Hi folks,
I’ve a strange issue here, I hope you can help me.
I’m installing the Astro Binding, and then I would like to add some specific icons, eg. for each season (spring, summer, autumn, winter).
so I’ve created 5 files:
then, quite simple and usual stuff, in the sitemap:
Text item=Astro_Sun_Season_Name icon="weather_season"
Nothing … with all items from Astro Binding I’m not able to use dynamic icons. Both ClassicUI and BasicUI use only the generic icon weather_seasons.png
Exactly the same with other items, like Zodiac Sign (both Moon and Sun).
Other items from other bindings are working like a charm.
How can I troubleshoot properly?
My logs are reporting this:
2018-08-23 18:25:14.161 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 36686558 failed: null
2018-08-23 18:25:14.163 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2018-08-23 18:25:15.633 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 36686593 failed: null
2018-08-23 18:25:15.634 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2018-08-23 18:25:16.645 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 36686620 failed: null
2018-08-23 18:25:16.647 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2018-08-23 18:25:59.124 [WARN ] [org.eclipse.jetty.http.HttpParser ] - URI is too large >8192
2018-08-23 18:25:59.127 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 414 for HttpChannelOverHttp@3c2487be{r=26,c=false,a=IDLE,uri=null}
2018-08-23 18:26:39.771 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 36687402 failed: null
2018-08-23 18:26:39.773 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
but the icons are 400KB, and in any case if the problem should be icon size/dimension, I should not be able to see also the generic icons, right?
Please let me know your thoughts
thanks
Andrea
