[SOLVED] Controlling Neopixel LED with Openhab
Hello all,
i a’m trying to control a Neopicel led strip with Openhab2.
Now i saw this guid on the internet:
But i a’m unable to get it working.
I have a ESP8266-01 and a ESP-01S RGB Led controller. The ESP8266-01 receives a IP adres from the router.
When i turn on the red led bij pressing the ON button or with the slider i do see a comment in the openhab events.log that the red light has been turned on. But the light won’t turn on in real life.
I have used MQTT.fx to verify that Moqsuitto is receiving the comments, and the are received.
My items file:
Group All
Color RGBLed "NeoPixel Color" (All)
String RGBLedColor (All) {mqtt=">[broker:OpenHab/RGB:command:*:default]"}
Switch NEO_RED  "Red"   <red> {mqtt=">[broker:OpenHab/RGB:command:ON:255,0,0]"}
Switch NEO_YELLOW "Yellow" <yellow> {mqtt=">[broker:OpenHab/RGB:command:ON:100,96,0]"}
Switch NEO_BLUE "Blue" <darkblue> {mqtt=">[broker:OpenHab/RGB:command:ON:0,0,255]"}
Dimmer NEO_SLIDERRED "Neopixel Red [%d %%]"  <red> {mqtt=">[broker:OpenHab/RGB/RED:command:*:default]"}
Dimmer NEO_SLIDERGREEN "Neopixel Green [%d %%]" <green> {mqtt=">[broker:OpenHab/RGB/GREEN:command:*:default]"}
Dimmer NEO_SLIDERBLUE "Neopixel Blue [%d %%]" <blue> {mqtt=">[broker:OpenHab/RGB/BLUE:command:*:default]"}
Number W_RSSI  "RSSI [%d dbm]" <signal>  {mqtt="<[broker:home/nb/weer/RSSI:state:default]"}
String W_IP "IP [%s]" <network>   {mqtt="<[broker:home/nb/weer/IP:state:default]"}
String W_version "Software versie [%s]" <version>  {mqtt="<[broker:home/nb/weer/version:state:default]"}
String W_MAC "MAC [%s]" <mac> (Wweather) {mqtt="<[broker:home/nb/weer/mac:state:default]"}
Number W_IP_Uptime "Uptime [%d min]" <clock> (Wweather) {mqtt="<[broker:home/nb/weer/uptime:state:default]"}
My sitemap file:
sitemap NeoPixel label="NeoPixel"
    Frame label="NeoPixel" {
        Colorpicker item=RGBLed icon="slider"
Switch item=NEO_RED mappings=[ON="ON"]
Switch item=NEO_YELLOW mappings=[ON="ON"]
Switch item=NEO_BLUE mappings=[ON="ON"]
//Switch item=NEO_RAINBOWCYCLE mappings=[ON="ON"]
//Switch item=NEO_RAINBOWTHEATER mappings=[ON="ON"]
Slider item=NEO_SLIDERRED
Slider item=NEO_SLIDERGREEN
Slider item=NEO_SLIDERBLUE
Frame label="Info" {
Text item=W_RSSI
   Text item=W_IP
   Text item=W_version
   Text item=W_MAC
   Text item=W_IP_Uptime
My rules file:
import org.eclipse.smarthome.core.library.types.DecimalType
import org.eclipse.smarthome.core.library.types.HSBType
rule "Set HSB value of item RGBLed to RGB color value"
    Item RGBLed changed
    val hsbValue = RGBLed.state as HSBType
    val brightness = hsbValue.brightness.intValue
    val redValue = ((((hsbValue.red.intValue * 255) / 100) *brightness) /100).toString
    val greenValue = ((((hsbValue.green.intValue * 255) / 100) *brightness) /100).toString
    val blueValue = ((((hsbValue.blue.intValue * 255) / 100) *brightness) /100).toString
    val color = redValue + "," + greenValue + "," + blueValue
    sendCommand( RGBLedColor, color)
//part of Neopixel conf files
rule "Send  RGB items from slider"
    Item NEO_SLIDERRED changed or
    Item NEO_SLIDERGREEN changed or
    Item NEO_SLIDERBLUE changed
    val redValue=  Math::round(2.55* (NEO_SLIDERRED.state as DecimalType).intValue)
    val greenValue=  Math::round(2.55* (NEO_SLIDERGREEN.state as DecimalType).intValue) //
    val blueValue=  Math::round(2.55* (NEO_SLIDERBLUE.state as Number).intValue)
Arduino code:
#include "Adafruit_NeoPixel.h"
#include "ESP8266WiFi.h"
#include "PubSubClient.h" //Imroy
#include "userdata.h"
#define PIXEL_PIN    2    // Digital IO pin connected to the NeoPixels. that is D4
#define PIXEL_COUNT 5    // 60 pixels in the NeoPixel strip
// Parameter 1 = number of pixels in strip,  neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream, correct for neopixel stick
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick & rings
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
/* MQTT Topic Settings */
// Enter the topic for your LED strip
String topic = "OpenHab/RGB/#";//this is your 'catch all'  for MQTT topics
String IP;
String MAC;
/* Network Settings */
// Change for your WiFi network. DO NOT CHANGE HERE, CHANGE IN "userdata" tab
const char *ssid =  mySSID;    // cannot be longer than 32 characters!
