[SOLVED] CPU Temperature
Hi, i tried to read the cpu temperature of my Raspberry Pi 3 with raspbian and Openhab 2. I used exec binding, systeminfo binding, i read a lot of issues about this into the community and guide, i tried everything but i can’t read the cpu temperature with openhab because with the cmd i have no problems. For example systeminfo binding print always 0.0°C and i didn’t find any solutions. Exec binding doesn’t print anything. Is there a solution?
Thanks!
SysInfo doesn’t work:
Exec should work:
You could also try SNMP:
Start here for debugging Exec binding problems:
It has been ages since I’ve done anything like this but I believe you need to install something in order for the Pi to return all this info.
Yes, solved!
I created a thing into the file name cpu_temp.things with the code:
Thing exec:command:apc [command="cat /sys/class/thermal/thermal_zone0/temp", interval=15, timeout=5, autorun=false]
Then i created two items, one linked to the thing (only the second is called into the sitemap file):
String Raspi (All) {channel="exec:command:apc:output"}
Number Raspi_CPU "Temperature CPU [%.1f °C]" <temperature>
finally i created a rules to get the temperature in decimal:
rule "CPU Temp"
        Item Raspi received update
        var String cpupdate = Raspi.state.toString.trim
        var Number cpuTemp = new DecimalType(cpupdate)
        sendCommand(Raspi_CPU, cpuTemp/1000)
and here we are, all is working!
I try this, but I get only - °C and no actual value. Is ther some rights are neccesary?
(I use OH 2.3; exec;RegEx are installed)
Jens
Try typing:
cat /sys/class/thermal/thermal_zone0/temp in the command line, what do you get?
I’ve got 44008
grafik
grafik
I think the Exec will not executed?!
My exec.things
My exec.items
Number Raspi_CPU "Temperature CPU [%.1f °C]" <temperature> (gAu)
openhab.log
grafik
events.log
grafik
Is a parametre neccasary to run the exec??? It doesent work!!!
:thinking:In order to get the CPU temperature I use the systeminfo binding.
I will use the exec to read some other values in vers. 1.x it was runnning but with the version 2.3 unfortune not:-(
Thats interesting. I use systeminfo binding too, but CPU temp does not seems to work, unless I`m trying to use incorrect syntax.
Number Sysinfo_Pi_Sensors_CpuTemp  (server) { channel="systeminfo:computer:openHABianPi:sensors#cpuTemp" }
Did you check on PaperUI Things? After selecting " Show More" the list of channels for your Pi should show under “Sensor” the “CPU Temperature” with the correct channel syntax. You could also link your item from there!
I was able to find CPU Temp, not sure how I missed that before. Thanks Jurgen.
