.m.t.r.i.ThingRuntimeActivator:26 ] - Registered ‘thing’ configuration parser
2017-12-19 20:51:29.457 [DEBUG] [s.ui.icon.internal.IconServlet:81 ] - Starting up icon servlet at /icon
2017-12-19 20:51:29.474 [INFO ] [.server.handler.ContextHandler:781 ] - Started o.e.j.s.ServletContextHandler@6480baae{/,null,AVAILABLE}
2017-12-19 20:51:29.499 [INFO ] [.u.d.internal.DashboardService:62 ] - Started dashboard at http://10.0.0.3:8080
2017-12-19 20:51:29.500 [INFO ] [.u.d.internal.DashboardService:66 ] - Started dashboard at https://10.0.0.3:8443
2017-12-19 20:51:29.568 [DEBUG] [io.rest.internal.RESTActivator:77 ] - REST API has been started.
2017-12-19 20:51:29.680 [DEBUG] [.s.core.internal.CoreActivator:37 ] - Core bundle has been started.
2017-12-19 20:51:29.729 [DEBUG] [.e.s.c.i.i18n.I18nProviderImpl:169 ] - No time zone set, falling back to the default time zone ‘Europe/Vienna’.
2017-12-19 20:51:29.729 [DEBUG] [.e.s.c.i.i18n.I18nProviderImpl:112 ] - No language set, falling back to the default locale
2017-12-19 20:51:29.805 [DEBUG] [.s.ExpressionThreadPoolManager:68 ] - Created an expression-drive scheduled thread pool ‘persist’ of size 5
2017-12-19 20:51:29.820 [DEBUG] [.core.common.ThreadPoolManager:121 ] - Created scheduled thread pool ‘discovery’ of size 5
2017-12-19 20:51:30.033 [DEBUG] [.i.r.sse.internal.SseActivator:51 ] - SSE API - SseFeature registered.
2017-12-19 20:51:30.034 [DEBUG] [.i.r.sse.internal.SseActivator:60 ] - SSE API has been started.
2017-12-19 20:51:30.040 [DEBUG] [s.i.t.m.internal.MDNSActivator:34 ] - mDNS service has been started.
2017-12-19 20:51:30.066 [DEBUG] [.i.t.m.internal.MDNSClientImpl:83 ] - mDNS service has been started (JmDNS-IP-1 for IP 10.0.0.3)
2017-12-19 20:51:30.067 [DEBUG] [i.t.m.internal.MDNSServiceImpl:50 ] - Registering 2 queued services
2017-12-19 20:51:30.067 [DEBUG] [.i.t.m.internal.MDNSClientImpl:111 ] - Registering new service _openhab-server._tcp.local. at 10.0.0.3:8080 (JmDNS-IP-1)
2017-12-19 20:51:30.090 [DEBUG] [.core.common.ThreadPoolManager:121 ] - Created scheduled thread pool ‘xml-processing’ of size 5
2017-12-19 20:51:30.177 [DEBUG] [s.c.d.AbstractDiscoveryService:404 ] - Background discovery for discovery service ‘org.eclipse.smarthome.config.discovery.mdns.internal.MDNSDiscoveryService’ enabled.
2017-12-19 20:51:30.241 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.osgi
2017-12-19 20:51:30.241 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.automation.module.script.defaultscope
2017-12-19 20:51:30.241 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.equinox.common
2017-12-19 20:51:30.241 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.equinox.common
2017-12-19 20:51:30.241 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.osgi
2017-12-19 20:51:30.243 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.automation.module.script.defaultscope
2017-12-19 20:51:30.244 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.model.rule
2017-12-19 20:51:30.244 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.servlet
2017-12-19 20:51:30.243 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.model.rule.runtime
2017-12-19 20:51:30.244 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.websocket.client
2017-12-19 20:51:30.244 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.io.rest.mdns
2017-12-19 20:51:30.244 [DEBUG] [c.x.o.XmlDocumentBundleTracker:347 ] - Reading the XML document ‘/ESH-INF/config/config.xml’ in module ‘org.eclipse.smarthome.ui.classic’…
2017-12-19 20:51:30.244 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.ui.icon
2017-12-19 20:51:30.245 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.osgi.httpservice
2017-12-19 20:51:30.245 [DEBUG] [c.x.o.XmlDocumentBundleTracker:347 ] - Reading the XML document ‘/ESH-INF/config/config.xml’ in module ‘org.eclipse.smarthome.ui.basic’…
2017-12-19 20:51:30.245 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.http
2017-12-19 20:51:30.245 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.jetty.servlet
2017-12-19 20:51:30.245 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=javax.inject
2017-12-19 20:51:30.245 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.model.rule
2017-12-19 20:51:30.246 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.model.rule.runtime
2017-12-19 20:51:30.246 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.ui.classic
2017-12-19 20:51:30.246 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.io.rest.mdns
2017-12-19 20:51:30.246 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.equinox.ds
2017-12-19 20:51:30.246 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.xtext
2017-12-19 20:51:30.247 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.apache.commons.net
2017-12-19 20:51:30.247 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.apache.felix.scr
2017-12-19 20:51:30.247 [DEBUG] [c.x.o.XmlDocumentBundleTracker:347 ] - Reading the XML document ‘/ESH-INF/config/config.xml’ in module ‘org.eclipse.smarthome.core.audio’…
2017-12-19 20:51:30.247 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.io.monitor
2017-12-19 20:51:30.247 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.automation.module.script.rulesupport
2017-12-19 20:51:30.248 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.jetty.websocket.client
2017-12-19 20:51:30.248 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.equinox.util
2017-12-19 20:51:30.248 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.ui.iconset.classic
2017-12-19 20:51:30.248 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.io.console.eclipse
2017-12-19 20:51:30.249 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.config.xml
2017-12-19 20:51:30.249 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=ch.qos.logback.classic
2017-12-19 20:51:30.250 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.equinox.http.servlet
2017-12-19 20:51:30.250 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.transform.map
2017-12-19 20:51:30.250 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.californium.scandium
2017-12-19 20:51:30.250 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.io.rest
2017-12-19 20:51:30.251 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.webapp
2017-12-19 20:51:30.251 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.automation.providers
2017-12-19 20:51:30.251 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.equinox.registry
2017-12-19 20:51:30.251 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.model.sitemap.runtime
2017-12-19 20:51:30.252 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.openhab.ui.classicui
2017-12-19 20:51:30.252 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.model.script.runtime
2017-12-19 20:51:30.253 [DEBUG] [c.x.o.XmlDocumentBundleTracker:347 ] - Reading the XML document ‘/ESH-INF/config/i18n.xml’ in module ‘org.eclipse.smarthome.core’…
2017-12-19 20:51:30.258 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=com.eclipsesource.jaxrs.jersey-min
2017-12-19 20:51:30.259 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.openhab.core.compat1x
2017-12-19 20:51:30.259 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.apache.httpcomponents.httpcore
2017-12-19 20:51:30.260 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.client
