- Platform information:
- Hardware: CPUArchitecture/RAM/storage Raspberry Pi 3
- OS: what OS is used and which version Rasbian Stretch - up-to-date
- Java Runtime Environment: which java platform is used and what version Not sure how to determine
- openHAB version: 2.4 (packaage install)
- Issue of the topic: please be detailed explaining your issue
Comparison between a number var and a constant complains of null value. Trying to turn on light switch when sensor luminance falls below threshold, and turn it off when it rises above a higher threshold. Each luminance change event stores the current value and successively compares to the old one to make sure the value crosses the threshold. 999999 is used to flag the old value for the first event (I was using -1, but changed it in subsequent debugging). System startup rule should not be necessary but again created for debug purposes.
Conditional statement is flagged with a null value, but null is explicitly tested prior to this line so should never happen
if (ff_k_pendants_lastvalue != 999999) {
I probably should rename ff_k_pendants_lastvalue to luminance_previous for clarity.
This is very likely my misunderstanding of the scripting language or environment. I’m not sure how variable typing and scoping works, being more accustomed to C and Python.
- Please post configurations (if applicable):
- Items configuration related to the issue
Aeotec Smart Sensor 6 (although not implicated in this issue)
- Sitemap configuration related to the issue
- Rules code related to the issue
var ff_k_pendants_threshold_lo = 20
var ff_k_pendants_threshold_hi = 30
var ff_k_pendants_lastvalue = 999999
var luminance = 0
// Experiment - triggers twice when rule is reloaded, both on reload & refresh
rule "System restart"
System started
if (ff_k_pendants_lastvalue == null) {
logWarn("DefaultRules", "Restart: last value was null")
} else {
logWarn("DefaultRules", "Restart: Last value was [{}]", ff_k_pendants_lastvalue)
// When it gets dark in the family room, turn on the kitchen pendants
rule "FF_K_Pendants_On_When_Dark"
Item Sensor_FF_FR_Luminance changed
if (Sensor_FF_FR_Luminance.state != NULL && Sensor_FF_FR_Luminance.state != null) {
luminance = Sensor_FF_FR_Luminance.state as Number
logWarn("DefaultRules", "FR Luminance now [{}], was [{}]", luminance, ff_k_pendants_lastvalue)
if (ff_k_pendants_threshold_lo <= ff_k_pendants_lastvalue) {
if (luminance < ff_k_pendants_threshold_lo) {
sendCommand(FF_K_Pendants, ON)
if (ff_k_pendants_lastvalue <= ff_k_pendants_threshold_hi) {
if (ff_k_pendants_threshold_hi < luminance) {
sendCommand(FF_K_Pendants, OFF)
ff_k_pendants_lastvalue = luminance
} else {
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
2019-03-17 11:44:37.040 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2019-03-17 11:44:53.233 [WARN ] [.smarthome.model.script.DefaultRules] - Restart: Last value was [999999]
2019-03-17 11:44:53.451 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'default.rules'
2019-03-17 11:45:05.116 [WARN ] [.smarthome.model.script.DefaultRules] - Restart: Last value was [999999]
2019-03-17 11:47:07.095 [WARN ] [.smarthome.model.script.DefaultRules] - FR Luminance now [252], was [999999]
2019-03-17 11:53:23.552 [WARN ] [.smarthome.model.script.DefaultRules] - FR Luminance now [254], was [252]
2019-03-17 11:53:23.561 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'FF_K_Pendants_On_When_Dark': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_notEquals(int,int) on instance: null
2019-03-17 12:03:23.735 [WARN ] [.smarthome.model.script.DefaultRules] - FR Luminance now [253], was [252]
2019-03-17 12:03:23.747 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'FF_K_Pendants_On_When_Dark': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_notEquals(int,int) on instance: null
