ChrisW
(Christian W)
January 30, 2020, 9:50am
1
Hi, finally did a upgrade of my docker openhab container to 2.5.1- debian.
It is wokring and in can’t see any errors in the Karaf console logging.
(I did uninstall Restdocs before doing the docker image change)
I’m pretty happy and thankful
But it looks like I’m missing some columns in the PaperUI > Add-ons Section
There are only: BINDINGS | MISC | VOICE
Any ideas?
Regards
Try clearing your browser cache. Chrome does not always work well without that.
ChrisW
(Christian W)
January 30, 2020, 10:36am
4
Did not help yet ? My Addons.cfg was empty, i should add - now it only has “package = standard”
10:03:36.106 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'package-simple' has been installed.
10:05:19.054 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'misc-mqttbroker' has been installed.
10:05:19.059 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-harmonyhub' has been installed.
10:05:19.064 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-mqtt' has been installed.
10:05:19.066 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'misc-market' has been installed.
10:05:19.069 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-openweathermap' has been installed.
10:05:19.077 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-unifi' has been installed.
10:05:19.079 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'misc-ruleengine' has been installed.
10:05:19.106 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'misc-hueemulation' has been installed.
10:05:19.129 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'ui-habpanel' has been installed.
10:05:19.131 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'ui-paper' has been installed.
10:05:19.140 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-zwave' has been installed.
10:26:54.871 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'misc-openhabcloud' has been installed.
11:26:02.597 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'package-standard' has been installed.
11:26:08.092 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'package-simple' has been uninstalled.
all my installed messages from the logs - after the update
ChrisW
(Christian W)
January 30, 2020, 10:39am
5
Did not help, also tried diffrent browser just to be sure.
ChrisW
(Christian W)
January 30, 2020, 10:48am
6
bundle.list gives this:
START LEVEL 100 , List Threshold: 50
ID ¦ State ¦ Lvl ¦ Version ¦ Name
19 ¦ Active ¦ 80 ¦ 5.3.1.201602281253 ¦ OSGi JAX-RS Connector
20 ¦ Active ¦ 80 ¦ 2.8.2.v20180104-1110 ¦ Gson: Google Json Library for Java
21 ¦ Active ¦ 80 ¦ 18.0.0 ¦ Guava: Google Core Libraries for Java
22 ¦ Active ¦ 80 ¦ 27.1.0.jre ¦ Guava: Google Core Libraries for Java
23 ¦ Active ¦ 80 ¦ 1.0.1 ¦ Guava InternalFutureFailureAccess and InternalFutures
24 ¦ Active ¦ 80 ¦ 3.0.0.v201312141243 ¦ Google Guice (No AOP)
25 ¦ Active ¦ 80 ¦ 4.8.35.v20190528-1517 ¦ ClassGraph
26 ¦ Active ¦ 80 ¦ 3.18.1.GA ¦ Javassist
29 ¦ Active ¦ 80 ¦ 3.5.5 ¦ JmDNS
31 ¦ Active ¦ 80 ¦ 1.0.0 ¦ Units of Measurement API
33 ¦ Active ¦ 80 ¦ 1.1.0.Final ¦ Bean Validation API
35 ¦ Active ¦ 80 ¦ 2.0.1 ¦ javax.ws.rs-api
36 ¦ Active ¦ 80 ¦ 2.9.2 ¦ Joda-Time
37 ¦ Active ¦ 80 ¦ 0.5.8 ¦ Jollyday
38 ¦ Active ¦ 80 ¦ 3.2.0.v201101311130 ¦ ANTLR Runtime
40 ¦ Active ¦ 80 ¦ 1.1 ¦ Commons Exec
41 ¦ Active ¦ 80 ¦ 2.2.0 ¦ Commons IO
42 ¦ Active ¦ 80 ¦ 2.6 ¦ Commons Lang
51 ¦ Active ¦ 80 ¦ 4.2.7 ¦ Apache Karaf :: OSGi Services :: Event
66 ¦ Active ¦ 80 ¦ 1.4.7.1 ¦ Apache ServiceMix :: Bundles :: xstream
69 ¦ Active ¦ 80 ¦ 4.14.0 ¦ Apache XBean OSGI Bundle Utilities
70 ¦ Active ¦ 80 ¦ 4.14.0 ¦ Apache XBean :: Classpath Resource Finder
71 ¦ Active ¦ 80 ¦ 2.12.0.v20160420-0247 ¦ EMF Common
72 ¦ Active ¦ 80 ¦ 2.12.0.v20160420-0247 ¦ EMF Ecore
73 ¦ Active ¦ 80 ¦ 2.11.0.v20160420-0247 ¦ EMF Change Model
74 ¦ Active ¦ 80 ¦ 2.12.0.v20160420-0247 ¦ EMF XML/XMI Persistence
75 ¦ Active ¦ 80 ¦ 3.10.400.v20190516-1504 ¦ Common Eclipse Runtime
104 ¦ Active ¦ 80 ¦ 0.8.0.v20190822-0801 ¦ org.eclipse.lsp4j
105 ¦ Active ¦ 80 ¦ 0.8.0.v20190822-0801 ¦ org.eclipse.lsp4j.jsonrpc
106 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0728 ¦ Xtend Runtime Library
107 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0728 ¦ Xtend Macro Interfaces
108 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0737 ¦ Xtext
109 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0952 ¦ Xtext Common Types
110 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0737 ¦ Xtext IDE Core
111 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0737 ¦ Xtext Utility
112 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0952 ¦ Xbase Model
113 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0952 ¦ Xbase Generic IDE Services
114 ¦ Active ¦ 80 ¦ 2.19.0.v20190902-0728 ¦ Xbase Runtime Library
129 ¦ Active ¦ 80 ¦ 1.9.6 ¦ MIME streaming extension
