Hi everyone,
I’m new with raspberry and I ask the community for help because the installation of the knxd service ends with an error and invites me to report the problem in the forum or on git.
I try to summarize my situation:
Raspberry 3B
Openhabian 1.5 image (for an automatic installation as possible) saved on 32GB MicroSD Kingston with Etcher
The first start was repeated several times for some errors (I checked the card and the power supply as I read on the forum and everything seems ok), until the 5th attempt was successful.
Through opehabian-config I launch the KNXD installation but in the end I always get the screen inviting you to report the error.
I have tried several times, even after a reboot.
I attach what I see on the terminal just out of the “openhabian-config”, hoping you can help me solve this problem (it seems to me that the error is in the bottom lines).
Edit note: The attached text is that of the first attempt, the others are slightly different because says that I already have the files, but the last lines are the same.
I only ask for a little patience because I am unfamiliar with the terminal commands and very little experience with RasPI
[11:06:21] openhabian@openhab:~$ sudo openhabian-config
[sudo] password for openhabian:
2020-03-18_11:06:30_GMT [openHABian] Checking for root privileges... OK
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Ign:3 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Get:4 https://dl.bintray.com/openhab/apt-repo2 stable Release [6,051 B]
Fetched 6,051 B in 2s (3,851 B/s)
Reading package lists... Done
2020-03-18_11:06:42_GMT [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-03-18_11:06:43_GMT [openHABian] openHABian configuration tool version: [master]v1.5-541(5158a5f)
2020-03-18_11:06:43_GMT [openHABian] Checking for changes in origin... OK
2020-03-18_11:06:57_GMT [openHABian] Setting up EIB/KNX IP Gateway and Router with knxd (http://michlstechblog.info/blog/raspberry-pi-eibknx-ip-gateway-and-router-with-knxd)...
$ wget -O /tmp/install_knxd_systemd.sh http://michlstechblog.info/blog/download/electronic/install_knxd_systemd.sh
--2020-03-18 11:07:02-- http://michlstechblog.info/blog/download/electronic/install_knxd_systemd.sh
Resolving michlstechblog.info (michlstechblog.info)... 178.254.10.73
Connecting to michlstechblog.info (michlstechblog.info)|178.254.10.73|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 16558 (16K) [application/x-sh]
Saving to: ‘/tmp/install_knxd_systemd.sh’
/tmp/install_knxd_systemd.sh 100%[=====================================================>] 16.17K --.-KB/s in 0.03s
2020-03-18 11:07:02 (532 KB/s) - ‘/tmp/install_knxd_systemd.sh’ saved [16558/16558]
$ sed -i s#git checkout tags/3.0.0#git checkout tags/5.0.0# /tmp/install_knxd_systemd.sh
$ sed -i s#cmake -DCMAKE_INSTALL_PREFIX=$INSTALL_PREFIX fmt/#cmake -DCMAKE_INSTALL_PREFIX=$INSTALL_PREFIX .# /tmp/install_knxd_systemd.sh
$ bash /tmp/install_knxd_systemd.sh
Dear User
Some issues reported regarding KNX USB Interfaces
with the latest stable version 0.14.18:ef3c496
see https://github.com/knxd/knxd/issues/290
As a workaround ersingencturk has tried to increase the timeout
and this still works reliable.
The patch sets
send-timeout from 300 to 6000
send-retries from 3 to 5
in src/libserver/emi_common.cpp
a suffix -emipatch to the knxd version is appended
PLEASE submit feedback or your experience about the stability of the patch as a comment to the post.
Would you like to apply patch ? [y|n]y
Raspberry 3 found!
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Fetched 6,051 B in 3s (1,943 B/s)
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
triggerhappy
Use 'sudo apt autoremove' to remove it.
The following packages have been kept back:
binutils binutils-arm-linux-gnueabihf binutils-common libbinutils
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
build-essential is already the newest version (12.6).
triggerhappy
The following additional packages will be installed:
cmake-data libarchive13 libjsoncpp1 librhash0 libuv1
Suggested packages:
cmake-doc ninja-build lrzip
The following NEW packages will be installed:
cmake cmake-data libarchive13 libjsoncpp1 librhash0 libuv1
0 upgraded, 6 newly installed, 0 to remove and 4 not upgraded.
