after i finally managed to change my code from 2.4 to 2.5 and app.bndrun doesn’t show any dependencies for my binding anymore, i have new problem:
Unfortunately, the things for my new binding can no longer be initialized or registered correctly. With paper-ui the thing will be created but not processed.
he following error message appears:
WARN o.e.s.c.t.internal.ThingRegistryImpl:259 - Cannot create thing. No binding found that supports creating a thing of type 'openwms:tcpbridge'.
and
ERROR o.e.s.i.r.c.i.thing.ThingResource:447 - Exception during HTTP PUT request for update config at 'things/openwms:tcpbridge:88e2f7b9/config'
java.lang.IllegalStateException: Thing with UID openwms:tcpbridge:88e2f7b9 has no handler attached.
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:93)
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:438)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
In the old development environment the ThingHandlerFactory (OSGI-INF) had to be created.
Is there such a way also neccessary in the new development environment?
I would be very happy about a hint for troubleshooting.
Thanks in advance
rainer
For code nothing changed between 2.4 and 2.5 (nothing structural). You still need ThingHandlerFactory. So I’m not sure how you came to the conclusion you don’t need it anymore? Did you have OSGI-INF xml files that you removed (we now use annotations) Can you point me to your code so I can give direct feedback.
