When you setup the cloud openhab there are some keys you have to include in the setup. Do you know if you did that step? On the openhab cloud service it allow you to search items. Does your items show up in that list?
Hi Eric.
In https:/myopenhab.org i cant view items.
18:49:55.737 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
18:49:55.800 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
18:49:55.815 [INFO ] [ulation.internal.HueEmulationServlet] - Started Hue Emulation service at /api
18:49:56.817 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 3e00e59f-9935-4ff0-91ca-376f2a585e0e, base URL = http://localhost:8080)
just set items.cfg, default.sitemap.
The classic-ui I see the item.
I have installed open cloud-connector misc.
It my experience. It doesn’t have to be active. It still seems what every device you are using for mqtt need to be put on the end of your sting command in your item file. But it this point that is just a guess.
Uninstall the skill openhab from alexa and discovered the item. It was not the first time I uninstalled it but it worked. Thank you so much for help me.
