[Solved] Attempt to migrate from MQTT1 to v2
OK, if I take this advise… (as I wouldn’t know how to submit the JSON to REST), and add the generic mqtt things… how do I have to define them?
There is no auto-config, because these are some Arduinos.
… and what do I put into the item.
As an example, here are a few items sending / receiving mqtt commands:
String ZevaUNO_MAC			"MAC address [%s]"						<network>		(gZevaStatus)		{mqtt="<[mymosquitto:ArgyleCourt/Shed/Tower/Zeva16/MAC:state:default]"}
String ZevaUNO_Message		"SysMsg: [%s]"							<settings>		(gZevaStatus)		{mqtt="<[mymosquitto:ArgyleCourt/Shed/Tower/Zeva16/Notification:state:default]", expire="12m,Zeva Controller broken"}
String ZevaCellSetRaw		"Cell sets raw [%s]"									(gZevaStatus)		{mqtt="<[mymosquitto:ArgyleCourt/Shed/Tower/Zeva16/Voltages:state:default]"}
Number   Irrigation1_1_ValveVolume          "Stn 1.1: Outer East Volume [%d l]"             <sprinkler>     (gIrri1All, gPumpStation1_ZoneVolumes_Chart, gPersist_rrd4j)    {mqtt="<[mymosquitto:ArgyleCourt/Property/PumpStation1/Volume1:state:default]"}
Switch   PumpStation1_SoilPermittivity      "Stn 1 soil permittivity"                                       (gIrri1All)                         {mqtt=">[mymosquitto:ArgyleCourt/Property/PumpStation1/Command:command:ON:soilOn],>[mymosquitto:ArgyleCourt/Property/PumpStation1/Command:command:OFF:soilOff]"}
You gace me examples for rules the other day:
        // MQTT 2.x version
        val mqttActions = getActions("mqtt","mqtt:broker:mymosquitto") // use Thing ID for broker Thing
        mqttActions.publishMQTT(topicRoot + "Flow"   + valveNumber, valveFlow.toString)
        mqttActions.publishMQTT(TopicRoot + "Volume" + valveNumber, valveVolume.toString)
… as for “use Thing ID for broker Thing” I have (re)named to mymosquitto. :slight_smile:
[edit] I have started another thread: [Solved] Things: doing my head in :(
… and things (pun intended) have become much clearer by the minute. :slight_smile:
