[SOLVED] An error occurred during the script execution: null
i have seen already other issues on this error but it do not help
i have a long rule which can get inputs from telegram, voicecommand, or google calendar.
i am getting this error :
Please find below the logs:
114 [INFO ] [script.Rule File: voicecontrol.rules] - Rule:TelegramInput
129 [INFO ] [smarthome.model.script.voice control] - 2 TelegramInput received----@ifttt éteindre télé----
140 [INFO ] [smarthome.model.script.voice control] - 2 TelegramInput received----éteindre télé----
165 [ome.event.ItemCommandEvent] - Item 'GlobalScene' received command éteindre télé
179 [vent.ItemStateChangedEvent] - TriggerGlobalScene changed from VoiceCommand to Telegram
184 [vent.ItemStateChangedEvent] - GlobalScene changed from éteindre clim salon to éteindre télé
2018-08-05 22:06:24.107 [vent.ItemStateChangedEvent] - Sun_Elevation changed from -26.88 to -27.63
2018-08-05 22:06:24.428 [vent.ItemStateChangedEvent] - Moon_Elevation changed from -30.69 to -29.96
311 [INFO ] [script.RULE : Scenario -GlobalScene=] - receivedCommand :éteindre télé
316 [INFO ] [ipse.smarthome.model.script.Scenario] - 1-newscene :éteindre télé
332 [INFO ] [ipse.smarthome.model.script.Scenario] - 2-newscene :eteindre tele
352 [vent.ItemStateChangedEvent] - GlobalScene_LastUpdate changed from 2018-08-05T22:03:44.404+0300 to 2018-08-05T22:06:26.335+0300
354 [INFO ] [ipse.smarthome.model.script.Scenario] - -----------------------------------------------------------------------
360 [INFO ] [pse.smarthome.model.script.Scenario ] - --END OF CLOSED OPTIONS---VarFoundScenario= NULL
366 [vent.ItemStateChangedEvent] - FoundScenario changed from eteindre clim salon to NULL
368 [INFO ] [.eclipse.smarthome.model.script.cmd ] - OFF
409 [INFO ] [.eclipse.smarthome.model.script.cmd ] - tele: current state ON
417 [INFO ] [ipse.smarthome.model.script.Scenario] - -----------------------------------------------------------------------
423 [INFO ] [pse.smarthome.model.script.Scenario ] - VarFoundScenario= NULL
429 [INFO ] [pse.smarthome.model.script.Scenario ] - -----END OF OPENED OPTIONS----VarFoundScenario= NULL
435 [INFO ] [pse.smarthome.model.script.Scenario ] - -----NOT FOUND----eteindre tele_ISSUE
448 [vent.ItemStateChangedEvent] - FoundScenario changed from NULL to eteindre tele_ISSUE
462 [INFO ] [pse.smarthome.model.script.ifttt_url] - https://maker.ifttt.com/trigger/GlobalScene/with/key/d-gfo0Ob3sjc-zAuwcQJ6F
475 [INFO ] [me.model.script.notification_json = ] - {"value1":"Telegram","value2":"eteindre_tele_ISSUE-Opened","value3":"10:06m on Sunday, August 5, 2018"}
483 [INFO ] [se.smarthome.model.script.myquery = ] - curl@@-X@@POST@@-H@@Content-Type: application/json@@-d@@{"value1":"Telegram","value2":"eteindre_tele_ISSUE-Opened","value3":"10:06pm on Sunday, August 5, 2018"}@@https://maker.ifttt.com/trigger/GlobalScene/with/key/d-gfo0Ob3sjc-zAuwcQJ6F
035 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'scenario.rules'
536 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'scenario': An error occurred during the script execution: null
680 [vent.ItemStateChangedEvent] - logreaderLastError changed from 2018-08-05 22:03:49.680 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'scenario': An error occurred during the script execution: null to 2018-08-05 22:06:31.536 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'scenario': An error occurred during the script execution: null
Please find below the rules (the remarks for optimization are more than welcome)
The performance are not stable
var Timer ToasterTimer = null
