I’m pretty new to openHAB2. Today I heared of it for the first time.
It looks really interesting and promising, so I decided to give openHAB2 a try.
I’m using openHab on my Laptop currently.
Milight addon is installed .
Inbox is empty. clicking “+” shows “Milight Binding”.
clicking on “Milight Binding” starts a search for things but shortly comes up with “manually add thing”
I added a thing myself using the IP Address I have taken from the web interface and entered the port (8899) as well as the MAC Address of the iBox2.
Under Configuration → Things I see my iBox2, but the status is “offline - Configuration pending SESSION_WAIT_FOR_BRIDGE”
Any help is very much appreciated.
When you manually adding an ibox bridge you have to specify its MAC address. This means that you have to enter two things: IP and MAC address. That MAC address setting is hidden so that’s why I also could not get it to work.
You can find your MAC address by visiting the bridge web page:
Just a quick update from my side. I got this working today.
I have a Mi Light Wi-Fi iBox LED Controller (in OH seen as iBox/iBox2 milight:v6)
installed the Milight Binding within PaperUI - binding-milight - 2.4.0.M4
addded the ibox2 device to OH as a Thing
confgured the IP address of the box (made sure it is connected to my WiFi, same network as OH)
configured the MAC address (use SHOW MORE)
configured the port 5987 (use SHOW MORE)
3, 4 can be opbtained from the web-interface of the iBox when it is successfully connected to your WiFi.
DO NOTE USE THE TCP PORT FROM THE iBOX, DO NOT USE 8899, USE 5987 INSTEAD
