which is a 1.x binding.
The items I am using are these:
Number Ups_Output_Charge "Laddning i UPS [%.1f %%]" {networkupstools="ups1:battery.charge"}
String Ups_Status "UPS status [%s]" {networkupstools="ups1:ups.status"}
Number Ups_Output_Charge_warning "UPS nivå när varning ges [%.1f %%]" {networkupstools="ups1:battery.charge.warning"}
Can I add a location to this UPS somehow? I tried adding a Thing, but failed get the definition accepted, so either I just have not gotten the syntax right, I am confusing what is what, or it is just not possible to define a Thing for something that does not come from a 2.x binding..?
1.x bindings have a .cfg file (right when you click on the link you provided yourself). Usually that’s where stuff is specified that otherwise is specified as parameters to a thing for 2.x bindings.
Not sure what a “location” is in that context and what you want to achieve by adding it.
I am still figuring OH out so I just wanted to see if this was possible. Locations are only used in Paper UI as far as I can tell, so this is not a big issue.
Ah, that one. That’s just a string with no functionality attached.
(well except for in mapping Alexa skills, but I guess you don’t wanna shutdown your UPS using voice control ).
