i’m testing some Echo Control rules
here the rule
var var_Echo_Garten_Volume = null
var Timer Test1_Timer = null
rule "Test"
Item testbutton changed to ON
val var_Echo_Garten_Volume = Echo_Garten_Volume.state()
Echo_Garten_Volume.sendCommand(60)
Echo_Garten_TTS.sendCommand('Test TTS ')
Test1_Timer = createTimer(now.plusSeconds(10)) [|
Echo_Garten_Volume.sendCommand(var_Echo_Garten_Volume)
main issue is that TTS_Volume is not working for me, so i created a rule to save the volume and restore it after the announcement (was working fine several days)
no after apt-get update / upgrade i receive the following error
any idea what is causing this ?
Thomas
2019-01-26 12:39:56.555 [ome.event.ItemCommandEvent] - Item 'testbutton' received command ON
2019-01-26 12:39:56.570 [vent.ItemStateChangedEvent] - testbutton changed from OFF to ON
2019-01-26 12:39:57.683 [ome.event.ItemCommandEvent] - Item 'Echo_Garten_Volume' received command 60
2019-01-26 12:39:57.687 [ome.event.ItemCommandEvent] - Item 'Echo_Garten_TTS' received command Test TTS
2019-01-26 12:39:57.693 [nt.ItemStatePredictedEvent] - Echo_Garten_Volume predicted to become 60
2019-01-26 12:39:57.704 [nt.ItemStatePredictedEvent] - Echo_Garten_TTS predicted to become Test TTS
2019-01-26 12:39:57.711 [vent.ItemStateChangedEvent] - Echo_Garten_TTS changed from to Test TTS
2019-01-26 12:40:00.087 [vent.ItemStateChangedEvent] - Echo_Garten_TTS changed from Test TTS to
2019-01-26 12:40:07.688 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-01-26T12:40:07.685+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
<XFeatureCallImplCustom>.sendCommand(<XFeatureCallImplCustom>)
} ] threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1103) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy129.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.IllegalArgumentException: java.lang.ClassCastException@153e27d
at sun.reflect.GeneratedMethodAccessor158.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
... 19 more
2019-01-26 12:40:07.794 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-01-26T12:40:07.685+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
2019-01-26 12:40:16.782 [vent.ItemStateChangedEvent] - TimeKNX changed from 2019-01-26T12:39:36.961+0100
