Hi chaps,
I have the following in a rule:
val String ASTRO_INTRO = "Hi, some astro info, "
val String SUN_RISE_TXT = ASTRO_INTRO + “The sun is due to be rising at [%1$tH,%1$tM] hundred hours”
val String SUN_SET_TXT = ASTRO_INTRO + “The sun is due to be setting at [%1$tH,%1$tM] hundred hours”rule “Sunrise rules”
Channel ‘astro:sun:home:rise#event’ triggered START
String tmp = Sunrise.state.format(SUN_RISE_TXT)
say (tmp)
endrule “Sunset rules”
Channel ‘astro:sun:home:set#event’ triggered START
String tmp = Sunset.state.format(SUN_SET_TXT)
say (tmp)
And the following items:
DateTime Sunrise “Sun rise [%1$tH:%1$tM]” (Astro) { channel=“astro:sun:home:rise#end” }
DateTime Sunset “Sun Set [%1$tH:%1$tM]” (Astro) { channel=“astro:sun:home:set#start” }
The astro binding is generating events nicely, apart from the issue requiring a restart periodically. Events are set to trigger 15 minutes prior to each ‘official’ time.
The aim is simply to have the system announce the time the event will take place. I seem to be getting the following error in the logs:
Rule ‘Sunrise rules’: An error occurred during the script execution: Couldn’t invoke ‘assignValueTo’ for feature JvmVoid: (eProxyURI: astro.rules#|::0.2.0.2.0.1::0::/1)
Any assistance on where I am going wrong would be greatly appreciated.