Need to get 2,788 kB/4,601 kB of archives.
After this operation, 22.5 MB of additional disk space will be used.
Get:1 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf librhash0 armhf 1.3.8-1 [132 kB]
Get:2 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libuv1 armhf 1.24.1-1 [96.7 kB]
Get:3 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf cmake armhf 3.13.4-1 [2,559 kB]
Fetched 2,788 kB in 4s (718 kB/s)
Selecting previously unselected package cmake-data.
(Reading database ... 47774 files and directories currently installed.)
Preparing to unpack .../0-cmake-data_3.13.4-1_all.deb ...
Unpacking cmake-data (3.13.4-1) ...
Selecting previously unselected package libarchive13:armhf.
Preparing to unpack .../1-libarchive13_3.3.3-4+deb10u1_armhf.deb ...
Unpacking libarchive13:armhf (3.3.3-4+deb10u1) ...
Selecting previously unselected package libjsoncpp1:armhf.
Preparing to unpack .../2-libjsoncpp1_1.7.4-3_armhf.deb ...
Unpacking libjsoncpp1:armhf (1.7.4-3) ...
Selecting previously unselected package librhash0:armhf.
Preparing to unpack .../3-librhash0_1.3.8-1_armhf.deb ...
Unpacking librhash0:armhf (1.3.8-1) ...
Selecting previously unselected package libuv1:armhf.
Preparing to unpack .../4-libuv1_1.24.1-1_armhf.deb ...
Unpacking libuv1:armhf (1.24.1-1) ...
Selecting previously unselected package cmake.
Preparing to unpack .../5-cmake_3.13.4-1_armhf.deb ...
Unpacking cmake (3.13.4-1) ...
Setting up libarchive13:armhf (3.3.3-4+deb10u1) ...
Setting up libuv1:armhf (1.24.1-1) ...
Setting up librhash0:armhf (1.3.8-1) ...
Setting up cmake-data (3.13.4-1) ...
Setting up libjsoncpp1:armhf (1.7.4-3) ...
Setting up cmake (3.13.4-1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Updating FireMotD available updates count ...
triggerhappy
autotools-dev libltdl-dev libltdl7 libsigsegv2 m4
Suggested packages:
autoconf-archive gnu-standards autoconf-doc gettext libtool-doc gfortran | fortran95-compiler gcj-jdk m4-doc
autoconf automake autotools-dev libltdl-dev libltdl7 libsigsegv2 libtool m4
0 upgraded, 8 newly installed, 0 to remove and 4 not upgraded.
Need to get 2,499 kB of archives.
After this operation, 6,882 kB of additional disk space will be used.
Get:1 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libsigsegv2 armhf 2.12-2 [32.3 kB]
Get:2 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf m4 armhf 1.4.18-2 [185 kB]
Get:3 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf autoconf all 2.69-11 [341 kB]
Get:4 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf autotools-dev all 20180224.1 [77.0 kB]
Get:5 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf automake all 1:1.16.1-4 [771 kB]
Get:6 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libltdl7 armhf 2.4.6-9 [387 kB]
Get:7 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libltdl-dev armhf 2.4.6-9 [159 kB]
Get:8 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libtool all 2.4.6-9 [547 kB]
Fetched 2,499 kB in 2s (1,021 kB/s)
Selecting previously unselected package libsigsegv2:armhf.
(Reading database ... 50358 files and directories currently installed.)
Preparing to unpack .../0-libsigsegv2_2.12-2_armhf.deb ...
Unpacking libsigsegv2:armhf (2.12-2) ...
Selecting previously unselected package m4.
Preparing to unpack .../1-m4_1.4.18-2_armhf.deb ...
Unpacking m4 (1.4.18-2) ...
Selecting previously unselected package autoconf.
Preparing to unpack .../2-autoconf_2.69-11_all.deb ...
Unpacking autoconf (2.69-11) ...
Selecting previously unselected package autotools-dev.
Preparing to unpack .../3-autotools-dev_20180224.1_all.deb ...
Unpacking autotools-dev (20180224.1) ...
Selecting previously unselected package automake.
Preparing to unpack .../4-automake_1%3a1.16.1-4_all.deb ...
