nakh_Home
(Nakh Home)
1
Hi
i have found this really smart project and i have just an issue of syntax, i think
rule "Voice control"
Item VoiceCommand received command
// https://github.com/openhab/openhab/wiki/Controlling-openHAB-with-your-voice
var String command = VoiceCommand.state.toString.toLowerCase
logInfo("voice control","VoiceCommand received----" + command+ "----")
var String cmd = null
if ( command.contains("éteins") || command.contains("turn off") || command.contains("eteins")|| command.contains("éteindre")) {
logInfo("cmd ", "OFF two condition works" )
cmd = "OFF"
logInfo("cmd ", "éteindre: " + cmd )
if ( command.contains("allume") || command.contains("allumer") or || command.contains("turn on")) {
cmd = "ON"
logInfo("cmd ", "ONtwo condition works" )
// } else if (command.contains("ouvre")) {
// cmd = "OPEN"
// } else if (command.contains("ferme")) {
// cmd = "CLOSE"
if (command.contains("bain")) {
logInfo("cmd ", "bain: " + cmd )
sdblight.sendCommand(cmd)
sdblight.postUpdate(cmd)
appliqueSwitch.sendCommand(cmd)
appliqueSwitch.postUpdate(cmd)
SP2_1.sendCommand(cmd)
SP2_1.postUpdate(cmd)
if (command.contains("douche")) {
logInfo("cmd ", "douche: " + cmd )
ZWaveSwitch1_Channel1_Right.sendCommand(cmd)
ZWaveSwitch1_Channel2_Left.sendCommand(cmd)
but in the log, we can see the IF statement do not work
2018-04-01 18:11:47.503 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-01 18:11:47.514 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-01 18:11:47.508 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-01 18:12:09.123 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command et ta salle de bain
2018-04-01 18:12:09.143 [vent.ItemStateChangedEvent] - VoiceCommand changed from allume salle de bain to et ta salle de bain
2018-04-01 18:12:09.147 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-01 18:12:09.152 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----et ta salle de bain----
2018-04-01 18:12:09.161 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-01 18:12:09.529 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-04-01T18:11:09.512+0300 to 2018-04-01T18:12:09.517+0300
2018-04-01 18:12:17.634 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command turn off salle de bain
2018-04-01 18:12:17.663 [vent.ItemStateChangedEvent] - VoiceCommand changed from et ta salle de bain to turn off salle de bain
2018-04-01 18:12:17.681 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn off salle de bain----
2018-04-01 18:12:17.696 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn off salle de bain----
2018-04-01 18:12:17.699 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn off salle de bain----
2018-04-01 18:12:26.000 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command turn off douche
2018-04-01 18:12:26.034 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn off douche----
2018-04-01 18:12:26.039 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn off douche----
2018-04-01 18:12:26.027 [vent.ItemStateChangedEvent] - VoiceCommand changed from turn off salle de bain to turn off douche
2018-04-01 18:12:27.751 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:162723a63f8:node4' has been updated.
2018-04-01 18:12:28.002 [vent.ItemStateChangedEvent] - lastseen_Hen changed from 2018-04-01T18:11:27.763+0300 to 2018-04-01T18:12:27.982+0300
2018-04-01 18:12:35.999 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command turn on douche
2018-04-01 18:12:36.033 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn on douche----
2018-04-01 18:12:36.040 [vent.ItemStateChangedEvent] - VoiceCommand changed from turn off douche to turn on douche
2018-04-01 18:12:36.055 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----turn on douche----
what is wrong in my condition???
