Hi, Im using several Amazon Dashbuttons within Openhab (2.3) and they work fine in principle (for triggering rules). But every time I reboot OH, the Dashbuttons (even if theyre “online” in the Paper UI) doesnt trigger the rules. So I need to modify the rules slightly, e.g. just create a return or blank and save it, then it works again. Any idea why this happens? Thanks Jesco - P.S. I dont use the rule editor in Openhab, I created them manually.
OK, found it! Was my mistake. I`m using several rules and three of them had the same name “Dash button pressed”. Just rename them and it works fine after reboot.