131 ¦ Active ¦ 80 ¦ 7.1.0 ¦ org.objectweb.asm.commons
132 ¦ Active ¦ 80 ¦ 7.1.0 ¦ org.objectweb.asm.tree
133 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Core
134 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Audio
135 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: OAuth2Client
136 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Binding XML
137 ¦ Active ¦ 90 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Boot
138 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration Core
139 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration Discovery
140 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration mDNS Discovery
141 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration Dispatcher
142 ¦ Active ¦ 75 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration XML
143 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Ephemeris
144 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: ID
145 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Console
146 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Console for OSGi runtime Karaf
147 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: HTTP Interface
149 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Monitor
150 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Network I/O
151 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: REST Interface
152 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Audio REST Interface
153 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: REST Interface :: Core
154 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: REST mDNS Announcer
155 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: REST JAX-RS Optimizations
156 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Sitemap REST Interface
157 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: SSE Interface
158 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Voice REST Interface
159 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: mDNS Service
160 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Karaf Integration
161 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Core
162 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Items
163 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Item IDE
164 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Items Runtime
165 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Language Server
166 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Persistence
167 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Persistence IDE
168 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Persistence Runtime
169 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Rules
170 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Rule IDE
171 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Rules Runtime
172 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Script
173 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Script IDE
174 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Script Runtime
175 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Sitemap
176 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Sitemap IDE
177 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Sitemap Runtime
178 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Thing
179 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Thing IDE
180 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Model Thing Runtime
181 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Persistence
182 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Scheduler Service
183 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Semantics
184 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: JSON Storage
185 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Thing
186 ¦ Active ¦ 75 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Thing XML
187 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Transformation Service
188 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: UI
189 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: UI Icon Support
190 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Voice
191 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB UI :: Bundles :: Dashboard UI
200 ¦ Active ¦ 80 ¦ 1.4.0 ¦ ThreeTen-Extra
201 ¦ Active ¦ 80 ¦ 1.0.3 ¦ Units of Measurement Common Library
202 ¦ Active ¦ 80 ¦ 1.0.10 ¦ Units of Measurement Implementation for Java SE
203 ¦ Active ¦ 80 ¦ 2.20 ¦ Dagger
204 ¦ Active ¦ 80 ¦ 1.4.199 ¦ H2 MVStore
205 ¦ Active ¦ 80 ¦ 1.1.2 ¦ hivemq-mqtt-client
206 ¦ Active ¦ 80 ¦ 3.15.0.OH2 ¦ nrjavaserial
207 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Buffer
208 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Codec
209 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Codec/HTTP
210 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Codec/MQTT
