theory:
I have several items which belongs to the group
If I use this
rule "whatever"
Member of Motion changed from OFF to ON
//do stuff
Is it possible to use exact Item which triggered group to work with? For example to alert where motion was triggered without need of separate rule to find out which was triggered?
Just to add a bit more clarity, in Rules DSL, triggeringItem is the Item that triggered the Rule. So any of the methods and data members that are available on any Item (e.g. MyItem.name, MyItem.lastUpdate, etc.) are available on triggeringItem.
In Jython, you usually access of that stuff using different function calls passing the name of the Item.
