- Platform information:
- Hardware: Raspberry 3B
- OS: Archlinux AArch64
- Java Runtime Environment: Oracle JDK 8
- openHAB version: 2.2.0
- Issue of the topic: Unable to access serial devices, getting a NoSuchPortException
- Please post configurations (if applicable):
- Mysensors.things config:
Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/mysensorsgw", sendDelay=200 ] {
- Rfxcom.things config:
Bridge rfxcom:bridge:e0755ec5 [ serialPort="/dev/rfxtrx0", disableDiscovery=true ]
- Udev rules:
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A11DAINL", SYMLINK+="rfxtrx0", GROUP="dialout", MODE="0666"
SUBSYSTEMS=="usb", ATTRS{idProduct}=="7523", ATTRS{idVendor}=="1a86", SYMLINK+="mysensorsgw"
- If logs where generated please post these here using code fences:
2018-05-18 23:56:51.141 [ERROR] [col.serial.MySensorsSerialConnection] - No such port: /dev/mysensorsgw
gnu.io.NoSuchPortException: null
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) [25:com.neuronrobotics.nrjavaserial:3.12.0.OH]
at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:51) [231:org.openhab.binding.mysensors:2.3.0.201803141156]
at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:148) [231:org.openhab.binding.mysensors:2.3.0.201803141156]
at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:127) [231:org.openhab.binding.mysensors:2.3.0.201803141156]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
I’m currently running Raspbian without any issue, both Rfxcom and MySensors’ gateway are working with Openhab. This confirms that the above configuration is correct.
For software specific versions (dnsmasq + other things), as Debian/Raspbian package release process is a bit slow, I would like to swich to Archlinux. It’s a distro that I know pretty well and I like it, so I tried Openhab on it.
Unfortunately, none of my serial devices work with Openhab. I get the error given above. I also tried on my main Arch system on my desktop (Intel Core i7) and I get the same stack trace.
The dialout group does not exist on Archlinux, the uucp group is used instead, and the lock one.
I did test the ARMv7 version of Archlinux ARM yet, but I’ve just prepared an SD card and will test this weekend.
I dit not test another controller like Domoticz yet.
I know Arch is not officially supported, but is this a known issue?
Am I in a dead end with this?
Should I stick with Raspbian?
Thanks.
EDIT: I’ve just tested MyController, which is another Java controller, and the MySensors’ gateway is properly detected and working. Don’t know if this gives a clue…
EDIT2:
fixed log (correct /dev/xxx)
and I forgot to join my extra java opt:
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/rfxtrx0:/dev/mysensorsgw"
