[SOLVED] Command 'string.contains()' not a member of '...items.StringItem'
Dear all,
I am pretty new to openHAB and I am currently struggeling with a rule execution. I’d like to change the color setting of my HUE lamp depending on the content of a string item (here ‘WeatherWarningString’) of the DWD Unwetter binding. The rule is as follows:
rule “Define Weather Event”
Item SwitchX changed to ON // SwitchX is triggered in a separate rule by an event channel
if (WeatherWarningString.contains(“Storm”)) {
var DecimalType hueINT = new DecimalType(120)
var PercentType saturationINT = new PercentType(100)
var PercentType brightnessINT = new PercentType(100)
var HSBType changeCol = new HSBType(hueINT, saturationINT, brightnessINT) }
else {
var DecimalType hueINT = new DecimalType(360)
ColorX.sendCommand(changeCol)
Executing the rule leads to the following error message:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Define Weather Event’: ‘contains’ is not a member of ‘org.eclipse.smarthome.core.library.items.StringItem’;
I have checked recent posts on this forum, on whether I am missing to load an additional library, but could not found any solution.
I am using openHAB 2.4.0 release on a raspberry pi 2.
Any help would be much appreciated!
Thanks a lot,
Thomas
An Item is an object with name, label, etc. properties. You would presumably be interested in its state property.
State may not have all the methods of a regular string variable, I don’t know, so to be safe I’d get the string conversion anyway.
myItem.state.toString.contains(…
As what @rossko57 said, this need to be:
if (WeatherWarningString.state.contains(“Storm”)) {
Dear rossko57,
dear ljsquare,
Thanks for your quick reply. Unfortunately neither
if (WeatherWarningString.state.contains(“Storm”)) nor
if (WeatherWarningString.state.toString.contains(“Storm”)) worked.
With “state.toString” a second error message appears:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Define Weather Event’: ‘contains’ is not a member of ‘org.eclipse.smarthome.core.types.State’;
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Define weather event’: Script interpreter couldn’t be obtain
Please use code fences
Rule ‘Define Weather Event’ is a different rule from ‘Define weather event’
I think your rule editing has messed up somewhere.
if (someItem.state.toString.contains("xx")) { ...
works fine for me
The toString problem seems to be fixed now. The above error message does not occur any longer. Unfortunately I stumbled over another problem with my rule.
 rule "Define Weather Event"
    Item Kueche_Schalter changed to ON
    if (WarningLichTyp.state.toString.contains("Sturm")) {
        var HSBType lightOBJ = new HSBType(hueINT, saturationINT, brightnessINT)
    if (WarningLichTyp.state.toString.contains("Gewitter")) {
    if (WarningLichTyp.state.toString.contains("Frost")) {
        var DecimalType hueINT = new DecimalType(240)
    else {
        var PercentType saturationINT = new PercentType(0)
    sendCommand(Kueche_Farbe,lightOBJ)
This code results in
2019-10-19 19:46:13.621 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Weather.rules', using it anyway:
The value of the local variable lightOBJ is not used
Could there be something wrong with my if-else statements?
Thanks.
Try:
    var DecimalType hueINT = null
    var PercentType saturationINT = null
    var PercentType brightnessINT = null
    var HSBType lightOBJ = null
    else {
    Kueche_Farbe.sendCommand(lightOBJ)
Thanks a lot, that solved the problem. I only had to change
  else {
to
if (WarningLichTyp.state.toString.contains("NULL")){
because that is the name of the weather warning type if no alarm is active.
Best regards,
Thomas
Anyone know how to do in OH3? I found contains no longer support,
all my key rules use it. please help
