I’ve a number of Raspberry devices in my house controlling some motion and door sensors (all via GPIO) and i’ve some python scripts running on them to report the status into a central smarthome controller.
I’m investigating if I can move to OpenHAB as a central controller. I want to create multiple “items” for the door and motion sensors. For motion I’m using a Switch, I expect that for the door sensor in need (can) use the Contact item, like:
Thanks, I found that indeed, I was able to update the switches but not the contacts. But in the mean time found out that I need to use the PUT HTTP command and NOT the POST. That did the trick.
