- Platform information:
- Hardware: Raspberry 3
- OS:Openhabian
- Java Runtime Environment: Zulu
- openHAB version: 2.4
- Issue of the topic: I would like to control 5 rollershutters with a single proxy item; when the proxy item change status, only a single shutter moves. What is the correct way to address this? List all 5 after the sendCommand instruction so they move together? According to the logs all of them receive the command but only one of them moves.
Previously I was able to get this done using a Group entry in the sitemap with the mapping (with the 1.13 Souliss binding), but with the latest version of the Souliss binding, I no longer define the items of the binding, instead I add the gateway and the things get auto-discovered and then I link them to my items. With the latest binding, the same method of adding a Group entry to the sitemap with all the items produces the same behavior (only 1 shutter moves, not all of them). Unfortunately version 1.13 of the Souliss binding (which you can install from PaperUI) keeps one CPU spinning on 100% so I’d prefer to keep the newer one and figure out how to move all 5 together.
- Items configuration related to the issue
Channels are defined via PaperUI, but they are all Souliss entries which work fine when commands are sent to an individual entry.
Rollershutter GF_LivingRoom_Shutter1 “Roller Shutter” (GF_LivingRoom, gShutter) [“Rollershutter”] {channel=“”}
Rollershutter GF_LivingRoom_Shutter2 “Roller Shutter” (GF_LivingRoom, gShutter) [“Rollershutter”] {channel=“”}
Rollershutter GF_LivingRoom_Shutter3 “Roller Shutter” (GF_LivingRoom, gShutter) [“Rollershutter”] {channel=“”}
Rollershutter GF_Bedroom_Shutter1 “Roller Shutter” (GF_Bedroom, gShutter) [“Rollershutter”] {channel=“”}
Rollershutter GF_Bedroom_Shutter2 “Roller Shutter” (GF_Bedroom, gShutter) [“Rollershutter”] {channel=“”}
Sitemap configuration related to the issue
Text label="Roller Shutter" icon="rollershutter" { Default item=ProxyRollerGF } -
Rules code related to the issue
rule “GF proxy roller DOWN”
Item ProxyRollerGF received command DOWN
then {
sendCommand( GF_LivingRoom_Shutter1, DOWN )
sendCommand( GF_LivingRoom_Shutter2, DOWN )
sendCommand( GF_LivingRoom_Shutter3, DOWN )
sendCommand( GF_Bedroom_Shutter1, DOWN )
sendCommand( GF_Bedroom_Shutter2, DOWN )
rule “GF proxy roller UP”
Item ProxyRollerGF received command UP
then {
sendCommand( GF_LivingRoom_Shutter1, UP )
sendCommand( GF_LivingRoom_Shutter2, UP)
sendCommand( GF_LivingRoom_Shutter3, UP )
sendCommand( GF_Bedroom_Shutter1, UP )
sendCommand( GF_Bedroom_Shutter2, UP )
rule “GF proxy roller STOP”
Item ProxyRollerGF received command STOP
then {
sendCommand( GF_LivingRoom_Shutter1, STOP )
sendCommand( GF_LivingRoom_Shutter2, STOP)
sendCommand( GF_LivingRoom_Shutter3, STOP )
sendCommand( GF_Bedroom_Shutter1, STOP )
sendCommand( GF_Bedroom_Shutter2, STOP )
09:59:24.880 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ProxyRollerGF' received command DOWN
09:59:24.907 [INFO ] [smarthome.event.ItemStateChangedEvent] - ProxyRollerGF changed from NULL to 100
09:59:27.438 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_LivingRoom_Shutter1' received command DOWN
09:59:27.447 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_LivingRoom_Shutter2' received command DOWN
09:59:27.454 [INFO ] [arthome.event.ItemStatePredictedEvent] - GF_LivingRoom_Shutter1 predicted to become DOWN
09:59:27.465 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_LivingRoom_Shutter3' received command DOWN
09:59:27.478 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_Bedroom_Shutter1' received command DOWN
09:59:27.485 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_Bedroom_Shutter2' received command DOWN
09:59:27.518 [INFO ] [arthome.event.ItemStatePredictedEvent] - GF_LivingRoom_Shutter2 predicted to become DOWN
09:59:27.534 [INFO ] [smarthome.event.ItemStateChangedEvent] - GF_LivingRoom_Shutter1 changed from NULL to 100
09:59:27.555 [INFO ] [arthome.event.ItemStatePredictedEvent] - GF_LivingRoom_Shutter3 predicted to become DOWN
09:59:27.563 [INFO ] [smarthome.event.ItemStateChangedEvent] - GF_LivingRoom_Shutter2 changed from NULL to 100
09:59:27.569 [INFO ] [arthome.event.ItemStatePredictedEvent] - GF_Bedroom_Shutter1 predicted to become DOWN
09:59:27.576 [INFO ] [smarthome.event.ItemStateChangedEvent] - GF_LivingRoom_Shutter3 changed from NULL to 100
09:59:27.592 [INFO ] [arthome.event.ItemStatePredictedEvent] - GF_Bedroom_Shutter2 predicted to become DOWN
09:59:27.599 [INFO ] [smarthome.event.ItemStateChangedEvent] - GF_Bedroom_Shutter1 changed from NULL to 100
09:59:27.604 [INFO ] [smarthome.event.ItemStateChangedEvent] - GF_Bedroom_Shutter2 changed from NULL to 100
09:59:36.223 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'ProxyRollerGF' received command STOP
09:59:36.236 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_LivingRoom_Shutter1' received command STOP
09:59:36.253 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_LivingRoom_Shutter2' received command STOP
09:59:36.261 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_LivingRoom_Shutter3' received command STOP
09:59:36.268 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_Bedroom_Shutter1' received command STOP
09:59:36.273 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'GF_Bedroom_Shutter2' received command STOP
