Heya
I’d need a sanity check here. I migrated from the 1.x mqtt binding to the 2.x one and I can’t seem to get the thing configuration right. I am all file based.
My thing is configure in a mqtt.thing file. There are other mqtt topics I subscribe on the same broker (mostly temp) and they work fine - so the general connectivity is ok.
My button is a xiaomi Mijia WXKG01LM
mosquitto-sub shows:
zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d000423b146/click', payload 'single'"}
zigbee2mqtt/0x00158d000423b146/click single
If you have a paperui mqtt broker, then you’ll need to get it’s definition name to put in the Garage_innen thing.
Then everything else of yours does look ok.
Thank you - for simplicity I left out the bridge in my post (which probably did confuse instead of keeping things simple)
I have added the bridge to complete the statement in the original post.
I did configure the bridge in a slightly different way . All tings are directly under the Bridge. But this should make no difference