211 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Common
212 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Handler
213 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Resolver
214 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Transport
215 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Transport/Native/Epoll
216 ¦ Active ¦ 80 ¦ 4.1.42.Final ¦ Netty/Transport/Native/Unix/Common
217 ¦ Active ¦ 80 ¦ 2.2.5 ¦ rxjava
218 ¦ Active ¦ 80 ¦ 1.10.0 ¦ Apache Commons Codec
219 ¦ Active ¦ 80 ¦ 3.3.0 ¦ Commons Net
220 ¦ Active ¦ 80 ¦ 2.1.2 ¦ Java Concurrency Tools Core Library
221 ¦ Active ¦ 80 ¦ 2.5.2 ¦ JUPnP Library
222 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: HarmonyHub Binding
223 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: MQTT Broker Binding
224 ¦ Active ¦ 81 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: MQTT Things and Channels
225 ¦ Active ¦ 82 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
226 ¦ Active ¦ 82 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: MQTT Homie Convention
227 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: OpenWeatherMap Binding
228 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: UniFi Binding
229 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: ZWave Binding
230 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Automation
231 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Automation Media Modules
232 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Automation Script Modules
233 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Automation Script RuleSupport
234 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Automation REST API
235 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration UPnP Discovery
236 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration USB-Serial Discovery
237 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration USB-Serial Discovery for Linux using sysfs scanning
238 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Configuration Serial
239 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: MQTT Transport
240 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Serial Transport
241 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Serial Transport for RXTX
242 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: Serial Transport for RFC2217
243 ¦ Active ¦ 80 ¦ 2.5.0 ¦ openHAB Core :: Bundles :: UPnP Transport
244 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: Extension Service :: Eclipse IoT Marketplace
245 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: IO :: Hue Emulation Service
246 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: IO :: Java Sound Support
247 ¦ Active ¦ 75 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: IO :: MQTT Broker Moquette
248 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: IO :: Web Audio Support
249 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB UI :: Bundles :: HABPanel UI
250 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB UI :: Bundles :: Paper UI
251 ¦ Active ¦ 80 ¦ 1.0.2 ¦ reactive-streams
252 ¦ Active ¦ 80 ¦ 1.0.0 ¦ IO.Socket Engine Client
253 ¦ Active ¦ 80 ¦ 1.0.0 ¦ IO.Socket Socket Client
254 ¦ Active ¦ 80 ¦ 20180813.0.0 ¦ JSON in Java
255 ¦ Active ¦ 80 ¦ 3.8.1.1 ¦ Apache ServiceMix :: Bundles :: okhttp
256 ¦ Active ¦ 80 ¦ 1.13.0.1 ¦ Apache ServiceMix :: Bundles :: okio
257 ¦ Active ¦ 80 ¦ 2.5.1 ¦ openHAB Add-ons :: Bundles :: IO :: openHAB Cloud Connector
Have you shutdown openHAB , cleared openHAB cache and then restarted?
Through the years I have had missing tabs in paper ui off and on at random. This always fixed it.
Clear openHAB cache using command
openhab-cli clean-cache
from the terminal command line of your openHAB system.
H102
(CM6.5 H102)
January 30, 2020, 2:13pm
8
As @Thedannymullen mentioned cleaning the cache is a good first step but make sure to stop OH first .
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo systemctl start openhab2 or sudo reboot
You may need to reboot OH a few times after this as well. Just make sure to allow OH to fully restart between reboots.
I am lazy. After I stop OH I sometimes recursively delete all the contents of the cache
and tmp
folders in userdata
. (not those folders, just their contents)
H102
(CM6.5 H102)
January 30, 2020, 2:24pm
10
That is what openhab-cli clean-cache does, but there is always more than one way to skin a cat.
I thought it always had to be done very carefully , unless it is already dead.
rlkoshak
(Rich Koshak)
January 30, 2020, 2:39pm
12
If OH is stopped you can just delete the whole contents in one go. If OH is running, you shouldn’t be deleting those files anyway.
True. I was referring specifically to the cat…
ChrisW
(Christian W)
January 31, 2020, 8:02am
14
Stopping and deleting the userdata/tmp and userdata/cache did help.
Thanks a lot.
