I’m using CalDAV configured with Google, I want to remove it, and using an internal CalDAV server.
I opened caldavio.cfg removed calendar configuration called casaOH and I added a new one called SynoOH.
I stopped Openhab, cleaned cache and deleted ics file into /var/lib/openhab2/etc/caldav and restarted, but in the log, I can see that CalDAV binding still try to connect to Google Calendar (casaOH).
Google config was removed from anywhere, but in the logs I still got it, attached logs where CalDAV check config for casaOH even if is not into caldavio.cfg.
2019-04-02 16:09:23.715 [DEBUG] [org.openhab.io.caldav ] - BundleEvent [unknown:512] - org.openhab.io.caldav
2019-04-02 16:09:23.719 [DEBUG] [org.openhab.io.caldav ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.openhab.io.caldav.CalDavLoader}={service.id=354, service.bundleid=242, service.scope=bundle, service.pid=org.openhab.caldavio, component.name=org.openhab.io.caldav.caldavloader, component.id=198} - org.openhab.io.caldav
2019-04-02 16:09:23.917 [DEBUG] [org.openhab.io.caldav ] - BundleEvent STARTING - org.openhab.io.caldav
2019-04-02 16:09:23.919 [DEBUG] [org.openhab.io.caldav.internal.CalDavActivator ] - CalDav Calendar IO has been started.
2019-04-02 16:09:23.919 [DEBUG] [org.openhab.io.caldav ] - BundleEvent STARTED - org.openhab.io.caldav
2019-04-02 16:09:23.927 [DEBUG] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - Update was called for CalDAV IO.
2019-04-02 16:09:23.931 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: casaOH:disableCertificateVerification
2019-04-02 16:09:23.933 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: casaOH:password
2019-04-02 16:09:23.933 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: casaOH:preloadTime
2019-04-02 16:09:23.934 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: casaOH:reloadInterval
2019-04-02 16:09:23.934 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: casaOH:url
2019-04-02 16:09:23.934 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: casaOH:username
2019-04-02 16:09:23.934 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:disableCertificateVerification
2019-04-02 16:09:23.935 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:password
2019-04-02 16:09:23.935 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:preloadTime
2019-04-02 16:09:23.935 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:reloadInterval
2019-04-02 16:09:23.935 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:timeZone
2019-04-02 16:09:23.935 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:url
2019-04-02 16:09:23.936 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: synoOH:username
2019-04-02 16:09:23.936 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - processing configuration parameter: timeZone
2019-04-02 16:09:23.936 [DEBUG] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - Overriding default timezone Europe/Rome with Europe/Rome
2019-04-02 16:09:23.937 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - config for calendar 'casaOH': CalDavConfig [key=casaOH, username=marco.pozzuolo@bizmatica.com, url=https://www.google.com/calendar/dav/xxxxxxxxx_ata1085hehmjxxxxxxxxxxx@group.calendar.google.com/events, reloadMinutes=1, preloadMinutes=20000, disableCertificateVerification=true, lastModifiedFileTimeStampValid=true]
2019-04-02 16:09:23.937 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - config for calendar 'synoOH': CalDavConfig [key=synoOH, username=calendario, url=https://1xxxxxxxx.xxxxxxxx:5001/caldav/calendario/rdqlnw/, reloadMinutes=1, preloadMinutes=20000, disableCertificateVerification=true, lastModifiedFileTimeStampValid=true]
2019-04-02 16:09:23.986 [INFO ] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - CalDAV IO is properly configured.
2019-04-02 16:09:24.002 [TRACE] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - starting execution...
2019-04-02 16:09:24.010 [INFO ] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - reload job scheduled for: casaOH
2019-04-02 16:09:24.012 [INFO ] [org.openhab.io.caldav.internal.CalDavLoaderImpl ] - reload job scheduled for: synoOH
Any suggestion would be appreciated.
Marco
