[SOLVED] Amazon account login page not working
I have been using the Amazon echo binding to great effect, mostly having Alexa announce things via the TTS options. It has been working great for some time but recently (a week or more) the binding is not working. It appears to have logged out from my account. In the past I have simply gone to the URL
http://openhab:8080/amazonechocontrol/myaccountID/
and logged in however, now when I try that instead of getting a login page at Amazon I am getting garbage text that looks like I might be opening a binary file.
An example of which is shown below:
��Yks�F���_A��h`A���	�Y��l�h⬣$��Ѩ�����H�����v�%Y٩��r�D߾}��}�'�w: �ܗr7Y���>�"�u�~�G��)?j����~�Jc��-��o���!3�"�������tzK���֢J�fJ�٫F�5ǟ��k꫷;^M��Y0���۹����F��wz������m�aŭI�O��|J��=!ɓ�kjO��$ �s3ƦKk�8��ډ:�L���hS"�m4Vwb��\4I����Hk% T}���a'd�����~��Z��l�Uދ:x� X?�w�д�L�X�@X�"κ��#f�[�I
What am I doing wrong, or what has gone wrong?
I have tried removing the binding and reinstalling.
I am on the latest snapshot.
I do see errors in my /var/log/openhab2/openhab.log
2018-11-08 19:14:02.413 [WARN ] [trol.internal.handler.AccountHandler] - get flash briefing profiles fails {}
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
	at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:224) ~[21:com.google.gson:2.7.0.v20170129-0911]
	at com.google.gson.Gson.fromJson(Gson.java:887) ~[21:com.google.gson:2.7.0.v20170129-0911]
	at com.google.gson.Gson.fromJson(Gson.java:852) ~[21:com.google.gson:2.7.0.v20170129-0911]
	at com.google.gson.Gson.fromJson(Gson.java:801) ~[21:com.google.gson:2.7.0.v20170129-0911]
	at com.google.gson.Gson.fromJson(Gson.java:773) ~[21:com.google.gson:2.7.0.v20170129-0911]
	at org.openhab.binding.amazonechocontrol.internal.Connection.parseJson(Connection.java:565) ~[231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.openhab.binding.amazonechocontrol.internal.Connection.getEnabledFlashBriefings(Connection.java:802) ~[231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateFlashBriefingProfiles(AccountHandler.java:541) [231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateFlashBriefingHandlers(AccountHandler.java:513) [231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateFlashBriefingHandlers(AccountHandler.java:505) [231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.getNewCurrentFlashbriefingConfiguration(AccountHandler.java:499) [231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.openhab.binding.amazonechocontrol.internal.discovery.AmazonEchoDiscovery.startScan(AmazonEchoDiscovery.java:82) [231:org.openhab.binding.amazonechocontrol:2.4.0.201811081934]
	at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:211) [97:org.eclipse.smarthome.config.discovery:0.10.0.201811071908]
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:381) [97:org.eclipse.smarthome.config.discovery:0.10.0.201811071908]
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:366) [97:org.eclipse.smarthome.config.discovery:0.10.0.201811071908]
	at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:215) [97:org.eclipse.smarthome.config.discovery:0.10.0.201811071908]
	at org.eclipse.smarthome.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:97) [119:org.eclipse.smarthome.io.rest.core:0.10.0.201811071908]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [170:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [170:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [170:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [170:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [170:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [170:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [171:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [168:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [168:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [168:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [168:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [168:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [185:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [185:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [185:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
	at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:385) ~[?:?]
	at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:213) ~[?:?]
	... 76 more
2018-11-08 19:15:00.518 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:16:00.966 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:16:59.786 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:18:01.011 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:19:01.636 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:20:02.128 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:21:02.710 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:22:03.333 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:23:04.533 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:24:05.027 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
2018-11-08 19:25:05.474 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: POST url 'https://www.amazon.com/ap/signin' failed: Not Found
I searched the community forums to no avail. - I am not sure what to do next.
Did you read this thread?
Thanks for the heads up, I did not find that thread in my search. I will take a look at downloading Beta 6 (I think that’s the latest).
I downloaded the beta 6 version and installed the jar file in /usr/share/openhab2/addons
and it fixed the issue. I am now able to get Alexa to speak again.
Where did you download it from?
Download the file from the page linked here