2017-12-19 20:51:30.260 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.security
2017-12-19 20:51:30.261 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.deploy
2017-12-19 20:51:30.261 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.binding.hue
2017-12-19 20:51:30.262 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.ui.icon
2017-12-19 20:51:30.262 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.ui.classic
2017-12-19 20:51:30.262 [DEBUG] [c.x.o.XmlDocumentBundleTracker:347 ] - Reading the XML document ‘/ESH-INF/config/networkinterface.xml’ in module ‘org.eclipse.smarthome.core’…
2017-12-19 20:51:30.262 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.core.binding.xml
2017-12-19 20:51:30.262 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.ui.basic
2017-12-19 20:51:30.263 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.jetty.osgi.httpservice
2017-12-19 20:51:30.263 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.xtext.util
2017-12-19 20:51:30.263 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.core
2017-12-19 20:51:30.263 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.io.rest.sse
2017-12-19 20:51:30.264 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.ui.basic
2017-12-19 20:51:30.264 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.jetty.http
2017-12-19 20:51:30.264 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.xtext.common.types
2017-12-19 20:51:30.264 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.xtext
2017-12-19 20:51:30.264 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=javax.inject
2017-12-19 20:51:30.264 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.equinox.ds
2017-12-19 20:51:30.265 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.apache.commons.net
2017-12-19 20:51:30.265 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.apache.felix.scr
2017-12-19 20:51:30.265 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.core.audio
2017-12-19 20:51:30.265 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.objectweb.asm
2017-12-19 20:51:30.265 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.io.monitor
2017-12-19 20:51:30.266 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.automation.module.script.rulesupport
michi
(Michael Geramb)
December 19, 2017, 7:58pm
3
2017-12-19 20:51:30.717 [DEBUG] [.c.d.internal.ConfigDispatcher:319 ] - Processing config file 'services.cfg’
2017-12-19 20:51:30.759 [DEBUG] [.c.d.internal.ConfigDispatcher:319 ] - Processing config file 'basicui.cfg’
2017-12-19 20:51:30.762 [DEBUG] [.c.d.internal.ConfigDispatcher:319 ] - Processing config file 'classicui.cfg’
2017-12-19 20:51:30.764 [DEBUG] [.c.d.internal.ConfigDispatcher:319 ] - Processing config file 'logging.cfg’
2017-12-19 20:51:30.777 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.config.dispatch
2017-12-19 20:51:30.777 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.config.dispatch
2017-12-19 20:51:30.789 [DEBUG] [.c.c.registry.AbstractRegistry:296 ] - Provider ‘org.eclipse.smarthome.automation.internal.core.provider.ModuleTypeResourceBundleProvider’ has been added.
2017-12-19 20:51:30.801 [DEBUG] [.c.c.registry.AbstractRegistry:296 ] - Provider ‘org.eclipse.smarthome.automation.internal.core.provider.TemplateResourceBundleProvider’ has been added.
2017-12-19 20:51:30.802 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.automation.parser.gson
2017-12-19 20:51:30.803 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.automation.parser.gson
2017-12-19 20:51:30.806 [DEBUG] [o.e.s.c.s.i.SchedulerActivator:39 ] - Scheduler has been started.
2017-12-19 20:51:30.846 [DEBUG] [s.c.d.AbstractDiscoveryService:404 ] - Background discovery for discovery service ‘org.eclipse.smarthome.config.discovery.upnp.internal.UpnpDiscoveryService’ enabled.
2017-12-19 20:51:30.847 [INFO ] [uartz.impl.StdSchedulerFactory:1184 ] - Using default implementation for ThreadExecutor
2017-12-19 20:51:30.851 [DEBUG] [.core.common.ThreadPoolManager:121 ] - Created scheduled thread pool ‘upnp-io’ of size 5
2017-12-19 20:51:30.852 [DEBUG] [.e.s.i.t.u.i.UpnpIOServiceImpl:197 ] - Starting UPnP IO service…
2017-12-19 20:51:30.856 [DEBUG] [.core.common.ThreadPoolManager:86 ] - Updated scheduled thread pool ‘discovery’ to size 3
2017-12-19 20:51:30.857 [WARN ] [.core.common.ThreadPoolManager:94 ] - Ignoring invalid configuration for pool ‘safeCall’: 3,10 - value must be an integer
michi
(Michael Geramb)
4
2017-12-19 20:51:30.905 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
2017-12-19 20:51:30.905 [INFO ] [rg.quartz.core.QuartzScheduler:240 ] - Quartz Scheduler v.2.2.1 created.
2017-12-19 20:51:30.907 [INFO ] [org.quartz.simpl.RAMJobStore :155 ] - RAMJobStore initialized.
2017-12-19 20:51:30.908 [INFO ] [rg.quartz.core.QuartzScheduler:305 ] - Scheduler meta-data: Quartz Scheduler (v2.2.1) ‘openHAB-job-scheduler’ with instanceId 'NON_CLUSTERED’
Scheduler class: ‘org.quartz.core.QuartzScheduler’ - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool ‘org.quartz.simpl.SimpleThreadPool’ - with 2 threads.
