Hey there,
I’m trying to add a switch case to my rule. But it does not trigger.
First i intialize a variabel called “Schritt” it gets the Value “1”. So if my Roomlight turns from OFF to ON the rule should be triggered. When “Schritt” equals 1 then also another light (blackboardlight) turns to ON. Independently of the second light there is also a projector that switches to ON.
So the proplem is that everything works except of the switch case function. That means the Trigger is regocnized and the Projecter is turned to ON. But nothing happens with the blackboardlight.
I guess i didn’t initialized “Schritt” correct. Well can anyone help me?
Here is my rule:
val int Schritt = 1
rule "Ablaufsteuerung"
Item MeinZuhause_Erdgeschoss_Buero_Licht_RaumlichtAnAus changed from OFF to ON
switch Schritt
case 1:
sendCommand(MeinZuhause_Erdgeschoss_Buero_Licht_TafellichtAnAus,OFF)
sendCommand(MeinZuhause_Erdgeschoss_Buero_Schalter_BeamerAnAus, ON)
