Thanks, I was just starting to think along those lines, and it works decently. I also had to add a get channel and item in order to ask MQTT for the item state because it wasn’t getting updated after the transition time. I ended up with this:
Items:
Number Hue_OfficeLamp_Brightness "Brightness" { channel="mqtt:topic:b80400aa:brightness"}
Number Hue_OfficeLamp_TransitionTime "Transition time"
String Hue_OfficeLamp_Command "Command" { channel="mqtt:topic:b80400aa:command"}
String Hue_OfficeLamp_Get "Get" { channel="mqtt:topic:b80400aa:get"}
[{"id":"d36bb0f3.c22d8","type":"change","z":"2368f2dd.7ffe86","name":"Use brightness","rules":[{"t":"set","p":"command.brightness","pt":"msg","to":"payload.payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":120,"wires":[["aa44bd51.54231"]]},{"id":"aa44bd51.54231","type":"openhab2-get","z":"2368f2dd.7ffe86","name":"get transition time","controller":"8d5b202.2cf62e","itemname":"Hue_OfficeLamp_TransitionTime","x":510,"y":120,"wires":[["84f00198.3ec4a8"]]},{"id":"84f00198.3ec4a8","type":"change","z":"2368f2dd.7ffe86","name":"Use transition time","rules":[{"t":"set","p":"command.transition","pt":"msg","to":"payload.state","tot":"msg"},{"t":"set","p":"delay","pt":"msg","to":"$number(msg.payload.state) * 1000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":120,"wires":[["e09b630.0a989a"]]},{"id":"de5f6187.b95428","type":"openhab2-out","z":"2368f2dd.7ffe86","name":"","controller":"8d5b202.2cf62e","itemname":"Hue_OfficeLamp_Command","topic":"ItemCommand","payload":"","x":780,"y":180,"wires":[["e76a84e2.d90a3"]]},{"id":"e09b630.0a989a","type":"json","z":"2368f2dd.7ffe86","name":"Format as json","property":"command","action":"str","pretty":false,"x":380,"y":180,"wires":[["f4c78f5a.ecf818"]]},{"id":"4b62ca94.3ffe5c","type":"switch","z":"2368f2dd.7ffe86","name":"filter for commands","property":"payload.type","propertyType":"msg","rules":[{"t":"eq","v":"ItemCommandEvent","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":60,"wires":[["d36bb0f3.c22d8"]]},{"id":"f4c78f5a.ecf818","type":"change","z":"2368f2dd.7ffe86","name":"Set the payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"command","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":180,"wires":[["de5f6187.b95428"]]},{"id":"e76a84e2.d90a3","type":"delay","z":"2368f2dd.7ffe86","name":"delay by transition time","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":450,"y":240,"wires":[["33528c3d.35779c"]]},{"id":"33528c3d.35779c","type":"openhab2-out","z":"2368f2dd.7ffe86","name":"Refresh values","controller":"8d5b202.2cf62e","itemname":"Hue_OfficeLamp_Get","topic":"ItemCommand","payload":"","x":680,"y":240,"wires":[[]]},{"id":"90dd043b.a29a","type":"openhab2-in","z":"2368f2dd.7ffe86","name":"","controller":"8d5b202.2cf62e","itemname":"Hue_OfficeLamp_Brightness","x":140,"y":60,"wires":[[],["4b62ca94.3ffe5c"]]},{"id":"8d5b202.2cf62e","type":"openhab2-controller","z":"","name":"OpenHab","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""}]