const char *pass =  PASSW;    //
// Update these with values suitable for your network.
IPAddress server( myMQTT); //ipaddres MQTT server
//  STARTUP DEFAULTS
long  TXinterval = TRANSMITINTERVAL; // can set this in userdata.h
int   signalStrength;             // WiFi signal strength
long  lastMinute = -1;            // timestamp last minute
long  upTime = 0;               // uptime in minutes
byte scene;
// Initializes the color to zero
uint32_t color = 0;
// Initializes update status to false
volatile bool updateLights = false;
#define BUFFER_SIZE 100
// OTA configuration
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
const char* host = HOST; //set this in userdata.h
// function prototypes required by Arduino IDE 1.6.7, but we are now way passed that
void setupOTA(void);
void callback(const MQTT::Publish & pub) {
  if (pub.has_stream()) {
    uint8_t buf[BUFFER_SIZE];
    int read;
    while (read = pub.payload_stream()->read(buf, BUFFER_SIZE)) {
      Serial.write(buf, read);
    pub.payload_stream()->stop();
    Serial.println("*");
  } else
    Serial.print(pub.topic());
  Serial.print(" ");
  Serial.println(pub.payload_string());
  // Check if the control topic came in and split payload into  R,G,B values
  if (pub.topic() == "OpenHab/RGB") {
    String values = pub.payload_string();
    int c1 = pub.payload_string().indexOf(',');
    int c2 = pub.payload_string().indexOf(',', c1 + 1);
    int red = pub.payload_string().toInt();
    int green = pub.payload_string().substring(c1 + 1).toInt();
    int blue = pub.payload_string().substring(c2 + 1).toInt();
    color = strip.Color(red, green, blue);
    updateLights = true;
    scene=0;
  } else {
    // check if a scene setting topic came in
    if (pub.topic() == "OpenHab/RGB/scene") {
      scene=pub.payload_string().toInt();
WiFiClient wclient;
PubSubClient client(wclient, server);
void setup() {
  // Setup console
  Serial.begin(115200);
  delay(10);
  Serial.println();
  Serial.println();
  strip.begin();
  setupOTA();
  MAC = WiFi.macAddress();
void changeColor(uint32_t c) {
  if (updateLights) {
    for (uint16_t i = 0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
void loop() {
  if (WiFi.status() != WL_CONNECTED) {
    Serial.print("Connecting to ");
    Serial.print(ssid);
    Serial.println("...");
    WiFi.begin(ssid, pass);
    if (WiFi.waitForConnectResult() != WL_CONNECTED)
      return;
    Serial.println("WiFi connected");
  if (WiFi.status() == WL_CONNECTED) {
    if (!client.connected()) {
      if (client.connect("arduinoClient")) {
        client.set_callback(callback);
        client.subscribe(topic);
  if (client.connected())
    client.loop();
  changeColor(color);
  if (millis() % (TXinterval * 1000) == 0) {
    client.publish("home/nb/weer/version", VERSION); // no quotes or   "String" as it is a macro
    signalStrength = WiFi.RSSI();
    client.publish("home/nb/weer/RSSI", String(signalStrength));// these topics are my choice, can change them, but then do as well in yr itemsfile
    IP = WiFi.localIP().toString();
    client.publish("home/nb/weer/IP", String(IP));
    client.publish("home/nb/weer/mac", String(MAC));
    client.publish("home/nb/weer/uptime", String(upTime));
    //Serial.println(MAC);
  // INCREASE UPTIME
  if (lastMinute != (millis() / 60000)) {         // another minute passed ?
    lastMinute = millis() / 60000;
    upTime++;
  switch (scene) {
    case 1:  rainbow(20);
      break;
    case 2: redblue();
      break;
    case 3: bluedot();
      break;
      case 4: rainbowCycle(20);
      break;
      case 5:theaterChaseRainbow(50);
            break;
Can someone please tell me what i a’m doing wrong here.
Greet
Hallo all,
Truned out to be Mosquitto. I set it up to use a user and passwd, removed this from mosquitto.conf and now it works fine.