Thanks!!
vzorglub
(Vincent Regaud)
2
if ( command.contains("allume") || command.contains("allumer") || command.contains("turn on")) {
There was a or
in there that didn’t belong
Et voila…
nakh_Home
(Nakh Home)
3
Thanks.
it helped partially
cmd = "OFF"
cmd = "ON"
// cmd = "OPEN"
// cmd = "CLOSE"
if (command.contains("bain") || command.contains("ben")) {
it works for salle de bain
2018-04-02 10:13:25.075 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command allume salle de bain
2018-04-02 10:13:25.092 [vent.ItemStateChangedEvent] - VoiceCommand changed from Amin salle de bain to allume salle de bain
2018-04-02 10:13:25.132 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-02 10:13:25.136 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-02 10:13:25.155 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allume salle de bain----
2018-04-02 10:13:25.175 [INFO ] [.eclipse.smarthome.model.script.cmd ] - ONtwo condition works
2018-04-02 10:13:25.184 [INFO ] [.eclipse.smarthome.model.script.cmd ] - bain: ON
2018-04-02 10:13:25.190 [ome.event.ItemCommandEvent] - Item 'sdblight' received command ON
2018-04-02 10:13:25.197 [INFO ] [ab.binding.exec.internal.ExecBinding] - executed commandLine '/usr/bin/python /etc/openhab2/scripts/SendCode_Salon_RF.py /etc/openhab2/scripts/Codes/SDB_VENTA_ON.txt'
2018-04-02 10:13:25.202 [GroupItemStateChangedEvent] - gSdb changed from OFF to ON through sdblight
2018-04-02 10:13:25.208 [vent.ItemStateChangedEvent] - sdblight changed from OFF to ON
2018-04-02 10:13:25.211 [ome.event.ItemCommandEvent] - Item 'appliqueSwitch' received command ON
2018-04-02 10:13:25.218 [GroupItemStateChangedEvent] - gAll changed from OFF to ON through sdblight
2018-04-02 10:13:25.223 [vent.ItemStateChangedEvent] - appliqueSwitch changed from OFF to ON
but i have still two issues:
- the french word éteindre with the accent on the e is not identified.
2018-04-02 10:13:39.343 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command éteindre salle de bain
2018-04-02 10:13:39.357 [vent.ItemStateChangedEvent] - VoiceCommand changed from allume salle de bain to éteindre salle de bain
2018-04-02 10:13:39.387 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----éteindre salle de bain----
2018-04-02 10:13:39.393 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----éteindre salle de bain----
2018-04-02 10:13:39.400 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----éteindre salle de bain----
2018-04-02 10:13:39.397 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----éteindre salle de bain----
2018-04-02 10:13:39.458 [INFO ] [.eclipse.smarthome.model.script.cmd ] - bain: null
2018-04-02 10:13:39.462 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'null' to a command type which item 'sdblight' accepts: [OnOffType, RefreshType].
2018-04-02 10:13:39.467 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'null' to a state type which item 'sdblight' accepts: [OnOffType, UnDefType].
2018-04-02 10:13:39.472 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'null' to a command type which item 'appliqueSwitch' accepts: [OnOffType, RefreshType].
2018-04-02 10:13:39.477 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'null' to a state type which item 'appliqueSwitch' accepts: [OnOffType, UnDefType].
2018-04-02 10:13:39.482 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'null' to a command type which item 'SP2_1' accepts: [OnOffType, RefreshType].
2018-04-02 10:13:39.486 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'null' to a state type which item 'SP2_1' accepts: [OnOffType, UnDefType].
- “allumer douche” do not work and i have not idea why
018-04-02 10:18:15.357 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command allumer douche
2018-04-02 10:18:15.368 [vent.ItemStateChangedEvent] - VoiceCommand changed from Allume douche to allumer douche
2018-04-02 10:18:15.390 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allumer douche----
2018-04-02 10:18:15.396 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allumer douche----
2018-04-02 10:18:15.398 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allumer douche----
2018-04-02 10:18:15.399 [INFO ] [smarthome.model.script.voice control] - VoiceCommand received----allumer douche----
2018-04-02 10:18:15.406 [INFO ] [.eclipse.smarthome.model.script.cmd ] - ONtwo condition works
vzorglub
(Vincent Regaud)
4
Try to use spaces instead of “tabs” to indent your code
It is more consistent and easier to copy and paste between editors
if ( command.contains("éteins") || command.contains("turn off") || command.contains("eteins") || command.contains("éteindre")) {
- There is no
to close your “bain” if condition:
nakh_Home
(Nakh Home)
5
Thanks/Merci !!!
it works
now, i have an integration with voice command and google assistant!!!
