Hi all, having a connection issue with OpenSprinkler. Seems pretty straight forward but its not finding the pi i have it running on. It’s on the same lan as my openhab build but running on a separate pi. in my opensprinker app the ip address is 10.1.10.7:8080. i have put that in with and without the 8080 in the binding setup in paperui. i have the port set at 80 in the binding. password is opendoor even though i do not use the authentication. and refresh 60.
i setup on simple switch as an item and added it to the sitemap. i get this in the log:
[hingStatusInfoChangedEvent] - 'opensprinkler:http:0a365875' changed from OFFLINE (COMMUNICATION_ERROR): Could not get the station channel 2 current state from the OpenSprinkler thing. to OFFLINE (COMMUNICATION_ERROR): Could not create a connection to the OpenSprinkler.
10.1.10.7:8080 and then port 80. that actually worked! it connected! i could still not get the switch to connect but at least opensprinkler showed “online”.
but wait, then it didnt. now it shows offline. and i get this error in the paper ui thing:
Status: OFFLINE - COMMUNICATION_ERROR Could not get the station channel 1 current state from the OpenSprinkler thing.
then i get this in the log:
[hingStatusInfoChangedEvent] - 'opensprinkler:http:0a365875' changed from OFFLINE (COMMUNICATION_ERROR): Could not get the station channel 2 current state from the OpenSprinkler thing. to OFFLINE (COMMUNICATION_ERROR): Could not get the station channel 1 current state from the OpenSprinkler thing.
2018-06-26 12:28:13.998 [vent.ItemStateChangedEvent] - Station01 changed from NULL to OFF
Was the issue ever resolved? I am considering OpenSprinkler, but want to see if others have been successful connecting and using the binding from an OpenHAB installation separate from the device.
Hey Harpo3! Yes, i have it working in 2.4. I connect to opensprinkler with the pi binding. I have it set to turn a valve on daily at a certain time. i use opensprinkler for that setting and turn the valve on. openhab reports that the valve triggered and i can manual control the valve through my sitemap.
Hi Clint! Thanks for your response. I found a Piface binding (OH 2.4.0-1), but not Pi. I am using a Raspberry Pi 3B for my OpenHAB server. Is this a beta binding?
I had the same issue, where the thing went offline with the message of:
OFFLINE - COMMUNICATION_ERROR *Could not get* the *station channel* 6 *current state*
The binding was configured with port 8080. So, I changed it to port 80 which brought the whole thing offline, then switched back to 8080. It then came back online. What triggered the error status?
