[Solved] Binary Operations in Rules
This rule works as expected and produces the output “Trap 3”:
    var Number nID
    var int intValue
    nID = 12
    intValue = 0
    if (nID == 25) {
        if (intValue == 0) {
            logInfo("sensor.rules", "Trap 1")
        else logInfo("sensor.rules", "Trap 2")
    else logInfo("sensor.rules", "Trap 3")
Then the 2nd if-statement is changed to perform a binary operation.
The rule looks like this and gives the unexpected result “Trap 1”:
    var Number nID
    var int intValue
    nID = 12
    intValue = 0
    if (nID == 25) {
        if ((intValue | 0x20) == 0) {
Because nID does not match the value given in the 1st if-statement it should not even check the 2nd one.
Besides that the 2nd if-statement which is a binary OR would give a false result anyway.
From what I’ve read about binary operations in Java that code should be OK (e.g. https://www.tutorialspoint.com/java/java_bitwise_operators_examples.htm).
So there are 3 questions:
  1. Why is the 2nd if-statement checked at all after the 1st one results in a false condition.
  2. Why does the rule evaluate the 2nd if-statement to true?
  3. If there’s anything wrong in that code how is it done right?
I suspect the single pipe is breaking everything. Did you intend || for OR? That would always return true though.
Unfortunately this is not Java, rules are written in a OH specific version of Xtend. Mostly very like Java. But distinctly quirky so far as handling Numbers bitwise goes.
Googling for OpenHAB bitwise throws up tidbits worth reading, example
OK, it’s not Java.
With that information and the link I could change my rule to this:
    var Number nID
    var int intValue
    nID = 12
    intValue = 0
    if (nID == 25) {
        if (intValue.bitwiseOr(0x20) == 0) {
When playing with the variable values the statements now are evaluated like expected.
Thanks a lot!
