Hi all,
After reading through a lot of posts here, it looks like there has been a lot of recent work on making it easy to develop a binding.
I followed the Eclipse guide (v2.5) to a tee. I’ve even been able to debug existing bindings! I created a new binding using the create_openhab_binding_skeleton script and built it using mvn. But I can’t debug using the org.openhab.demo.app app.bndrun system.
The problem I’m hitting is the demo app can’t find the dependency. I’ve added the dependancy to the demo app pom.xml, but it looks like Maven is trying to download my new binding from a external repository (which it’s obviously not in yet). How do I tell the demo app to use the locally built version rather than trying to download it?
I’m presumably missing something silly. I think what I’m trying to do is exactly what the development guide is tailored to (creating a new binding).
The full error is as follows
Failed to execute goal on project e[36morg.openhab.demo.appe[m: e[1;31mCould not resolve dependencies for project org.openhab.demo:org.openhab.demo.app:jar:2.5.1-SNAPSHOT: Failure to find org.openhab.addons.bundles:org.openhab.binding.zabbix:jar:2.5.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forcede[m (biz.aQute.bnd:bnd-maven-plugin:4.3.0:bnd-process:default:process-classes)
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project e[36morg.openhab.demo.appe[m: e[1;31mCould not resolve dependencies for project org.openhab.demo:org.openhab.demo.app:jar:2.5.1-SNAPSHOT: Failure to find org.openhab.addons.bundles:org.openhab.binding.zabbix:jar:2.5.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forcede[m
at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies(LifecycleDependencyResolver.java:269)
at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.resolveProjectDependencies(LifecycleDependencyResolver.java:147)
at org.apache.maven.lifecycle.internal.MojoExecutor.ensureDependenciesAreResolved(MojoExecutor.java:248)
at org.eclipse.m2e.core.internal.embedder.MavenImpl.execute(MavenImpl.java:333)
at org.eclipse.m2e.core.internal.embedder.MavenImpl.lambda$8(MavenImpl.java:1381)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.executeBare(MavenExecutionContext.java:179)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:114)
at org.eclipse.m2e.core.internal.embedder.MavenImpl.execute(MavenImpl.java:1380)
at org.eclipse.m2e.core.project.configurator.MojoExecutionBuildParticipant.build(MojoExecutionBuildParticipant.java:54)
at bndtools.m2e.BndConfigurator$1.build(BndConfigurator.java:130)
at org.eclipse.m2e.core.internal.builder.MavenBuilderImpl.build(MavenBuilderImpl.java:135)
at org.eclipse.m2e.core.internal.builder.MavenBuilder$1.method(MavenBuilder.java:169)
at org.eclipse.m2e.core.internal.builder.MavenBuilder$1.method(MavenBuilder.java:1)
at org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.lambda$1(MavenBuilder.java:114)
at org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.lambda$0(MavenBuilder.java:105)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:153)
at org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:101)
at org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.execute(MavenBuilder.java:88)
at org.eclipse.m2e.core.internal.builder.MavenBuilder.build(MavenBuilder.java:197)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:833)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:220)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:263)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:316)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:319)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:371)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:392)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:154)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:244)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.apache.maven.project.DependencyResolutionException: Could not resolve dependencies for project org.openhab.demo:org.openhab.demo.app:jar:2.5.1-SNAPSHOT: Failure to find org.openhab.addons.bundles:org.openhab.binding.zabbix:jar:2.5.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced
at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:209)
at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies(LifecycleDependencyResolver.java:243)
... 33 more
Caused by: org.eclipse.aether.resolution.DependencyResolutionException: Failure to find org.openhab.addons.bundles:org.openhab.binding.zabbix:jar:2.5.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced
at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveDependencies(DefaultRepositorySystem.java:357)
at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve(DefaultProjectDependenciesResolver.java:202)
... 34 more
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException: Failure to find org.openhab.addons.bundles:org.openhab.binding.zabbix:jar:2.5.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:424)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:229)
at org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveDependencies(DefaultRepositorySystem.java:340)
... 35 more
Caused by: org.eclipse.aether.transfer.ArtifactNotFoundException: Failure to find org.openhab.addons.bundles:org.openhab.binding.zabbix:jar:2.5.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-artifactory-snapshot has elapsed or updates are forced
at org.eclipse.aether.internal.impl.DefaultUpdateCheckManager.newException(DefaultUpdateCheckManager.java:218)
at org.eclipse.aether.internal.impl.DefaultUpdateCheckManager.checkArtifact(DefaultUpdateCheckManager.java:193)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.gatherDownloads(DefaultArtifactResolver.java:559)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:483)
at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:401)
... 37 more
