and I uninstall from PaperUI. The results is that Binding go on working and writing logs, and if I reboot OpenHab, the binding is still installed in PaperUI, but if i do a bundle:list into console, binding is not present but still working fine.
Simply cleaning the cache didn’t work then try deleting /var/lib/openhab2/config/org/openhab/addons.config. Doing this will regenerate the file and hopefully solve the issue.
Note: Please use sudo systemctl stop openhab2 before deleting the file above. While you have it stopped I would go ahead and clean the cache again then reboot.
If you would please mark the topic as solved by clicking the square box on the post that provided the solution and edit the title to start with [Solved]. This will help others with a similar issue find a quick solution.
