[Solved]Calculate duration from number (seconds)
I have an item which receives a number from an http request. that works as expected
I want to calculate the hours and minutes (hh:mm) and send the new value to another item. Then I want to display that duration.
e.g. 6060 = 01h 41min
Can anyone help`?
I tried several rules but non woked
val totalSecs = SecondsNumber.state as Number
val sec = totalSecs % 60
val min = (totalSecs / 60) % 60
val hrs = (totalSecs / (60*60)) % 24
val day = totalSecs / (60*60*24)
Could I ask to give a hint how to include your code to my Player-Item to show the min:sec instead of dezimal.
Here my item (Squeezeboxplayer)
I think I have to replace the %d, but how?
Number SB_ARZ_Time "Time [%d]" { channel="squeezebox:squeezeboxplayer:LMS:SB_ARZ:currentPlayingTime" }
You don’t. The code above is the body of a Rule. You must create Rules in text .rules files. See
http://docs.openhab.org/tutorials/beginner/index.html
http://docs.openhab.org/configuration/rules-dsl.html
OK,
I created a rule:
rule "Calculate decimal time counter"
	Item SB_ARZ_Time changed
Because of my limited knowledge with object-orientated programming I don’t know how to handle the error which I see in the log.
Rule 'Calculate decimal time counter': The name 'SecondsNumber' cannot be resolved to an item or type; line 5, column 18, length 13
It just says that you don‘t have an Item called „SecondsNumber“
Also, this is just a code fragment. You still need to do the work to take day, hrs, min, and sec into a String and postUpdate that to your appropriate Item.
SB_ARZ_Time contains the number, so I changed to:
	val totalSecs = SB_ARZ_Time.state as Number
Now I get this error:
Rule 'Calculate decimal time counter': Unknown variable or command '%'; line 6, column 12, length 14
I really appreciate your help with some code.
Well shoot. It looks like the Rules DSL can’t work with Numbers for the modulo operator.
val int totalSecs = (SB_ARZ_Time.state as Number).intValue
Hi Rich,
thank you for your quick reply! I will try it the next days. The follow up by Doxer is also very useful to me …
Once I have a working solution I will post it here … but it may take some days :slight_smile:
kind reagrds
Markus
This is the working rule:
	val totalSecs = (SB_ARZ_Time.state as Number).intValue
	logInfo("default.rules", min.toString + ":" + sec.toString)
Now I have to investigate for the formating (ss:mm) and how to transfer this to the item. :frowning:
Something like this should work:
TimeString.postUpdate(String::format("%02d:%02d:%02d:%02d", day, hrs, min, sec))
Where TimeString is your String Item.
Got my problem solved and it is running as expected.
Short summary what I did:
Thos items are active:
Number  VU_Dauer    "Dauer [%s]"             		( VUPLUS )	{ http="<[http://192.168.1.6:80/web/getcurrent:3000:REGEX(.*?<e2eventduration>(.*?)</e2eventduration>.*)]" }
String  VU_Duration_converted    "Dauer1 [%s]" 		( VUPLUS
This rule is set:
rule "Dauer"
		Item   VU_Dauer changed
		val totalSecs = (VU_Dauer.state as Number).intValue
		val txt = (VU_Dauer)
		VU_Duration_converted.postUpdate(String::format("%02d:%02d",  hrs, min))
		logWarn("hilfe", "" +totalSecs)
Log tells me the correct received Number in seconds
2017-12-21 11:37:49.498 [WARN ] [eclipse.smarthome.model.script.hilfe] - 21600
Running on OH 2 and OH 2.2 (release)
Thank your for the help provided, appreciate it very much!
Hi Markus,
your post helped me how to transfer the value from the rule to the item. Learning by doing :slight_smile:
