- Platform information:
- Hardware: CPUArchitecture/RAM/storage VM 4 core, 2gb ram 32gb HDD
- OS: what OS is used and which versionubuntu 18.04
- Java Runtime Environment: which java platform is used and what version 1.8.0_191
- openHAB version: Openhab2 2.4.0-1
im trying to learn openhab and this particular setup is purely for learning so i was trying to install the bindings in the gui then do the rest with the config files rather than using gui.
i got it running with the NTP plugin and the systeminfo plugin after a bit of back and forth.
i have a
testing.sitemap
testing.items
testing.things
everything was working fine.
i then tried to get the weather plugin working using new files
weather.items
weather.config
weather.sitemap
after reading various posts and troubleshooting i found a similar post suggesting
Blockquote
Delete your/var/lib/openhab2/config/org/openhab/weather.config
and try with only 1 location in your/etc/openhab2/services/weather.cfg
(fix .cfg, then delete .config)
Check also if you have listed the weather binding in your/etc/openhab2/services/addons.cfg
:binding = weather1
(you need to add the1
Blockquote
So i did this, (renaming instead of deleting) and rebooted
and my weather plugin started working perfectly
but i found it had stopped everything else working and all my bindings and everything else except the weather binding has gone from the gui??
thinking this has something to do with openhab v1 vs v2 bindings i then deleted the binding = weather1
from the addons.cfg and my weather plugin is still working but not my other plugins, seems i will need to reinstall the bindings.
Im now going to do that but i just wondered if anyone can advise what i did wrong or why this happened?
i realize im still very much lacking basic understanding so just trying to fill in the gaps as best i can.
After playing with these plugins i may do a fresh install because ultimately I would like to get familiar with the snmp and the knx plugins and put them to real world use. i figured starting with sysinfo, weather and ntp was enough to begin with. If you can suggest any other stepping stones to use with this install that would help me before tackling snmp and knx let me know.
thanks
B