val int timeoutMinutes = 8 // choose an appropriate value
rule "scenario"
    Item GlobalScene received command
//Block 1 start String formatting////////
 //if(GlobalScene.previousState == NULL) return;
	//var String newscene= GlobalScene.state.toString.toLowerCase
	var String newscene=receivedCommand.toString.toLowerCase
	var String cmd
	logInfo("RULE : Scenario -GlobalScene=", "receivedCommand :" +newscene  )
	logInfo("Scenario", "1-newscene :"  + newscene)
	newscene =newscene.replace("@ifttt ","")
	newscene =newscene.replace("ifttt","")
	newscene =newscene.replace("lili ","")
 	newscene =newscene.replace("lili","")
	newscene =newscene.replace("é","e")
	newscene =newscene.replace("î","i")
	newscene =newscene.replace("allen","allume")
	newscene =newscene.replace("eteins","eteindre")
	newscene =newscene.replace("allumer","allume")
	newscene =newscene.replace("stop","eteindre")
	newscene =newscene.replace(" ’ ","'")
	newscene =newscene.replace(" ' ","'")
	logInfo("Scenario", "2-newscene :"  + newscene)
	//1 end String formatting////////
	var String VarFoundScenario= "NULL"
	var String optionFound
	//logInfo("Scenario", "receivedCommand :"  + receivedCommand)
	GlobalScene_LastUpdate.postUpdate(new DateTimeType())
	FoundScenario.postUpdate("NULL")
//Bloc 1 end String formatting////////
//Bloc 2 Start Options ////////
	switch (newscene)
				case "bloque tele",
				case "bloch tele":{
						VarFoundScenario=newscene
						//FoundScenario.postUpdate(newscene)
						M1_1.sendCommand("OFF")
						M1_1.postUpdate("OFF")
				case "allume appliques" ,
				case "allume applique" :
					appliqueSwitch.sendCommand(ON)
					appliqueSwitch.postUpdate(ON)
				//	FoundScenario.postUpdate(newscene)
				case "eteindre appliques" :
					appliqueSwitch.sendCommand(OFF)
					appliqueSwitch.postUpdate("OFF")
				case "allume terrasse" :
					TerraseSwitch2.sendCommand("ON")
					TerraseSwitch2.postUpdate(ON)
					publish("mosquitto", "broadlink/mqtt_RM_1/rf/Terrrasse_ON", "replay")
				case "eteindre terrasse":
					TerraseSwitch2.sendCommand("OFF")
					TerraseSwitch2.postUpdate("OFF")
					publish("mosquitto", "broadlink/mqtt_RM_1/rf/Terrrasse_OFF", "replay")
				case "allume clim salon":
				//	if 	(Clim_1.state.toString.toLowercase="on"){return;}
					Clim_1.sendCommand("ON")
					Clim_1.postUpdate(ON)
				case "eteindre clim salon":
				//	if 	(Clim_1.state.toString.toLowercase="off"){return;}
					Clim_1.sendCommand("OFF")
					Clim_1.postUpdate("OFF")
				case "allume clim parents" :
					Clim_2.sendCommand("ON")
					Clim_2.postUpdate(ON)
				case "eteindre clim parents":
					Clim_2.sendCommand("OFF")
					Clim_2.postUpdate("OFF")
				case "allume clim noya",
				case "allume clim nono" :
					Clim_3.sendCommand("ON")
					Clim_3.postUpdate(ON)
				case "allume clim chateau":
					Clim_4.sendCommand("ON")
					Clim_4.postUpdate(ON)
				case "eteindre clim chateau":
					Clim_4.sendCommand("OFF")
					Clim_4.postUpdate("OFF")
				case "allume clim maison":
					Clim_3.postUpdate(ON)				//	FoundScenario.postUpdate(newscene)
					Clim_2.postUpdate(ON)				//	FoundScenario.postUpdate(newscene)
					Clim_1.postUpdate(ON)				//	FoundScenario.postUpdate(newscene)
				case "eteindre clim maison":
					Clim_3.sendCommand("OFF")
					Clim_3.postUpdate("OFF")
				case "eteindre salon":
					LG_P_Power.sendCommand("OFF")
					LG_P_Power.postUpdate(OFF )
					SP2_2.sendCommand("OFF")
					SP2_2.postUpdate("OFF")
				case "eteindre lumieres maison":
				case "eteindre chambre parents":
					ZWaveSwitch1_Channel1_Right.sendCommand(OFF)
					ZWaveSwitch1_Channel2_Left.sendCommand(OFF)
					led_desk.sendCommand("OFF")
					led_desk.postUpdate("OFF")
                case "allume bar",
				case "allume ilot",
				case "allume barre":
					SP2_2.sendCommand("ON")
					SP2_2.postUpdate(ON)
                case "eteindre ilot",
				case "eteindre bar" ,
				case "eteindre barre":
				case "allume chauffage":
					SP2_1.sendCommand("ON")
					SP2_1.postUpdate(ON)
 				case "eteindre chauffage":
					SP2_1.sendCommand("OFF")
					SP2_1.postUpdate("OFF")
				 case "allume bureau" :
					//sonoff_desk.sendCommand("ON")
					//sonoff_desk.postUpdate(ON )
					led_desk.sendCommand("ON")
					Thread::sleep(1)
					led_desk.sendCommand("turkey2")
					led_desk.postUpdate("turkey2")
				 case "eteindre bureau" :
					//	//sonoff_desk.sendCommand("OFF")
					//	//sonoff_desk.postUpdate("OFF")
				 case "allume routeur" :
	  case "lock",
				  case "verrouille",
				  case "arme":
				//HomeStatus.sendCommand("bye")
				HomeStatus.postUpdate("lock")
				//logInfo("Scene Bye", "Start on all devices: " + receivedCommand)
				VarFoundScenario="lock"
				/* Switcher.sendCommand("OFF")
				Switcher.postUpdate("OFF")
				Toilets.sendCommand("OFF")
				Toilets.postUpdate("OFF")
				sdblight.sendCommand("OFF")
				sdblight.postUpdate("OFF")
				appliqueSwitch.sendCommand("OFF")
				LG_Power_Proxy.sendCommand("OFF")
				LG_Power_Proxy.postUpdate("OFF")
				//	M1_1.sendCommapdate(OFF)
				//M1_2.sendCommand("OFF_M2")
				//M1_2.postUpdate("OFF")_M2" )
				//M1_3.sendCommand("OFF_M3")nd("OFF")
				//	M1_1.postU
				//M1_3.postUpdate("OFF")_M3" )
				//M1_4.sendCommand("OFF_M4")
				//M1_4.postUpdate("OFF")_M4" )
				ZWaveSwitch1_Channel2_Left.postUpdate( OFF )
				ZWaveSwitch1_Channel1_Right.postUpdate( OFF )
				TV.sendCommand("OFF")
				TV.postUpdate("OFF")
				led_mini2.sendCommand("OFF")
				led_mini2.postUpdate("OFF")
				led_mini3.sendCommand("OFF")
				led_mini3.postUpdate("OFF")
				logInfo("Bye", "End on all devices: ")
				//sendTelegram("bot1", "SCENE BYE triggered: Salon except clim, Toilets,Terrase,Switcher,SDB , douche, clim parents, clim noya")
        case "telephone gil",
		case "gil telephone":				{
				VarFoundScenario="wmd_gil"
				logInfo("WMD RING", newscene)
				wmd_global.sendCommand("wmd_gil")
				wmd_global.postUpdate("wmd_gil")
		case "musique gil",
		case "musique gili",
		case "musique billy",
		case "musique guili",
		case "guili musique",
		case "gili sonne",
		case "gil sonne":
				VarFoundScenario="ring_gil"
				wmd_global.sendCommand("ring_gil")
				wmd_global.postUpdate("ring_gil")
        case "telephone karen",
		case "karen telephone",
		case "karen  téléphone",
		case "téléphone karen":
				wmd_global.sendCommand("wmd_karen")
				wmd_global.postUpdate("wmd_karen")
        case "telephone heni",
		case "heni telephone":
				wmd_global.sendCommand("wmd_heni")
				wmd_global.postUpdate("wmd_heni")
        case "telephone noya",
		case "noya telephone",
		case "telephone nono",
		case "nono telephone":
					wmd_global.sendCommand("wmd_noya")
					wmd_global.postUpdate("wmd_noya")
		case "allume pc":
		case "volume 10":
					LG_TV0_Volume.sendCommand(10)
		//			LG_TV0_Volume.postUpdate(10)
		case "volume 30":
					LG_TV0_Volume.sendCommand(30)
		//			LG_TV0_Volume.postUpdate(30)
		case "volume 40":
					LG_TV0_Volume.sendCommand(40)
		case "volume 50":
					LG_TV0_Volume.sendCommand(50)
		//			LG_TV0_Volume.postUpdate(50)
		case "volume 60":
					LG_TV0_Volume.sendCommand(60)
		//			LG_TV0_Volume.postUpdate(60)
		case "volume 70":
					LG_TV0_Volume.sendCommand(70)
		//			LG_TV0_Volume.postUpdate(70)
		case "silence salon":
					irobot.sendCommand("irobot_pause")
					irobot.postUpdate("irobot_pause")
					LG_TV0_Mute.sendCommand("ON")
					LG_TV0_Mute.postUpdate(ON)
					ChromecastAudio_Control.sendCommand("PAUSE")
					ChromecastAudio_Control.postUpdate("PAUSE")
		case "silence chambre":
					TV_vol.sendCommand("Tvmute")
					TV_vol.postUpdate("mute")
					case "toaster",
					case "toaster 5 minutes":
					SP2_3.sendCommand("ON")
					SP2_3.postUpdate(ON)
      				ToasterTimer = createTimer(now.plusMinutes(5 ), [|
            		SP2_3.sendCommand(OFF)
            		ToasterTimer = null
					say("Le toast est prêt. bon appetit")
					case "toaster 10 minutes":
      				ToasterTimer = createTimer(now.plusMinutes(10 ), [|
            		ToasterTimer = null
					case "eteindre toaster":
					SP2_3.sendCommand("OFF")
					SP2_3.postUpdate(OFF)
					say("oui monsieur")
	logInfo("Scenario", "-----------------------------------------------------------------------")
	optionFound="_Closed"
	logInfo("Scenario ", "--END OF CLOSED OPTIONS---"+"VarFoundScenario= "+ VarFoundScenario  )
//Bloc 2 End Options ////////
	//FoundScenario.postUpdate(VarFoundScenario)
//Bloc 3 start Options ////////
if (VarFoundScenario.contains("NULL")){
			if ( newscene.contains("turn off")  || newscene.contains("tein")|| newscene.contains("eteindre")){
						logInfo("cmd ", "OFF" )
						cmd = "OFF"
			if ( newscene.contains("turn on")  || newscene.contains("allume") ){
				cmd = "ON"
			if ( newscene.contains("switcher 60m") ){
				Switcher.sendCommand("60m")
				VarFoundScenario="allume eau chaude 60"
			if (newscene.contains("allume eau chaude")  || newscene.contains("allume dude")){
				Switcher.sendCommand("30m")
				VarFoundScenario="allume eau chaude"
			if ( newscene.contains("switcher 30m") ){
				VarFoundScenario="allume eau chaude 30"
 		 	if (newscene.contains("eteindre eau chaude")  || newscene.contains("eteindre dude")){
			   Switcher.sendCommand("OFF")						//	Switcher.postUpdate("OFF")
				VarFoundScenario="stop eau chaude"
			if (newscene.contains("bain") || newscene.contains("ben"))  {
				logInfo("cmd ", "bain: " + cmd )
						if (cmd=== null) {
							switch (sdblight.state.toString)
									case "OFF" :
										cmd = "ON"
									case "ON" :
										cmd = "OFF"
							VarFoundScenario="Salle de Bain_" +cmd
						sdblight.sendCommand(cmd)
						sdblight.postUpdate(cmd)
						appliqueSwitch.sendCommand(cmd)
						appliqueSwitch.postUpdate(cmd)
						SP2_1.sendCommand(cmd)
						SP2_1.postUpdate(cmd)
			if (newscene.contains("douche")) {
				logInfo("douche ", "douche: " )
				if (cmd === null) {
				switch (ZWaveSwitch1_Channel1_Right.state.toString)
							case "OFF",
							case "off" :
								cmd = "ON"
							case "ON",
							case "on" :
								cmd = "OFF"
				VarFoundScenario="douche_" +cmd
				ZWaveSwitch1_Channel1_Right.sendCommand(cmd)
				ZWaveSwitch1_Channel2_Left.sendCommand(cmd)
			if ( newscene.contains("romantique")  || newscene.contains("amour") || newscene.contains("sexe") || newscene.contains("sex")){
									VarFoundScenario="romantique"
									led_desk.sendCommand("on")
									Thread::sleep(2)
									led_desk.sendCommand("red")
									led_desk.postUpdate("red")
									// +cmd
			if ( newscene.contains("led")){
									VarFoundScenario="led  off"// +cmd
			if ( newscene.contains("vert")){
									VarFoundScenario="led  green"// +cmd
									Thread::sleep(2)
									led_desk.sendCommand("green")
									led_desk.postUpdate("green")
			if ( newscene.contains("blanc")){
									VarFoundScenario="led  white"// +cmd
									Thread::sleep(2)
									led_desk.sendCommand("white")
									led_desk.postUpdate("white")
			if (newscene.contains("toilettes") || newscene.contains("toilette")) {
				logInfo("cmd ", "toilettes: current state " + Toilets.state.toString )
				if (cmd=== null) {
				switch (Toilets.state.toString)
							case "OFF" :
							cmd = "ON"
							//publish("mosquitto", "broadlink/mqtt_M1_1/power", "1/ON")
								Toilets.sendCommand("ON")
								Toilets.postUpdate(ON)
							case "ON" :
								cmd="OFF"
					VarFoundScenario="Toilets_" +cmd
			if (newscene.contains("terrase") || newscene.contains("terrasse")) {
				logInfo("cmd ", "terrase: current state " + TerraseSwitch2.state.toString )
				if (cmd=== null) {
						switch (TerraseSwitch2.state.toString)
									case "OFF" :
										cmd = "ON"
									case "ON" :
										cmd="OFF"
						VarFoundScenario="Terrasse_" +cmd
		if (newscene.contains("ilot") || newscene.contains("bar")) {
						logInfo("cmd ", "ilot: current state " + SP2_2.state.toString )
						if (cmd=== null)
								switch (SP2_2.state.toString)
											case "OFF" :
												cmd = "ON"
											case "ON" :
												cmd="OFF"
											VarFoundScenario="ilot_" +cmd
			if (newscene.contains("clim salon") || newscene.contains("salon clim")) {
				logInfo("cmd ", "Salon: current state " + Clim_1.state.toString )
			//	if (cmd=== null) {
				switch (Clim_1.state.toString)
							case "OFF" :
							  cmd = "ON"
							case "ON" :
								cmd="OFF"
					VarFoundScenario="Clim_1_" + cmd
			if (newscene.contains("clim doudou") || newscene.contains("doudou clim")) {
							case "OFF" :
							  cmd = "ON"
							case "ON" :
								cmd="OFF"
			if (newscene.contains("clim parents") || newscene.contains("parents clim")) {
				logInfo("cmd ", "parents: current state " + Clim_2.state.toString )
				if (cmd=== null) {
				switch (Clim_2.state.toString)
							case "OFF" :
							  cmd = "ON"
							case "ON" :
								cmd="OFF"
					VarFoundScenario="Clim_2_" +cmd
				if (newscene.contains("clim nono") || newscene.contains("nono clim")) {
				logInfo("cmd ", "nono: current state " + Clim_3.state.toString )
				if (cmd=== null) {
				switch (Clim_3.state.toString)
							case "OFF" :
							  cmd = "ON"
							case "cold" :
								cmd="OFF"
					VarFoundScenario="Clim_3_" +cmd
		//	if (newscene.contains("led")) {
		//		logInfo("cmd ", "led: current state " + led_desk.state.toString )
		//		switch (led_desk.state.toString)
		//					case "OFF" :
		//					  cmd = "ON"
		//							led_desk.sendCommand("ON")
		//							Thread::sleep(10)
		//							led_desk.sendCommand("green")
		//							led_desk.postUpdate("green")
		//					default:
		//						cmd="off"
		//						led_desk.sendCommand("OFF")
		//						led_desk.postUpdate("OFF")
		//			VarFoundScenario="led_desk_" +cmd
	if (newscene.contains("tele") && newscene.contains("parents"))
	logInfo("cmd ", "tele: current state " + LG_P_Power.state.toString )
		if (LP_Switch.state == OFF )
				if (cmd=== null)
					switch (TV.state.toString)
									case "OFF" :
									cmd = "ON"
									TV.sendCommand("ON")
									TV.postUpdate(ON )
									case "ON" :
									cmd = "OFF"
									TV.postUpdate(OFF )
								VarFoundScenario="TV_Parents" +cmd
	if (newscene.contains("tele") )
				if (cmd=== null)
					switch (LG_P_Power.state.toString)
									case "OFF" :
									cmd = "ON"
									LG_P_Power.sendCommand("ON")
									LG_P_Power.postUpdate(ON )
									case "ON" :
									cmd = "OFF"