Using job-store ‘org.quartz.simpl.RAMJobStore’ - which does not support persistence. and is not clustered.
2017-12-19 20:51:30.908 [INFO ] [uartz.impl.StdSchedulerFactory:1339 ] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: 'quartz.properties’
2017-12-19 20:51:30.908 [INFO ] [uartz.impl.StdSchedulerFactory:1343 ] - Quartz scheduler version: 2.2.1
2017-12-19 20:51:30.908 [INFO ] [rg.quartz.core.QuartzScheduler:575 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
2017-12-19 20:51:30.909 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.core.scheduler
2017-12-19 20:51:30.909 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.core.scheduler
2017-12-19 20:51:30.910 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.jetty.proxy
2017-12-19 20:51:30.910 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.jetty.proxy
2017-12-19 20:51:30.912 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=com.eclipsesource.jaxrs.provider.gson
2017-12-19 20:51:30.912 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=com.eclipsesource.jaxrs.provider.gson
2017-12-19 20:51:30.919 [DEBUG] [.c.c.registry.AbstractRegistry:296 ] - Provider ‘org.eclipse.smarthome.automation.module.media.internal.MediaActionTypeProvider’ has been added.
2017-12-19 20:51:30.926 [DEBUG] [e.s.a.core.internal.RuleEngine:256 ] - ModuleHandlerFactory added.
2017-12-19 20:51:30.929 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.automation.module.media
2017-12-19 20:51:30.929 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.automation.module.media
2017-12-19 20:51:30.955 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.io.rest.sitemap
2017-12-19 20:51:30.955 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.io.rest.sitemap
2017-12-19 20:51:30.955 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.xtext.smap
2017-12-19 20:51:30.955 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.xtext.smap
2017-12-19 20:51:30.958 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.smarthome.core.id
2017-12-19 20:51:30.958 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.smarthome.core.id
2017-12-19 20:51:31.027 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlConfig=org.eclipse.emf.ecore
2017-12-19 20:51:31.027 [DEBUG] [s.c.i.service.ReadyServiceImpl:54 ] - Added ready marker esh.xmlBindingInfo=org.eclipse.emf.ecore
2017-12-19 20:51:38.029 [DEBUG] [.i.t.m.internal.MDNSClientImpl:111 ] - Registering new service _openhab-server-ssl._tcp.local. at 10.0.0.3:8443 (JmDNS-IP-1)
2017-12-19 20:51:55.432 [INFO ] [.a.m.s.r.i.l.ScriptFileWatcher:162 ] - Loading script 'demo.js’
2017-12-19 20:51:55.910 [DEBUG] [.a.m.s.r.i.l.ScriptFileWatcher:170 ] - Script loaded: demo.js
2017-12-19 20:51:55.912 [DEBUG] [.core.common.ThreadPoolManager:151 ] - Created thread pool ‘safeCall’ with size 5
2017-12-19 20:51:55.913 [INFO ] [smarthome.event.RuleAddedEvent:52 ] - Rule ‘e8e011d6-4335-46f7-9c1b-8cd562946b3a’ has been added.
2017-12-19 20:51:55.914 [INFO ] [home.event.RuleStatusInfoEvent:52 ] - e8e011d6-4335-46f7-9c1b-8cd562946b3a updated: INITIALIZING
2017-12-19 20:51:55.914 [INFO ] [home.event.RuleStatusInfoEvent:52 ] - e8e011d6-4335-46f7-9c1b-8cd562946b3a updated: UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Missing handler ‘timer.GenericCronTrigger’ for module ‘aTimerTrigger’
lizzy
(Teemu Tikka)
December 29, 2017, 11:24am
5
Can confirm that I have the same problem with osx High Sierra. Tried to reinstall multiple times but it ends the same way always. No UI responds from the localhost:8080.
lizzy
(Teemu Tikka)
December 29, 2017, 11:50am
6
Ok, so I got it working by changing the JRE to use Java SE 9 instead of Java8 from the run configurations…
michi
(Michael Geramb)
December 31, 2017, 8:41am
7
Hi lizzy,
Thank’s for your posting, it works now with SE 9. Interesting, because I think SE9 is not yet offical supported by openhab.
