Hi all,
I’m struggling with the air-quality binding which retrieves the data from aqicn.org. (using Version 3.2.0 stable). I use it since a while and all was working, but just yesterday I recognized the values are set to NULL. So i started to investigate and understood from the binding documentation, that the “Thing” has changed. So i updated my file according the docu, without success.
I ended up reinstalling the Binding, also without success and recreating the thing/item files. Also tried to set the Binding to DEBUG or even TRACE - but no… it stays silent.
My things-file (permissions are correct):
Bridge airquality:aqi:main "AQI Bridge" [ apiKey="xxxxxxx" ] {
station AQI_Vienna15 "AQI Home Vienna 15" [ location="48.205,16.30975", stationId="2850", refresh=60 ]
The related item file:
Group AirQuality <flow>
Number Aqi_Level "Air Quality Index" <flow> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:aqi#index" }
Number Aqi_Pm25 "PM\u2082\u2085 Level" <line> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:pm25#value" }
Number Aqi_Pm10 "PM\u2081\u2080 Level" <line> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:pm10#value" }
Number Aqi_O3 "O\u2083 Level" <line> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:o3#value" }
Number Aqi_No2 "NO\u2082 Level" <line> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:no2#value" }
Number Aqi_Co "CO Level" <line> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:co#value" }
Number Aqi_So2 "SO\u2082 Level" <line> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:so2#value" }
DateTime Aqi_ObservationTime "Time of observation [%1$tH:%1$tM]" <clock> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:aqi#timestamp" }
Number:Temperature Aqi_Temperature "Temperature" <temperature> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:weather#temperature" }
Number:Pressure Aqi_Pressure "Pressure" <pressure> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15:weather#pressure" }
Number:Dimensionless Aqi_Humidity "Humidity" <humidity> (AirQuality) { channel=" airquality:station:main:AQI_Vienna15weather#humidity" }
Any idea what got wrong here?
Thank you!
BR,
Rob