								VarFoundScenario="TV_" +cmd
			optionFound="-Opened"
	if	(optionFound!="_Closed"){
			logInfo("Scenario ","VarFoundScenario= "+ VarFoundScenario  )
			logInfo("Scenario ", "-----END OF OPENED OPTIONS----" +"VarFoundScenario= "+ VarFoundScenario  )
//Bloc 3 end Options ////////
switch VarFoundScenario{
			case "NULL":{
			VarFoundScenario=newscene+"_ISSUE"
			logInfo("Scenario ", "-----NOT FOUND----" +VarFoundScenario )
//					if(Bot2_Enabled.state == ON){sendTelegram("bot6", VarFoundScenario +"--NOT FOUND--")}
//			default:{
				var String ifttt_key = "d-gsjc-"
				var String notification_json
				val String currentTime = String::format( "%1$tl:%1$tM%1$tp on %1$tA, %1$tB %1$te, %1$tY", new java.util.Date )
				//var lastItem = TriggerGlobalScene.previousState().state.toString
				var lastItem = TriggerGlobalScene.state.toString
				// Avoid sending the alert if the state didn't change
				// Compare state before update and now
				//    var lastState = lastItem.historicState(lastItem.lastUpdate.toDateTime.minusSeconds(1))
				var String ifttt_url = "https://maker.ifttt.com/trigger/"+TriggerGlobalScene.state.toString + "/with/key/" + ifttt_key
				var String TriggerStripped =TriggerGlobalScene.state.toString
				TriggerStripped =TriggerStripped.replace('','_')
				//logInfo("ifttt_url", ifttt_url)
				//notification_json = '{"value1":"' + lastItem + '","value2":"' +  VarFoundScenario +'","value3":"' + currentTime + '"}'
				//logInfo("IFTT",    "sendHttpPostRequest : " + notification_json)
				//sendHttpPostRequest(ifttt_url, "application/json", notification_json)//,8000)
				//Thread::sleep(10)
				ifttt_url = "https://maker.ifttt.com/trigger/GlobalScene/with/key/" + ifttt_key
				var String FoundScenarioStripped =VarFoundScenario
				FoundScenarioStripped =FoundScenarioStripped.replace(' ','_')
				notification_json = '{"value1":"' + lastItem + '","value2":"' +  FoundScenarioStripped +optionFound+'","value3":"' + currentTime + '"}'
		//		WebhookUrl.postUpdate(ifttt_url)
				logInfo("notification_json = ", notification_json)
				var String myquery = String::format("curl@@-X@@POST@@-H@@Content-Type: application/json@@-d@@"+notification_json + "@@"+ifttt_url)
				logInfo("myquery = ", myquery)
				val results = executeCommandLine(myquery, 5000)
				//val results = executeCommandLine("/usr/bin/curl -X POST " +ifttt_url, 5000)
				logInfo("results", results)
Well, the reason is, you have typos in there. This rule is really disgusting, It’s not manageable.
As a first point, there should be no need to do a .sendCommand() and a .postUpdate() for the same item, as openHAB will do the .postUpdate() itself (if you don’t configure the item to autoupdate="false")
A second point, please use a code editor such as VSCode or Notepad++, both will tell you that the brace level has errors.
Please pay attention to the level by indenting lines with the same level to the same tab.
Please delete all commented code, as this will only make it more complex to follow the non existent structure…
Please consider to split the rule into less long rules. As far as I understood this rule is a parser for complete sentences. As I don’t speak french (hope this is french…) I have no idea how to parse this in a correct way.
I’ll second Udo’s suggestion to use VSCode with the openHAB extension. And it is not necessary to send a command and an update, the command is sufficient.
Have a look at Design Pattern: How to Structure a Rule and A simple scene management: finally a good use of scripts for some ideas you might be able to use to simplify this rule somewhat.