Regards,
Michael
Kai
(Kai Kreuzer)
January 12, 2018, 5:41pm
8
This sounds weird. Many people use a Mac for openHAB development, including myself - and Java8 works like a charm (rather, openHAB distro does not work with Java9 correctly).
Kai
(Kai Kreuzer)
January 12, 2018, 5:46pm
9
Btw, please use the code fences when posting log files, it make the formatting so much better readable…
michi
(Michael Geramb)
January 12, 2018, 6:30pm
10
Hi Kai,
sorry for not using the code fences.
which version of Java 8 do you use? Have you tried already to load a complete fresh copy of the repository? I’am not sure what’s wrong, but I know that it does not work on my mac, I have done the installation 4 times, always with the same result. I have done it one time with windows using the exactly same version of Java and OpenHAB and it works, so I’am sure that I have done everything correct. Also with Java 9, I have it done in the same way, but this works. But if you give me your exact version which you are using, I will give them a new try.
Regards, Michael
zmartify
(Peter Kristensen)
January 25, 2018, 1:55pm
11
Hi Michael, did you find a solution with Java 1.8 - I’m struggling to get my IDE reinstalled. It used to run perfectly. But now it installs and everything seems working perfect - however I can’t access the OpenHAB runtime from my browser. localhost:8080 - it just hangs.
No errors in the log - it looks like everything is running ok.
macOs 10.13.2 / Eclipse IDE Oxygen / Java version 1.8
java version "1.8.0_162"
Java™ SE Runtime Environment (build 1.8.0_162-b12)
Java HotSpot™ 64-Bit Server VM (build 25.162-b12, mixed mode)
Any suggestions.
Best regards
Peter Kristensen
michi
(Michael Geramb)
January 25, 2018, 7:03pm
12
@zmartify :
Hi Peter, after the posting from @Kai , I make one more try. But no success. I use now Java 9, this works perfect for development for my binding. I do not know what’s the problem with the openHAB distro, but I do not need more.
May @Kai can make a try with a clean setup.
Regards,
Michael
zmartify
(Peter Kristensen)
January 26, 2018, 9:39am
13
Tryed with a complete fresh installation of my Mac, Java 1.8.0_162, Eclipse and OpenHAB - same problem. But I finally found a solution to the problem - in the run configuration, for unknown reasons the “target platform” on MacOs selects openhab.core version 2.2.0… instead of version 2.3.0…
When I changed that, everything runs smoothly - maybe @Kai can explain this?
Best regards,
Peter
Kai
(Kai Kreuzer)
January 26, 2018, 4:25pm
14
I have some good news for you and some bad for me: I can know reproduce the problem in my IDE - openHAB does not come up
No, I cannot (it should also work with the 2.2 from the target platform) and I also cannot reproduce it - even if I take the projects from the workspace, it does not help…
I’ll try to investigate.
zmartify
(Peter Kristensen)
January 26, 2018, 5:00pm
15
Hi Kai,
Agree - What I thought was a Solution only worked very temporary - but glad you Can reproduce it.
Best regards
Peter
sjka
(Simon Schultze-Florey)
January 26, 2018, 5:07pm
16
Looks a bit like https://bugs.java.com/bugdatabase/view_bug.do?bug_id=8019496 and adding
-Djava.awt.headless=true
should help.
Kai
(Kai Kreuzer)
January 26, 2018, 5:27pm
17
Thanks @sjka , that works for me (and this parameter should have always been there, I am not sure how and when it got lost…). I have created https://github.com/openhab/openhab-distro/pull/638 for it.
@zmartify Could you please check that this fixes the issue for you as well?
zmartify
(Peter Kristensen)
January 26, 2018, 8:59pm
18
Thanks all, that fixed it for me as well