Unpacking automake (1:1.16.1-4) ...
Selecting previously unselected package libltdl7:armhf.
Preparing to unpack .../5-libltdl7_2.4.6-9_armhf.deb ...
Unpacking libltdl7:armhf (2.4.6-9) ...
Selecting previously unselected package libltdl-dev:armhf.
Preparing to unpack .../6-libltdl-dev_2.4.6-9_armhf.deb ...
Unpacking libltdl-dev:armhf (2.4.6-9) ...
Selecting previously unselected package libtool.
Preparing to unpack .../7-libtool_2.4.6-9_all.deb ...
Unpacking libtool (2.4.6-9) ...
Setting up autotools-dev (20180224.1) ...
Setting up libsigsegv2:armhf (2.12-2) ...
Setting up libltdl7:armhf (2.4.6-9) ...
Setting up libtool (2.4.6-9) ...
Setting up m4 (1.4.18-2) ...
Setting up autoconf (2.69-11) ...
Setting up automake (1:1.16.1-4) ...
update-alternatives: using /usr/bin/automake-1.16 to provide /usr/bin/automake (automake) in auto mode
Setting up libltdl-dev:armhf (2.4.6-9) ...
Processing triggers for install-info (6.5.0.dfsg.1-4+b1) ...
git is already the newest version (1:2.20.1-2+deb10u1).
triggerhappy
triggerhappy
autopoint dh-autoreconf dh-strip-nondeterminism dwz gettext intltool-debian libarchive-cpio-perl libarchive-zip-perl
libcroco3 libfile-stripnondeterminism-perl libmail-sendmail-perl libsys-hostname-long-perl po-debconf
Suggested packages:
devscripts dh-make gettext-doc libasprintf-dev libgettextpo-dev libmail-box-perl
autopoint cdbs debhelper dh-autoreconf dh-strip-nondeterminism dwz gettext intltool-debian libarchive-cpio-perl
libarchive-zip-perl libcroco3 libfile-stripnondeterminism-perl libmail-sendmail-perl libsys-hostname-long-perl po-debconf
0 upgraded, 15 newly installed, 0 to remove and 4 not upgraded.
Need to get 3,420 kB of archives.
After this operation, 10.4 MB of additional disk space will be used.
Get:1 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf autopoint all 0.19.8.1-9 [434 kB]
Get:2 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf cdbs all 0.4.159 [83.7 kB]
Get:3 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf dh-autoreconf all 19 [16.9 kB]
Get:4 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libarchive-zip-perl all 1.64-1 [96.8 kB]
Get:5 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf libfile-stripnondeterminism-perl all 1.1.2-1 [19.8 kB]
Get:6 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf dh-strip-nondeterminism all 1.1.2-1 [13.0 kB]
Get:7 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf dwz armhf 0.12-3 [66.0 kB]
Get:8 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libcroco3 armhf 0.6.12-3 [132 kB]
Get:9 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf gettext armhf 0.19.8.1-9 [1,219 kB]
Get:10 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf intltool-debian all 0.35.0+20060710.5 [26.8 kB]
Get:12 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf debhelper all 12.1.1 [1,016 kB]
Get:11 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf po-debconf all 1.0.21 [248 kB]
Get:13 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libarchive-cpio-perl all 0.10-1 [10.3 kB]
Get:14 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libsys-hostname-long-perl all 1.5-1 [12.0 kB]
Get:15 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libmail-sendmail-perl all 0.80-1 [25.3 kB]
Fetched 3,420 kB in 4s (771 kB/s)
Selecting previously unselected package autopoint.
(Reading database ... 50732 files and directories currently installed.)
Preparing to unpack .../00-autopoint_0.19.8.1-9_all.deb ...
Unpacking autopoint (0.19.8.1-9) ...
Selecting previously unselected package cdbs.
Preparing to unpack .../01-cdbs_0.4.159_all.deb ...
Unpacking cdbs (0.4.159) ...
Selecting previously unselected package dh-autoreconf.
Preparing to unpack .../02-dh-autoreconf_19_all.deb ...
Unpacking dh-autoreconf (19) ...
Selecting previously unselected package libarchive-zip-perl.
Preparing to unpack .../03-libarchive-zip-perl_1.64-1_all.deb ...
Unpacking libarchive-zip-perl (1.64-1) ...
Selecting previously unselected package libfile-stripnondeterminism-perl.
Preparing to unpack .../04-libfile-stripnondeterminism-perl_1.1.2-1_all.deb ...
Unpacking libfile-stripnondeterminism-perl (1.1.2-1) ...
Selecting previously unselected package dh-strip-nondeterminism.
Preparing to unpack .../05-dh-strip-nondeterminism_1.1.2-1_all.deb ...
Unpacking dh-strip-nondeterminism (1.1.2-1) ...
Selecting previously unselected package dwz.
Preparing to unpack .../06-dwz_0.12-3_armhf.deb ...
Unpacking dwz (0.12-3) ...
Selecting previously unselected package libcroco3:armhf.
Preparing to unpack .../07-libcroco3_0.6.12-3_armhf.deb ...
Unpacking libcroco3:armhf (0.6.12-3) ...
Selecting previously unselected package gettext.
Preparing to unpack .../08-gettext_0.19.8.1-9_armhf.deb ...
Unpacking gettext (0.19.8.1-9) ...
Selecting previously unselected package intltool-debian.
Preparing to unpack .../09-intltool-debian_0.35.0+20060710.5_all.deb ...
Unpacking intltool-debian (0.35.0+20060710.5) ...
Selecting previously unselected package po-debconf.
Preparing to unpack .../10-po-debconf_1.0.21_all.deb ...
Unpacking po-debconf (1.0.21) ...
Selecting previously unselected package debhelper.
Preparing to unpack .../11-debhelper_12.1.1_all.deb ...
Unpacking debhelper (12.1.1) ...
Selecting previously unselected package libarchive-cpio-perl.
Preparing to unpack .../12-libarchive-cpio-perl_0.10-1_all.deb ...
Unpacking libarchive-cpio-perl (0.10-1) ...
Selecting previously unselected package libsys-hostname-long-perl.
Preparing to unpack .../13-libsys-hostname-long-perl_1.5-1_all.deb ...
Unpacking libsys-hostname-long-perl (1.5-1) ...
Selecting previously unselected package libmail-sendmail-perl.
Preparing to unpack .../14-libmail-sendmail-perl_0.80-1_all.deb ...
Unpacking libmail-sendmail-perl (0.80-1) ...
Setting up libarchive-zip-perl (1.64-1) ...
Setting up autopoint (0.19.8.1-9) ...
Setting up libcroco3:armhf (0.6.12-3) ...
Setting up dwz (0.12-3) ...
Setting up libarchive-cpio-perl (0.10-1) ...
Setting up cdbs (0.4.159) ...
Setting up libsys-hostname-long-perl (1.5-1) ...
Setting up libfile-stripnondeterminism-perl (1.1.2-1) ...
Setting up gettext (0.19.8.1-9) ...
Setting up intltool-debian (0.35.0+20060710.5) ...
Setting up libmail-sendmail-perl (0.80-1) ...
Setting up po-debconf (1.0.21) ...
Setting up debhelper (12.1.1) ...
Setting up dh-autoreconf (19) ...
Setting up dh-strip-nondeterminism (1.1.2-1) ...
libsystemd0 is already the newest version (241-7~deb10u3+rpi1).
pkg-config is already the newest version (0.29-6).
triggerhappy
libusb-1.0-doc
libsystemd-dev libusb-1.0-0-dev libusb-1.0-doc libusb-dev
0 upgraded, 4 newly installed, 0 to remove and 4 not upgraded.
Need to get 605 kB of archives.
After this operation, 2,829 kB of additional disk space will be used.
Get:1 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf libsystemd-dev armhf 241-7~deb10u3+rpi1 [322 kB]
Get:2 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libusb-1.0-0-dev armhf 2:1.0.22-2 [65.5 kB]
Get:3 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libusb-1.0-doc all 2:1.0.22-2 [182 kB]
Get:4 http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian buster/main armhf libusb-dev armhf 2:0.1.12-32 [35.7 kB]
Fetched 605 kB in 1s (464 kB/s)
Selecting previously unselected package libsystemd-dev:armhf.
(Reading database ... 51701 files and directories currently installed.)
