[SOLVED] Can't connect to local console
i am running openhab2 on a debian linux since it came out and experiencing now a new problem: I can’t connect to the console anymore. Version is the newest “testing”, port is open:
tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN      13746/java
and i get the following:
root@openhab:~# ssh -p 8101 openhab@localhost
Connection reset by 127.0.0.1 port 8101
Any suggestions?
Thanks and best regards, Jens
Are you using the apt package? Does the command:
openhab-cli console
get you in?
If this is a manual zip install, go to your openHAB home directory and use the command:
./runtime/bin/client
i am using the apt-package…
root@openhab:~# openhab-cli console
Logging in as openhab
Session is being closed
root@openhab:~#
does not work either…
Is there a chance that your IP address has changed? I initially had mine set at 192.168.1.123. After my last reboot it lost that location and got reset to 192.168.1.104. I have to lock it down to a set IP address.
no.. no change in IP address… And i am trying to connect from the device itself to localhost :frowning:
i fixed it… executed "openhab-cli reset-ownership " and restarted. Now the console is back up again :slight_smile:
Glad you got it solved! there must have been a permission issue with either /var/lib/openhab2 or /usr/share/openhab2.
I had this same issue. I found an error message in openhab.log saying the key in /var/lib/openhab2/etc/hosts.key was unable to be parsed.
Deleting hosts.key solved the problem.
I had this issue when i moved the openhab installation from a Linux laptop to a raspberry pi. I made a backup from the first and restored it on the latter. Everything looked ok but I could not connect to local console. Openhab-cli reset ownership solved this problem.
Thank you for the tip!
