[SOLVED] Convert Temperature Readings in OpenWeatherMap
I just installed OpenWeatherMap and actually got it working. A big surprise for me since I can’t even set up the sensors correctly yet!! Still learning…
I noticed in the items file, all the temperature readings are displayed with [1f %unit%]
The special placeholder %unit% will then be replaced by the actual unit symbol. In addition, the placeholder %unit% can be placed anywhere in the state description.
All of the temp readings are showing in ° C. Is there a way to set the default readings in ° F other than changing each individual temperature reading line in the Items file?
Also, I noticed the wind direction is in ° instead of N/S/E/W etc. How would I go about changing that?
Thanks for any assistance!!
John
PaperUI → Configuration → System → Regional Settings → Show More → Imperial (US)
Thank you sihui!! I missed the “MORE” selection when setting up OH2
John
Forum search is really useful to learn
Thank you rossko57. I have been searching the forums for lots of help on things I want to do since this is all new to me. I missed that one and the settings for metric to imperial.