Preparing to unpack .../libsystemd-dev_241-7~deb10u3+rpi1_armhf.deb ...
Unpacking libsystemd-dev:armhf (241-7~deb10u3+rpi1) ...
Selecting previously unselected package libusb-1.0-0-dev:armhf.
Preparing to unpack .../libusb-1.0-0-dev_2%3a1.0.22-2_armhf.deb ...
Unpacking libusb-1.0-0-dev:armhf (2:1.0.22-2) ...
Selecting previously unselected package libusb-1.0-doc.
Preparing to unpack .../libusb-1.0-doc_2%3a1.0.22-2_all.deb ...
Unpacking libusb-1.0-doc (2:1.0.22-2) ...
Selecting previously unselected package libusb-dev.
Preparing to unpack .../libusb-dev_2%3a0.1.12-32_armhf.deb ...
Unpacking libusb-dev (2:0.1.12-32) ...
Setting up libusb-1.0-doc (2:1.0.22-2) ...
Setting up libusb-1.0-0-dev:armhf (2:1.0.22-2) ...
Setting up libusb-dev (2:0.1.12-32) ...
Setting up libsystemd-dev:armhf (241-7~deb10u3+rpi1) ...
triggerhappy
libev4
libev-dev libev4
0 upgraded, 2 newly installed, 0 to remove and 4 not upgraded.
Need to get 160 kB of archives.
After this operation, 292 kB of additional disk space will be used.
Get:1 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf libev4 armhf 1:4.25-1 [34.5 kB]
Get:2 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf libev-dev armhf 1:4.25-1 [125 kB]
Fetched 160 kB in 1s (236 kB/s)
Selecting previously unselected package libev4:armhf.
(Reading database ... 52357 files and directories currently installed.)
Preparing to unpack .../libev4_1%3a4.25-1_armhf.deb ...
Unpacking libev4:armhf (1:4.25-1) ...
Selecting previously unselected package libev-dev.
Preparing to unpack .../libev-dev_1%3a4.25-1_armhf.deb ...
Unpacking libev-dev (1:4.25-1) ...
Setting up libev4:armhf (1:4.25-1) ...
Setting up libev-dev (1:4.25-1) ...
triggerhappy
setserial
0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
Need to get 48.3 kB of archives.
After this operation, 106 kB of additional disk space will be used.
Get:1 http://ftp.arnes.si/mirrors/raspbian/raspbian buster/main armhf setserial armhf 2.17-52 [48.3 kB]
Fetched 48.3 kB in 1s (85.5 kB/s)
Preconfiguring packages ...
Selecting previously unselected package setserial.
(Reading database ... 52373 files and directories currently installed.)
Preparing to unpack .../setserial_2.17-52_armhf.deb ...
Unpacking setserial (2.17-52) ...
Setting up setserial (2.17-52) ...
removing the old setserial entry in the rcn.d directories
Update complete.
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
[ ok ] Stopping setserial (via systemctl): setserial.service.
Created symlink /etc/systemd/system/multi-user.target.wants/setserial.service → /lib/systemd/system/setserial.service.
Created symlink /etc/systemd/system/multi-user.target.wants/etc-setserial.service → /lib/systemd/system/etc-setserial.service.
Processing triggers for systemd (241-7~deb10u3+rpi1) ...
Cloning into 'knxd'...
remote: Enumerating objects: 111, done.
remote: Counting objects: 100% (111/111), done.
remote: Compressing objects: 100% (76/76), done.
remote: Total 12643 (delta 61), reused 61 (delta 34), pack-reused 12532
Receiving objects: 100% (12643/12643), 3.44 MiB | 1.20 MiB/s, done.
Resolving deltas: 100% (9704/9704), done.
Already on 'master'
Your branch is up to date with 'origin/master'.
patching file src/libserver/emi_common.cpp
Hunk #1 FAILED at 60.
1 out of 1 hunk FAILED -- saving rejects to file src/libserver/emi_common.cpp.rej
patching file tools/version.sh
FAILED
2020-03-18_11:15:49_GMT [openHABian] Checking for default openHABian username:password combination... OK
2020-03-18_11:15:49_GMT [openHABian] We hope you got what you came for! See you again soon ;)
